Running lights on the rear - BMW Luxury Touring Community
post #1 of 20 Old Jun 12th, 2015, 4:55 pm Thread Starter
SEG
I am looking to add running lights on the rear of the LT. My wife was recently riding in a car behind the LT at night and remarked after the trip that it was hard to see the LT on the road. What has worked well for some of the listers? Pics would be appreciated. Thank you.
Scott
- 2009 LT
- BMW MOA #92950
- BMW RA #41621
- IBA #35299
SEG is offline
post #2 of 20 Old Jun 12th, 2015, 5:19 pm
EzyMount's Avatar
Lots of good LED solutions out there. Try CarID.com and look for LED lighting. I used one of their kits to add amber running lights inside my smoke front turn signal housings.
EzyMount is offline
post #3 of 20 Old Jun 12th, 2015, 6:35 pm
cbpip's Avatar
Re: Running lights on the rear
Skene Design Motorcycle Visibility Lights
Check out Jerry Skeens P3 for the rear of the bike. Quality product and he stands by his lights if you have an issue with them. Easy install . Lots of riders using them.
76 Honda 750 four-departed
65 Pan head (gone)
72 Rickman 6 day Enduro
BMWMOA # 189093
BMWBMW LOCAL CHAPTER Member
BMW MARS CHAPTER Member
BMWRA # 41568
cbpip is offline
post #4 of 20 Old Jun 12th, 2015, 7:49 pm
bob1811's Avatar
I've added Hyper-lights, 2- 1157 LED bulbs in the main lens fixture and a LED light bar... see pic
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #5 of 20 Old Jun 12th, 2015, 9:50 pm
Scott
I installed this shortly after buying my 2007. I have not had anyone yet miss my brake application, particularly at night or in low light conditions.
Kisan 25LED Lt Tailblazer for BMW K1200 Lt | eBay
post #6 of 20 Old Jun 12th, 2015, 9:57 pm
EzyMount's Avatar
I'm going to add a 23" long Red LED strip to top of taillight fixture, initially only as 'on with ignition', later may add circuit to permit it to also function with stoplights as well... I already have BackOff wired into my top case stoplight fixture, figure that will be enough....
Jim Lawson 2016 R1200RT
Retired to NC !
EzyMount is offline
post #7 of 20 Old Jun 12th, 2015, 10:10 pm
EzyMount's Avatar
I installed 2 Kisan Plug'n Play bulbs on my older 00 LT. They get a lot of attention, with no problems.
EzyMount is offline
post #8 of 20 Old Jun 13th, 2015, 7:45 am
mtrevelino's Avatar
On my 00 LT I installed a top case brake/tail light. On you year bike you should already have something like this installed from the factory?
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #9 of 20 Old Jun 13th, 2015, 7:58 am
cbpip's Avatar
Currently running
Skene P3
Kissan LED 25 for leds on top case rack
Kissan Plug and play bulbs
Front has
Moto Lights with Amber bulbs
PIAA 1100x
Adding
Skene Photon Blasters yellow double LEDs to front
Never enough or too much conspicuous lighting on a bike IMO.
65 Pan head (gone)
BMWMOA # 189093
BMWRA # 41568
cbpip is offline
post #10 of 20 Old Jun 13th, 2015, 11:33 am Thread Starter
SEG
My '09 has the top case brake/tail light, but I'd like running lights up high. Options I'm considering are a string of LEDS used as running lights, on the top case, mil grade 3M reflective tape or maybe a short LED band on the back of the helmet. Lumenflex has the helmet LEDs at Lumenflex | Wearable LED Lighting for Peak Visibility and Moto Reflective has the reflective tape at MotoReflective: Motorcycle Reflective/Retroreflective vinyl tape.
- 2009 LT
- BMW MOA #92950
- BMW RA #41621
- IBA #35299
SEG is offline
post #11 of 20 Old Jun 17th, 2015, 9:38 pm
Bob,
Where did you get the light bar above the plate. It looks great.
Stu
2005 K1200LT
2005 Harley Davidson Duece
Wirestu is offline
post #12 of 20 Old Jun 17th, 2015, 10:13 pm
bob1811's Avatar
Originally Posted by Wirestu View Post
Bob,
Stu
Stu,
Back in 2008, I purchased the light bar from www.cyclegadgets.com. It's the Backoff 6" LED light bar. It's dual intensity, so it works as a running and brake light. I don't know if cyclegadets.com still sells them. If not, I'm sure that someone else has them. Back on 08' they sold for about $39.00.
