Whine that's not the final drive - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 15 Old Jun 7th, 2015, 8:58 pm Thread Starter
rowie's Avatar
Hi there. Not sure what this is so thought I'd ask. I get a whine when riding that increases in pitch as speed increases, but if you pull in the clutch the whine immediately disappears. It sounds like it's coming from under my knees but of course it's hard to tell. If I was guessing I'd say gearbox.
Is this the flying brick whine of straight cut gears and therefore normal or is something more sinister happening? I know these things are often hard to trace. And no, there's no oil of any form anywhere that it shouldn't be, and I have drilled the weep hole about 4 years ago and all is clear.
Thanks guys!
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #2 of 15 Old Jun 7th, 2015, 9:41 pm
Re: Whine that's not the final drive
I hate to say it but that is what a failing front input shaft bearing on the transmission sounds like. Maybe Patric will chime in as that is what I replaced for him.
post #3 of 15 Old Jun 7th, 2015, 10:49 pm
Axle's Avatar
+1 on the bearing
k whine is just that an annoying whine, mine starts at 97kph and goes through to 104kph and its gone. if you hear it as soon as you take off do not ride it get it trailered back home. I have just had this happen, I kept riding and did a hell of a lot of damage, that bearing cost about 30 bucks, my repair bill was well over 1k and did the repair myself
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is online now
post #4 of 15 Old Jun 8th, 2015, 7:31 pm Thread Starter
rowie's Avatar
I'lI check on the speeds I hear it.
If it is the transmission input shift bearing, ouch - the bike only has 28k miles on it....
BMWMOA member
Current rides:
Prior rides:
rowie is offline
post #5 of 15 Old Jun 8th, 2015, 8:48 pm
Other than removing the transmission it is a fairly easy fix if caught before it does damage to the input shaft.
post #6 of 15 Old Jun 8th, 2015, 11:14 pm
Cat Herder
tvguy's Avatar
Flashbacks of my 1980's vintage Toyota making the same sound... The quarter size bearing was a PITA to remove because it was rusted in... The HORROR...
Good news... put some Liquid Wrench on it... went to Hawaii for three days... popped right out!!!
Tvguy
'16 R1200RT - "Golden Eye"
tvguy is offline
post #7 of 15 Old Jun 9th, 2015, 7:54 am
14wntr's Avatar
+2 on the bearing. Mine went out at an early age as well. I have some videos covering the discovery and replacement if that is what it turns out to be. I think my total bill including the seals, clutch, rear main and slave were under $500. 25k later it is still running great!
The flat cut gear noise usually happens around 60mph. The input shaft will make noise a lot more than that!
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #8 of 15 Old Jun 18th, 2015, 9:41 pm Thread Starter
rowie's Avatar
Hmmm - this one's gonna take a while to fix because I have a job change and as a result a house move coming (8th house move in 22 years covering 3 countries - an avg 2.75 years per house). At least we're moving somewhere warmer (Raleigh/Durham area). But the move probably means not alot of riding for a while.
John, did you do the whole thing for Patric or did he send the transmission and you worked on that? If it was the whole thing, could you PM me with an idea of the cost (rough is fine)? I just know I'm gonna be tight on time to do this for a while so looking at options.
Thanks guys.
BMWMOA member
Current rides:
Prior rides:
rowie is offline
post #9 of 15 Old Jun 20th, 2015, 10:53 am
Patric's Avatar
Hi rowie John & all , sorry, I am a little late on this thread . our K1200LT rig has eaten two front input shaft bearings. First time the clutch started to slip a little at around 30,000 miles, so I took it apart. original transmission had a leaking input shaft seal , The shaft felt OK..it didn't move, so I just changed the seal, clutch& spring, slave cylinder.. and put it back together. Around two years later, I was 100 miles from home & the clutch started slipping. When I stopped there was gear oil on the center stand... not good. I thought it would make it home, but no.. it ate the input shaft bearing & part of the gear that drives the intermediate shaft, & the spring torsion came apart so the drive gear got ate & it lost all drive. I put in a used E-bay transmission that had 100,000 + miles one it & the bike had been in a fire. It lasted a few years & it started to squeal when we started to take off. I took it apart thinking it was the slave cylinder piston spinning in the boar , but That input bearing was bad & I could move the shaft. John helped me out big time, & rebuilt that transmission for me.
Other that the squealing like a belt or power steering squealing I don't remember any sounds.. but that might be from working in a factory for 31 years.
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #10 of 15 Old Aug 22nd, 2015, 8:23 pm Thread Starter
rowie's Avatar
Sorry to take a while to get back to this thread. I've started my new job in Raleigh-Durham but not moved yet (commuting / apartment living - I'm missing the summer unfortunately). Thanks to all for your feedback - I'll look at options once I move which will probably be in about 3 months time.
And this is the first time I logged back on to the site in 2 months - holy cow, what happened to the site!
Thanks again and ride safe.
BMWMOA member
Current rides:
Prior rides:
rowie is offline
post #11 of 15 Old Jul 12th, 2017, 3:23 pm
westvandude's Avatar
Mine now has this problem....darn new problems just keep coming up. Starting to tick me off. Oh well, I'm well versed at trans re&re.
Anyone have an online source for the input shaft seal and bearing? Is there also an output shaft bearing/seal that fails to replace or leave that alone?
westvandude is offline
post #12 of 15 Old Jul 12th, 2017, 4:11 pm
bmwcoolk1200's Avatar
I've gotten seals from Amazon although they are Buna and not Viton
Input shaft seal
https://www.amazon.com/20x32x8-Rubbe...s=seal+20x32x8
Output shaft seal. Set depth is critical due to an oil hole just inside the seal lip. Too deep and gushes.
https://www.amazon.com/25x40x6-Rubbe...s=seal+25x40x6
Slave seal but I would get the OEM Viton from the dealer due to possibility of brake fluid exposure. depth also critical.
https://www.amazon.com/17x28x7-Rubbe...s=seal+17x28x7
Nachi bearing
https://www.amazon.com/6204-2NSE-Bea...aring+20x47x14
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #13 of 15 Old Jul 12th, 2017, 7:31 pm
I always use OEM except for the output shaft seal I found a better one that is two lipped and only 1 mm thicker. I just replaced my input shaft bearing and seal now it is smooth and quiet.
ID:	128929   Click image for larger version
Patric likes this.
post #14 of 15 Old Jul 12th, 2017, 8:02 pm
Just for the record, the seals I have listed from Amazon are all double lip seals with garter springs.
If you have trouble swallowing the cost of the OEM, they are not a bad option but the orange OEM seals are made of Viton and as John said, are better and will hold up under the higher temps in the clutch cavity but 4 times the cost. You can go cheap if you want to though but you may get a few less years out of them overall.
Gordon
Sugar Hill, GA
post #15 of 15 Old Jul 14th, 2017, 11:35 am
Thanks for part #'s. I'm still couple hundred miles from home. Cross fingers!
K1200LT Drive Shaft / Final Drive Leak fredtman K1200LT 14 Aug 17th, 2015 2:20 pm
R1200RT final drive fluid experience erikrichard RT Series 17 Dec 21st, 2014 6:18 pm
What to do with a "used" FD jers99lt K1200LT 23 Dec 9th, 2011 11:31 am
RT final drive available CharlieVT RT Series 6 Oct 30th, 2008 3:55 pm
