Swirl in Gas Tank - BMW Luxury Touring Community
 2Likes
  • 1 Post By Scouter-50
  • 1 Post By beemer100
post #1 of 13 Old Jun 7th, 2015, 9:51 pm Thread Starter
beemer100's Avatar
Swirl in Gas Tank
I have replaced the in-tank fuel hoses with OEM hoses when I changed out the fuel filter and now I am having an issue with low power and a swirl in gas tank when ignition on. I took the tank back off thinking that the worm clamps might have give -way but they were fine. I went ahead and replaced them with FI clamps to see if it would make a difference. No change. The gas is probably about 5 months old.
I do have the QD clamps under the tank if that makes any difference.
I inspected the hoses and couldn't see any noticeable splits, etc.
Any thoughts?
I have scoured the site but couldn't find a whole lot on this issue.
Thanks. james
James Hart
2002 LTE Titan Silver
1992 Yamaha Virago 750 (given to friend)
River Oaks, TX
beemer100 is offline
post #2 of 13 Old Jun 8th, 2015, 12:20 am
Axle's Avatar
Re: Swirl in Gas Tank
sounds like a leak is still there, maybe you have a split in the filter, have you got the q'd hoses on the correct way, don't now what else it could be
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 13 Old Jun 8th, 2015, 9:38 am Thread Starter
beemer100's Avatar
I spoke to another BMW shop who indicated that the fuel pump has a return line and that it is normal to see a swirling action of sort in the tank due to the return line when ignition is on.
If that is correct, I am hunting a problem down that does not exist.
James Hart
River Oaks, TX
post #4 of 13 Old Jun 8th, 2015, 11:24 am
Scouter-50's Avatar
Do you see the swirling when the key is on and the bike not running?
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #5 of 13 Old Jun 8th, 2015, 11:34 am Thread Starter
beemer100's Avatar
Robert
Yes
James Hart
River Oaks, TX
post #6 of 13 Old Jun 8th, 2015, 12:58 pm
Scouter-50's Avatar
Yes
You should not see any movement of fuel when the pump runs. Try lowering the fuel level enough to uncover the hoses to see if they are spraying out from somewhere. On my bike the short straight(er) piece had a 1/8" split above the clamp. Bike would miss at higher RPMs.
Robert
Patric likes this.
1981 R80GS
1976 R90S
post #7 of 13 Old Jun 8th, 2015, 1:26 pm Thread Starter
beemer100's Avatar
Robert
Thanks Robert. I'll try that and see if I can tell if its one of the hoses. The problem I am having is that I put on brand new OEM hoses. The old hoses were working fine.
I may need to go back to the old theory . . . if it aint broke, don't fix it. . .
James
Patric likes this.
James Hart
River Oaks, TX
post #8 of 13 Old Jun 8th, 2015, 4:13 pm
Is it gas with alcohol init, if so 5 months is a long time to have it sitting around, maybe try some fresh fuel, just a thought
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #9 of 13 Old Jun 8th, 2015, 4:31 pm
deanwoolsey's Avatar
Swirl in the tank generally comes from one of two places, either a leak in the supply side or from the return line if the pump is running. A small amount of swirl or movement is normal when the rail charges prior to the start of the engine. If it runs normally, everything is probably fine. If it started running poorly when you changed out the filter, etc. then something is likely amiss.
deanwoolsey is offline
post #10 of 13 Old Jun 8th, 2015, 6:55 pm Thread Starter
beemer100's Avatar
Dean, I would consider it a small amount of swirl, but I am not a "Swirl Expert" : ). It did start running poorly after the filter change (24k service). One thing I did notice odd as wel is that the mpg was in the dumper (ie 7 mpg upon starting out and it then gradually went up to about 25 I believe). I would think this has something to do with the computer on the bike.
Thanks all for your advice and suggestions.
James
James Hart
River Oaks, TX
post #11 of 13 Old Jun 9th, 2015, 12:11 pm
Something is wrong with that mileage. I would personally say that anything below 40 is very suspect, particularly if that's highway miles.
post #12 of 13 Old Jun 10th, 2015, 8:00 pm
I get 28 MPG going 75 MPH in a head wind pulling my Bushtec trailer. Normally about 38 with the trailer and 42 without. I do get 50 in the Rockies. 2005 over the last 11 years.
post #13 of 13 Old Jun 10th, 2015, 10:00 pm
fatbob307's Avatar
James
Have you reset the motronic using the method described on this forum?
Bob Lower
Casper, WY
'01 K1200LT
'03 R1150 RT
'13 R1200GS
'79 R100T w/Hack
'10 Triumph Thunderbird
'09 Triumph Bonneville
'07 Guzzi Norge
'88 HD FLHS
fatbob307 is offline
K1600GT-L Tank Bag old1951 K1600GT/GTL 7 Dec 12th, 2011 1:53 pm
Started B4 I took the tank off, not now tho? BecketMa K1200LT 2 Aug 14th, 2011 3:35 pm
Gas tank vacumn and BC mileage output. Gene_Chapman K1200LT 5 Mar 9th, 2008 4:53 pm
RECALL: Oil Tank Ventilation eljeffe K1200/1300GT (The Next Generation) 2 Feb 9th, 2007 10:47 pm
