ABS unit - BMW Luxury Touring Community
 2Likes
  • 1 Post By C-A-D
  • 1 Post By 14wntr
post #1 of 11 Old Jun 7th, 2015, 4:42 am Thread Starter
ABS unit
Hi. I am sure this has been around the block already but .....
I have issue with my ABS unit. The winding sound, when using the front brake, has the sound of shocking! gasping....and of course i only have the residual brakes left.... The red warning light stay on, while the ABS light flashes rapidly.
Is there any thing i can do? is the ABS pump going bad? any thing that i can do... Would replacing the brake fluid help? is there dirt in the system that prevent it from working properly?
Any suggestions on what I could do...Is there a place that can rebuild these units if need be? Thank you for any help!
jeannot is offline
post #2 of 11 Old Jun 8th, 2015, 8:23 am
Re: ABS unit
Some of the symptoms you report will result from low reservoir fluid levels. The first thing I suggest you do is check and top-up all reservoirs on the bike especially the small one in the right rear hidden under the bright metal panel to which the right side passenger foot peg is attached. A brake fluid change should only be considered as a last resort. It is difficult to bleed the system completely and properly even for a dealer. This is not at all a weekend backyard mechanic repair. It is one for an experienced, BMW trained master technician. If the ABS modulator pump gets damaged or has anything wrong other than a faulty circuit board, replacement may be required, and that will be very expensive remedy: ABS pump replacement on my '03 LT totaled $2600 a few years ago.
microdoc is offline
post #3 of 11 Old Jun 8th, 2015, 10:08 am
Re: ABS unit
Originally Posted by microdoc View Post
...A brake fluid change should only be considered as a last resort. It is difficult to bleed the system completely and properly even for a dealer. This is not at all a weekend backyard mechanic repair. It is one for an experienced, BMW trained master technician....
What?! Never heard that before - especially on this forum Here "everybody" are doing their own fluid changes...
johnbaker15 likes this.
Born to be wild so why not
C-A-D is offline
post #4 of 11 Old Jun 8th, 2015, 8:56 pm
Re: ABS unit
There are a few things that can cause your symptoms that are not a failure of the system. Number one is a weak battery, starts OK but gets really low terminal voltage after the start. Load test will tell the true story on that. Fluid flushes are quite easy if you follow some simple tests, Bleeding after air gets into the system is just a tad bit harder. A fluid flush can't hurt but it will most likely not fix a failure. Best to get a readout of the fault code from a dealer or some one with a GS-911 unit then go from there.
post #5 of 11 Old Jun 8th, 2015, 10:50 pm
Re: ABS unit
what year is your bike.
If it's pre 2005 ( I think that is correct ) then Module Masters can most likely repair for comparatively little.
If it has I-ABS of the later bikes, and the abs has indeed failed, you are in for one expensive trip.
Module Masters can't deal with the I-ABS.
Hoodcounty is offline
post #6 of 11 Old Jun 8th, 2015, 11:02 pm Thread Starter
Re: ABS unit
Thank you for the good words. yes it is a 2003, so i should be in that category of reparable....
I still need to check the battery and check voltage and amps, but it runs ok. The battery is 3 plus years.....
so if i do need to remove and have it fixed, do you know of a place that can/would do it?
Thank you for your infos and advices.
jeannot is offline
post #7 of 11 Old Jun 8th, 2015, 11:43 pm
Re: ABS unit
Wasn't it so that ABS2 is considered to be repairable and the later servo-equipped systems perhaps not? If so the change happened already 2001 - not with the "facelift".
C-A-D is offline
post #8 of 11 Old Jun 9th, 2015, 7:54 am
Re: ABS unit
The knowledgeable here can correct any errors here ( please!)
The I-ABS was 2005 onward if I recall correctly. Pre integrated abs the units can be repaired according to the folks I spoke with at Module Master.
Mine was SOL. No parts available, and no one willing to make the parts.
I sold my 2006 bike for parts a couple weeks ago due to the unwarranted expense of replacing the failed I-ABS unit..
post #9 of 11 Old Jun 9th, 2015, 8:11 am
14wntr's Avatar
Re: ABS unit
Seriously? Are you talking about an LT? Where do you come up with this idea that only an master tech should change brake fluid? I change my fluids at least once every year. Why dont you watch the videos I did on doing just that and start saving yourself BIG $$$! PS. I am NOT a master tech. I am just a guy who does not like to get hosed every time I go into a shop.
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #10 of 11 Old Jun 9th, 2015, 8:18 am
Re: ABS unit
You can check this way:
Motorcycle ABS Modules | Product Categories | ModuleMaster
Or put the bike in here:
Motor Sports | ModuleMaster
Check the LT years at the bottom of the list.
http://modulemaster.com/rebuilds/sho.../abs-fte-abs3/
04 K1200LT, 05 F650GS
Enduro is offline
post #11 of 11 Old Jun 11th, 2015, 10:03 am
whtmtn2000's Avatar
And if you cannot repair or wish to replace your Integral ABS system you can remove this system from this perfectly good motorcycle.
There are a few that have done it. I just completed the project myself. Mine is an 02 that looks brand new. Still though 2300.00.....ahhhhhh...no.
Brakes feel excellent... As good as my buddies 2014 Non ABS Goldwing.
ABS is great but should not cause anyone to part out their bike.
whtmtn2000 is offline
ABS unit questions on 2001 dinocarsfast K1200LT 4 Sep 23rd, 2013 12:16 pm
ABS unit gone again plonk K1200LT 9 Jun 17th, 2011 5:06 am
Chevy Astro ABS unit help needed! pozo_izquierdo Chit Chat 4 Apr 19th, 2010 4:26 pm
