Oil Change, Skid Plate Torque Needed - BMW Luxury Touring Community
post #1 of 9 Old Jun 10th, 2015, 11:55 pm Thread Starter
Hi All,
I performed the 30k oil change.
Does anyone know the torque rating for the skid plate?
It has 2 allen head screws and 2 nuts
The plate I am referring to is a piece of sheet metal and is for my 2005.
ehaughn is offline
post #2 of 9 Old Jun 11th, 2015, 2:01 am
Re: Oil Change, Skid Plate Torque Needed
According to Clymers, clean bolt threads then as follows.
Apply Loctite 242 and tighten the engine guard 8mm bolts to 21 N*m (15.5ftlbs)
Apply Loctite 242 and tighten the engine guard 10mm bolts to 41 N*m (30ftlbs)
BMWMOA
Never ride faster than your Guardian Angel can fly
2007 K1200LT Storm Grey metallic
Uni Go Trailer
Chayside is offline
post #3 of 9 Old Jun 11th, 2015, 9:43 am Thread Starter
See url, BMWSTEELART.COM K589 (K 1200 RS, K 1200 LT)_ K 1200 LT 04 (0549,0559)_ USA_ 46 Frame and mounting parts_ 46_0831 Underride protection
For item #9 , I am looking for torque for #10 and #11 .
ehaughn is offline
post #4 of 9 Old Jun 11th, 2015, 10:46 am
hallzee's Avatar
The Holy Grail of LT Torque specs. There are TWO Tabs, pretty much everything on the bike is here.
Another Forum Member made this years ago, and posted here.
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #5 of 9 Old Jun 11th, 2015, 11:38 am Thread Starter
Thank you, this is a very useful spreadsheet.
ehaughn is offline
post #6 of 9 Old Jun 11th, 2015, 3:58 pm
Are you sure these are for the skid plate? The torque values sound very high!
I just snug the fasteners by hand. The two nuts on the rear are self-locking on my 2007 so just snug them with a combination wrench and you are good. No need for loctite on a self-locking nut!
And the front I just snug down also, no need for high torque on these.
post #7 of 9 Old Jun 11th, 2015, 7:46 pm
The metal skid plate that comes off the skid frame is held by two 5 mm Allens at the front (9 Nm is good enough but snug will work here as well) and the two 10 mm nuts should be self locking so just snug. The manuals does not cover a torque value for this item.
post #8 of 9 Old Jun 11th, 2015, 8:08 pm
Voyager, Clymers page 549, picture 60 section 17. I agree 110% with your reply but I was just answering the guys question. Some people get to hung up on torquing bolts. During my days a s a mechanic for well over thirty years if I had torqued every single bolt I am sure I would still be rebuilding crap today.
BMWMOA
Uni Go Trailer
Chayside is offline
post #9 of 9 Old Jun 11th, 2015, 10:42 pm
I just looked at the Clymer manual and I believe you are misreading it. The manual refers to the engine guard mounting bracket bolts, not the bolts and nuts that attach the engine guard to the engine guard mounting bracket!
And the last sentence of paragraph 2 specifically says NOT to remove the bolts that secure the engine guard to the mounting bracket. I believe in this case it is not necessary since the complete assembly is being removed. However, for an oil change, as is the case in this thread, only the guard itself needs to be removed (small bolts and nuts), not the guard mounting bracket which is affixed with the much larger bolts mentioned in the manual.
Bosch 72161 oil filter WARNING! kellenbenz K1200LT 29 Feb 20th, 2018 10:00 am
RT Gearbox oil change BigKev RT Series 9 Sep 5th, 2013 4:56 pm
First Oil Change FuzzyWuzHe K1200LT 6 Jul 8th, 2012 11:05 pm
Oil change question--removed the access door and whoosh... petevandyke K1200LT 12 Oct 12th, 2010 5:11 pm
Urgent advice needed regarding oil change Radu K1200LT 7 Sep 13th, 2009 12:32 pm
