2000 K1200LT Tire Question - BMW Luxury Touring Community
 9Likes
  • 2 Post By PMitchell
  • 2 Post By mtrevelino
  • 3 Post By CharlieVT
  • 1 Post By hfsmall
  • 1 Post By Buff8stuff
post #1 of 17 Old Jun 13th, 2015, 11:25 am Thread Starter
A friend gave me a rear tire (no cost, never mounted - Metzeler,Z6 Roadtec 160/70 ZR17) for my 2000 K1200LT. I reviewed the posts on this forum and reviews for this tire and realize that this tire is not a recommended tire for a K1200LT. I always drive with 1 up and rarely take long trips. My question is will I have any clearance problems between the tire side and the drive shaft side. Further, will I have any problems/concerns if I use this sports tire? Any advice will be appreciated!
hfsmall is offline
post #2 of 17 Old Jun 13th, 2015, 12:11 pm
PMitchell's Avatar
Re: 2000 K1200LT Tire Question
[QUOTE=hfsmall; realize that this tire is not a recommended tire for a K1200LT. I always drive with 1 up and rarely take long trips. [/QUOTE]
If it's not recommended why would you even consider using it?
The recommended skins for LT are weight/speed rated. She's a big girl and runs fast on the slab.
Don't risk your life to save a few bucks.
gunny and deputy5211 like this.
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is offline
post #3 of 17 Old Jun 13th, 2015, 12:12 pm
mtrevelino's Avatar
If it were I, I would give the tire back to your friend. But, it is your LIFE, so do as you please.
gunny and vernvernvern like this.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #4 of 17 Old Jun 13th, 2015, 3:53 pm
CharlieVT's Avatar
Originally Posted by hfsmall View Post
... My question is will I have any clearance problems between the tire side and the drive shaft side. ....Further, will I have any problems/concerns if I use this sports tire?...
I'd just mount that sucker and see if there are any clearance problems. Then report back here so the rest of us will know. Thanks.
Part two: Well.... if it isn't weight rated for the K1200LT, maybe you can remove the top case, never ride two up, and calculate if the bike then weighs less than the weight rating of the tire you are considering.
Dark humor: and if you mount it and it blows out and puts you in the hospital for a few days, you can kill time while you are in traction posting on this site your results with that tire. Curious minds will want to know...
mtrevelino, gunny and johnbaker15 like this.
CharlieVT is offline
post #5 of 17 Old Jun 13th, 2015, 11:03 pm
fatbob307's Avatar
You could sell that tire to me for $50.00. I'd run it on my R1200GS!
Oh no my GS RUNS A 170/60, sorry.
Bob Lower
Casper, WY
'01 K1200LT
'03 R1150 RT
'13 R1200GS
'79 R100T w/Hack
'10 Triumph Thunderbird
'09 Triumph Bonneville
'07 Guzzi Norge
'88 HD FLHS
fatbob307 is offline
post #6 of 17 Old Jun 14th, 2015, 6:51 am
norton's Avatar
By now I guess you get the opinion of the forum members. A catastrophic tire failure can happen one mile from home as well as one hundred miles from home. Give it back or sell the tire and get one rated for the bike, it doesn't matter how often you ride or how far from home.
It reminds me of the guy who didn't want to wear protective riding clothing because it was to hot, uncomfortable and expensive, well bleeding is much more uncomfortable and expensive.
Good Luck and please do the right thing
Scott
2007 LT
norton is offline
post #7 of 17 Old Jun 14th, 2015, 9:02 am
Do not use this tire. It is not worth injury or your life if it fails. Riding a motorcycle is dangerous at best (which we all forget at times), so why increase your odds for a problem.
Notahog is offline
post #8 of 17 Old Jun 14th, 2015, 1:32 pm
I don't get the concern about stuff like this. For instance, replacing a Z-rated tire with an H-rated one of the same size is "not recommended", and some (maybe most) tire shops won't mount it to the vehicle, or maybe on the wheel if they know the fitment, but that doesn't mean it's unsafe or that it will kill you. So, my advice as a non-lawyer is to mount the tire, presuming that you can get someone to do that, and see if it fits OK. If it does, as it should since it's the same size, ride it and see how it does. It may wear faster, and if you load the LT up like it's capable of being loaded, it may fail, so don't do that.
