How to connect Zumo 660 to power - BMW Luxury Touring Community
post #1 of 10 Old Jun 10th, 2015, 11:00 am Thread Starter
Since last Friday I'm the proud owner of a 2005 K1200LT (US version)
Because on my previous bike I was using a Zumo 660 I intend to keep using that. For this is the best navigation device. Used TomTom Rider before, but never original BMW nav.
Only thing I'm pretty interested in the the electrical connection of the Zumo.
I'm looking for the best way to connect it to the battery.
any suggestions? Any installation instructions?
Frenske (from the Netherlands)
Frenske2002 is offline
post #2 of 10 Old Jun 10th, 2015, 6:05 pm
JNW003's Avatar
Re: How to connect Zumo 660 to power
Congratulations on your new-to-you ride! I added a fuse block to my bike that has switched and unswitched sides that provides flexibility on installing new devices. My '07 originally came with a Nav III system that I removed and installed a Garmin 590LM. The fuse block provides power to the new GPS.
Click on the "Forums" link in the blue toolbar above and drop down and click on the "GPS" thread. You should find a variety of good info that should meet your needs.
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #3 of 10 Old Jun 10th, 2015, 7:18 pm
If you really want to get crazy wire it into Fuse F16 (that is hat I did). That was for an optional accessory and was not hooked to any wire in my US bike. It is a 4 amp and I believe it was for the factory GPS option anyway. But barring that a fuse box accessory is that best option that way you can control the fusing and whether it is switched power or hot all the time.
post #4 of 10 Old Jun 11th, 2015, 2:23 am
+1 on the FuzeBlock. I have a Garmon550 it had an inline fuse (2amp) direct to battery. It was live all the time. Now it's switched through the FuzeBlock.
FUZEBLOCKS.COM
BMWMOA
Never ride faster than your Guardian Angel can fly
2007 K1200LT Storm Grey metallic
Uni Go Trailer
Chayside is offline
post #5 of 10 Old Jun 11th, 2015, 9:26 pm
CR125Honda's Avatar
I modded my 03 with an electric center stand and needed a hook up.
This was my solution.
Can't remember if I got it at radio shack or online. $8 as I recall.
Mounted on top of the battery case with a couple zip ties.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Couple Mini Trail's QA' & CT's
CR125Honda is offline
post #6 of 10 Old Jun 11th, 2015, 11:54 pm
75 AMPs? You have inbuilt welding machine ?
Born to be wild so why not
C-A-D is offline
post #7 of 10 Old Jun 12th, 2015, 12:51 am
CR125Honda's Avatar
It powers the air conditioner!
It's a 7.5 amp fuse.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
post #8 of 10 Old Jun 12th, 2015, 2:54 am
I thought so, but couldn't resist - the dot is pretty well hidden.
C-A-D is offline
post #9 of 10 Old Jun 12th, 2015, 9:11 am Thread Starter
Guys,
Thanks for your replies.
I connected it directly to the battery this morning. Working great
Frenske
post #10 of 10 Old Jun 13th, 2015, 7:42 am
newguy's Avatar
I connected the red wire (hot) to the front turn signal wire. You will have to determine which one is hot when the key is on. Ran ground to negative side of terminal. GPS comes on when bike is started and off when bike is shut down.
newguy is offline
ZUMO 660 wiring RT-Ron 1200 RT Series 7 May 22nd, 2014 2:47 pm
Garmin 550 next to BMW Zumo Oldmanwheeler GPS 23 Jan 1st, 2012 11:05 pm
Zumo mount on BMW k1200 lt Keithb GPS 48 Apr 29th, 2010 12:15 am
Zumo 550 SOLVED! rdog GPS 0 Jul 5th, 2008 6:14 pm
Autocom, Zumo, Radar, iPod, Stereo project... mrbiker Intercom, CB, & 2-Way Radios 0 Feb 20th, 2008 11:48 pm
