Clutch disengaged, rod at slave sticking out too far - BMW Luxury Touring Community
 2Likes
  • 1 Post By sailor
  • 1 Post By jzeiler
post #1 of 6 Old Jun 9th, 2015, 11:33 am Thread Starter
westvandude's Avatar
As if I don't have enough issues already with my K1200LT.
Get the motor in and oil leak on cam tensioner bolt, etc.
Anyway, so I go to put it in 1st gear so I can torque the lug nuts on the rear wheel and I got no friction. Wheel just spins.
I recall the clutch release push rod sticking out a bit far but I did manage to bolt down the slave cylinder while pushing it in at the same time.
Now goddamn clutch is disengaged all the time. Had no issues mating up the trans input shaft to the new clutch disc, used the clutch push rod and a socket to align everything.
So this means I gotta pull the stupid rear swing arm AGAIN and look in the clutch release rod hole.
This thing is driving me nuts. What is seemingly a used engine replacement has gone into days and days and wknds and wknds of work. Sick of it.
Good thing I didn't put the exhaust on yet. Sheesh.
Anyone else know how far that stupid push rod is supposed to stick out/into the slave cylinder bore to be correct?
Didn't drill the weep hole yet either I suppose I should do that as well.
westvandude is offline
post #2 of 6 Old Jun 9th, 2015, 12:03 pm
bmwcoolk1200's Avatar
Re: Clutch disengaged, rod at slave sticking out too far
If you haven't watched the Northern IL maintenance videos, you might be able to see what you need on their clutch replacement video.
BMW K1200LT Clutch and Seal Replacement
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #3 of 6 Old Jun 9th, 2015, 3:43 pm Thread Starter
I just put a new clutch disc in it when I swapped motors. Somehow the rod isn't engaging the hole in the centre of the spring plate.
post #4 of 6 Old Jun 9th, 2015, 4:22 pm
sailor's Avatar
Assuming all the clutch parts are in place, there can be 2 causes:
1) clutch friction plate is not correct thickness range (too thin). The MIN specs for material thickness is: 4.6 mm (0.181 inch). Although it seems counter-intuitive, the design is such that a thinner friction plate will cause the push-rod to stick out further. This is documented in a long thread with photos here:
http://www.bmwlt.com/forums/k1200lt/...tch-slips.html
2) OR... the friction plate has been installed backward - the ridge with splines must point toward transmission. This problem is discussed in same thread above - in fact the whole thread was started by someone having a problem like yours.
Patric likes this.
John (Montreal, CANADA)
sailor is offline
post #5 of 6 Old Jun 9th, 2015, 7:17 pm Thread Starter
Goddamn.... I hope the trans doesn't have to come off again. I'll strip the rear end off pull slave/rod and take a look down the hole. I'm pretty good with remembering how things go together... pretty ret*rded if I put pressure plate on backwards.
I got the clutch disc from beemerboneyard.com great guys. Also new synth engine/gear oil for trans/FD.
post #6 of 6 Old Jun 10th, 2015, 7:53 pm
It is normal for the rod to be out much farther with a new clutch than it was when you pulled it out on the old clutch. In fact you have to compress the slave a tiny bit just to get the screws started. You did put it in the right way around? That could cause the issue but I would think you could not get the slave up far enough to even engage the screws. Also I hope you did put the ring spacer (no. 2 ) between the housing and the clutch spring. If not there will not be enough pressure to engage the clutch.
ID:	82130   Click image for larger version
Patric likes this.
Can the clutch slave cylinder be rebuilt ? Tomk1200lt K1200LT 12 Jan 7th, 2011 7:49 am
2nd clutch slave cylinder in 4800 miles? Tomk1200lt K1200LT 11 Jan 5th, 2011 6:47 am
Back on an LT after 3 years - clutch slave cyl question Bueller K1200LT 5 May 24th, 2009 8:58 pm
Clutch lever sticking ronnieds K1200LT 3 May 12th, 2009 10:29 pm
