Newbie - BMW Luxury Touring Community
post #1 of 4 Old Jun 12th, 2015, 7:38 am Thread Starter
Newbie
Hi guys, I have the chance to buy a 1999 K1200 LT with 45k on it (is that a lot of miles for one of these bikes?) and was wondering what faults I should be looking out for.
I'm new to the K1200 LT so any help would be very much appreciated...... Thanks
Rab-33 is offline
post #2 of 4 Old Jun 12th, 2015, 8:35 am
Re: Newbie
Like most vehicles, it all depends on the maintenance. A well-maintained LT with 45K miles is barely broke in. One that wasn't maintained, annual ABS flushes in particular, might be a very expensive "bargain" priced bike.
There may be a list of areas to check if you search the site, but I am not aware of one right off-hand.
A few that come to mind and which are expensive are:
1. ABS that hasn't had annual wheel circuit flushes or is showing fault lights. My 07 has a different system than the 99 and I am not familiar with the latter, but mine will flash the brake failure light until I ride a few feet to trigger the self-test. However, if you hit 10 MPH and still have fault lights flashing, you probably have trouble.
2. Slipping clutch. Go out and whack the throttle wide open in 5th gear. If the relationship between RPM and speed isn't linear, then you have an expensive clutch (worn disk, weak spring, oil or slave cylinder leak) problem.
3. Check the trunk latch for cracks at the corners where the actuating arms are.
4. Check the final drive and swing arm boots for leaks and check for play in the rear wheel.
These are some particular areas for the LT, but obviously you need to do the normal checks for any vehicle. Tires, brakes, controls (including cruise control operation), lights, general condition, tightness of fasteners, leaks anywhere under the engine or transmission, maintenance records, any crash or damage history, etc.
post #3 of 4 Old Jun 12th, 2015, 9:01 am
Re: Newbie
99 has ABS only and if it fails loss of ABS but NO effect on braking, warning lights will probably stay on when self test fails, you can drive without ABS, not all bikes have that feature.
I would add look at bottom of motor where transmission motor meet and see if seam has any evidence of leaking oil.
Check rear wheel for play vertically and horizontally, rotate wheel through a couple of revolutions listening for scraping - before I bought mine I looked at a newer one, drove OK low speed but was looking for date stamp on tire and while revolving wheel heard noise and saw movement at rear drive pivot, bad u joint, rare.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 4 Old Jun 12th, 2015, 9:33 am Thread Starter
Looks like I'm going to be busy at the dealers tomorrow... Lol
Thanks guys, much appreciated.
Rab-33 is offline
Newbie Biker Going to Texas RonHolly K1200LT 34 Jun 5th, 2012 2:09 pm
UK Newbie Panman-Chips K1200LT 4 Apr 17th, 2011 4:07 pm
Newbie Here Davidtn57 K1200LT 14 Jul 15th, 2010 9:39 am
Brand new RT newbie RTrev RT Series 26 Apr 24th, 2008 8:09 pm
Newbie looking for info Bear-KLT K1200LT 12 Dec 2nd, 2007 11:34 am