Let me know if you need more info.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #13 of 20 Old Jun 18th, 2015, 8:17 am
EzyMount's Avatar
Cycle Gadgets no longer in business
EzyMount is offline
post #14 of 20 Old Jun 21st, 2015, 10:02 pm
Hooligan's Avatar
Scott
Are you looking for running lights or more tail/brake lights. You can add LED lights to your lt easily and cheaply. Part #s available if anyone is interested. Added three pics with lights off, tail lights only and brake light. Just have to move your license plate down and do a little wiring.
ID:	83090   Click image for larger version
ID:	83098   Click image for larger version
Hooligan is offline
post #15 of 20 Old Jun 22nd, 2015, 7:47 am
Scouter-50's Avatar
Post numbers please. Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #16 of 20 Old Jun 22nd, 2015, 9:06 am
Seriously look at and consider the Kisan Signal Minder. You can program this device to turn all your lights (brake and turn signal) into running lights. They will flash for a couple of second every time you hit the brakes and still allow the signals to function normally. You can also change the timing of the auto cancel on the signals. Add LEDs to the saddle bag reflectors and the blank area behind the bulb in the front signal lights. My Muth mirrors are also hooked up to work as both running and signal lights.
You can add these small trailer marker lights to the back of the chrome part of the tip over wings (also available in red).
I like the add on that Wayne has as well.
Buff8stuff is offline
post #17 of 20 Old Jun 23rd, 2015, 9:21 pm
newguy's Avatar
I'm sending this for Hooligan as he is out of town. The NAPA part numbers are LED Mod 45 STT T-LIT 4550(LED Light itself), Grommet 4570, Plug 50-94993-3 These parts cost a total $35.51 if bought individually. If you buy the complete unit all put together NAPA wants $135. We also have a template cut out of cardboard if you need it.
newguy is offline
post #18 of 20 Old Jun 28th, 2015, 2:31 pm Thread Starter
SEG
I am interested in adding running lights. I already have LEDs that flash when the brakes are applied. More lighting in the rear will be better.
Thank you for posting the part numbers. I'd appreciate the template. I'll send a PM. Thank you.
Scott
QUOTE=newguy;1339266]I'm sending this for Hooligan as he is out of town. The NAPA part numbers are LED Mod 45 STT T-LIT 4550(LED Light itself), Grommet 4570, Plug 50-94993-3 These parts cost a total $35.51 if bought individually. If you buy the complete unit all put together NAPA wants $135. We also have a template cut out of cardboard if you need it.[/QUOTE]
- 2009 LT
- BMW MOA #92950
- BMW RA #41621
- IBA #35299
SEG is offline
post #19 of 20 Old Jun 28th, 2015, 10:28 pm
CR125Honda's Avatar
Your timing is good. Just ordered a couple of these. One for the LT, one for an R1 and another for an ole Harley.
Your 09 and my 03 LTC has the LED light bar on the top case.
Did a little research on this item (GS-100A).
For $3.00, you can't hardly go wrong.
They're on the slow boat from China now.
Strobes the LED light bar a few times then goes solid.
12V-24V GS-100A Car LED Brake Stop Bulb Light Strobe Flash Module Controller Box
If this link stops working, search GS-100A on eBay. It was the lowest cost I found on eBay and had over 300 purchases.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Couple Mini Trail's QA' & CT's
CR125Honda is offline
post #20 of 20 Old Jul 20th, 2015, 11:43 am
CR125Honda's Avatar
Just an update.
Installed the LED Strobe controller last night.
Very pleased with the result.
Took a short video, link below.
GS-100A strobe controller video
Regards, Ken
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Givi top Box LED wiring HowardRichman K1200/1300GT (The Next Generation) 21 Jul 27th, 2010 11:47 pm
Finally Flashing LED Rear Lights for RT Lopaca RT Series 63 Aug 12th, 2009 7:10 pm
Running lights for the front? beemerguywhotravelsalot K1200LT 2 Jul 11th, 2009 12:28 pm
How can I install boat running lights on LT JoyfulSoul Lighting 8 Oct 29th, 2005 3:56 pm
running lights Brian_H K1200LT 7 Oct 11th, 2005 3:28 pm