Then let us know how it goes.
And thanks for submitting the question. I learn something from each of these threads. Even the oil threads.
Nope that's a lie, I don't read the oil threads.
bgerrity is offline
post #9 of 17 Old Jun 14th, 2015, 1:47 pm
I am guessing you are a non-engineer as well as a non-lawyer. :-)
post #10 of 17 Old Jun 14th, 2015, 3:38 pm
In this case it is replacing a 79V REINF (load of 963 lbs) tire with a 73W (Non REINF) (load of 803 lbs). Big difference in load rating and side wall rigidity.
post #11 of 17 Old Jun 14th, 2015, 4:48 pm
Enjoy The Ride
saddleman's Avatar
It is important to keep in mind the extra weight added to the side wall & tread when you are cornering.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is online now
post #12 of 17 Old Jun 14th, 2015, 6:33 pm
Axle's Avatar
my records show that I have used one of these tyres, I got 11300 km from it, my comment to self was, do not use if towing, rear tyre too soft allowing rear end wobble, I don't ride 2 up so I am guessing it would be similar (wobble) with pillion + gear.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #13 of 17 Old Jun 14th, 2015, 7:40 pm
Looks like that tire is 73W rated as opposed to the 79V recommended tire. So it has a higher speed rating but about a 150lb lower weight rating. I had a blowout in Idaho a couple years ago. Had to rent a car to go to Boise and the only tire there was the non-reinforced ME880 which has a 73H rating. Assuming about 1000 lbs for the bike then with the 73 rear and a 58 front the weight is still a few hundred pounds under the max tire rating. I completed that trip 2 up with gear on the 880 73H and continued to ride it until wornout, 11978 miles. I couldn't tell any difference. I suspect if I had a blowout on that one maybe I'd feel the lack of reinforcement, don't know. Tires on a bike are rated to attain maximum performance limits. I don't go anywhere near that in terms of my normal riding.
04 K1200LT, 05 F650GS
Enduro is offline
post #14 of 17 Old Jun 14th, 2015, 7:47 pm Thread Starter
K1200LT Tire Update
The BMW Luxury Touring Community Forum is truly a valuable resource for K1200LT owners! I asked a question regarding problems/concerns if I use a sports tire? Many knowledgeable fellow K1200LT owners responded with advice regarding my question that was extremely helpful and informative. I will not be putting a sports tire on my K1200LT and would encourage others owners to use only approved load rated tires on their K1200LT. I currently have a Bridgestone Battlax BT020 on my motorcycle with 2000+ remaining miles. I have been very pleased with this tire and will most likely stay with the Bridgestone BT020. Thank you fellow K1200LT for responding to my question!
CharlieVT likes this.
hfsmall is offline
post #15 of 17 Old Jun 15th, 2015, 9:16 pm
If you really read the previous 50 or 60 tire threads, you would have realized that just posting this question would get you a virtual beating on this forum.
Buff8stuff is offline
post #16 of 17 Old Jun 16th, 2015, 3:20 pm
Re: K1200LT Tire Update
+1 for the Bridgestone.
2006 LT
Magnesium Shwarz Metalic
Bountiful, Utah
2006lt is offline
post #17 of 17 Old Jun 18th, 2015, 2:35 pm
CharlieVT's Avatar
I thought we were pretty nice.
And his follow up post suggests he took it well.
2000 K1200LT Questions scotti K1200LT 23 Sep 20th, 2014 12:28 pm
Yet More Tire Questions Jim_McG K1200LT 23 Feb 7th, 2013 10:09 am
Tire wear question Trojan RT Series 14 Oct 7th, 2012 12:39 pm
Rear tire question Teach RT Series 7 Aug 19th, 2012 2:18 am
New/Old tire question Mick-F RT Series 4 Jan 7th, 2009 10:56 am
