clutch plate supposed to spin freely? - BMW Luxury Touring Community
 4Likes
  • 1 Post By gary45
  • 2 Post By gary45
  • 1 Post By BecketMa
post #1 of 9 Old Jun 12th, 2015, 9:51 am Thread Starter
BecketMa's Avatar
Before I start putting her back together from my initiation into the LT slave cylinder, clutch, engine seal replacement, is the clutch supposed to spin freely after assembly?
I've got the trany reinstalled but want to verify if the clutch should spin freely before I start reattaching everything and lowering the frame.
Best from T'son
BecketMa is offline
post #2 of 9 Old Jun 12th, 2015, 10:12 am
Patric's Avatar
Re: clutch plate supposed to spin freely?
I think that unless you are engaging the clutch, no it should not turn freely. Is it posable the spring is in backwards?... But what do I know..
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #3 of 9 Old Jun 12th, 2015, 11:43 am
Best from T'son
Bob,
I fear that I may be joining the club also. What were your initial symptoms that first made you notice you had a problem? I'm pretty good at tearing down stuff, but I don't think I could rebuild an engine. Did you find a lot of fluid leaking from the slave, and were you able to save most of the clutch? I have both the well written instructions as well as the 3 videos on drilling the weep hole.
Thanks!
Mark
Markwk is offline
post #4 of 9 Old Jun 12th, 2015, 3:30 pm
Best from T'son
If you are turning output shaft of installed transmission it should only rotate if you are in neutral, if in a gear should not rotate much
Patric likes this.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 9 Old Jun 12th, 2015, 4:04 pm Thread Starter
BecketMa's Avatar
I was turning the clutch plate once I had bolted the assembly together before reinstalling the trany.
BecketMa is offline
post #6 of 9 Old Jun 12th, 2015, 4:24 pm
bmwcoolk1200's Avatar
check post #6 on another thread for the proper assy and order of things in the clutch to make sure you didn't get some things on in the wrong order.
http://www.bmwlt.com/forums/k1200lt/...t-too-far.html
It is possible you switched the position of some of the components like the spacer ring as mentioned in that thread.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #7 of 9 Old Jun 12th, 2015, 4:32 pm
The disk should not rotate in the carrier, you have to push on the spot the clutch rod would push on in order to rotate disk once assy put back together, you have a problem
Zeke and Patric like this.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #8 of 9 Old Jun 14th, 2015, 5:37 pm Thread Starter
BecketMa's Avatar
WeeeelllWelooks, looks as if I installed the spring backwards?? It looked nice and symmetrical when I installed it.
Time to fabricate a centering pin for when I reinstall it.
have to work on it just before sunrise around 4:30AM now, the coolest part of our 100F plus days.
Patric likes this.
BecketMa is offline
post #9 of 9 Old Jun 14th, 2015, 10:07 pm
Yup domed side facing to the rear of the bike and don't forget the spacer ring between it and the housing.
And it should look like this when you are done.
ID:	82362   Click image for larger version
Siebenrock Clutch failure kclineman10 K1200LT 19 Sep 7th, 2012 9:39 am
clutch slave operational function tenrocky K1200LT 28 Oct 9th, 2011 3:43 pm
Clutch adjustment luis K1200LT 10 Sep 5th, 2010 12:08 pm
What's worse then a slipping clutch on a 2005 LT? smithbs K1200LT 6 Apr 22nd, 2009 11:19 am
Sintered clutch plate bikesnumbnuts K1200LT 4 Nov 14th, 2006 3:32 pm
