Clutch issue on 1999 LT/30k miles - BMW Luxury Touring Community
post #1 of 5 Old Jun 6th, 2015, 4:56 pm Thread Starter
In the last week I noticed that even when pulling the clutch lever all the way in, that shifting gears was getting more difficult. I would have to either double clutch and then shift, or really jump on the gear shifter to change gears. Today when making a stop and holding the clutch in, the bike started stalling out, but when I got it into neutral it was fine. So my guess is that the clutch is not totally disengaging, which makes the shifting difficult and causing it to stall out if I'm in gear but holding the clutch lever in at a stop. I'm hoping there is adjustment for this and not a major overhaul. It does not slip while in gear. The clutch has 30k miles on it. Thanks for any advice.
Markwk is offline
post #2 of 5 Old Jun 6th, 2015, 5:55 pm
Re: Clutch issue on 1999 LT/30k miles
Have you checked the fluid level in the clutch master cylinder? If it is really low, you may have a leak in the slave cylinder or hose to it.
Voyager is online now
post #3 of 5 Old Jun 6th, 2015, 8:22 pm
Axle's Avatar
there is no adjustment, as above then bleed the clutch system
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #4 of 5 Old Jun 7th, 2015, 3:33 am
If the clutch slave is leaking, fix it immediately. If it leaks, it leaks internally and it is just matter of time brake fluid ending up to clutch and causing massive clutch overhaul. Do a search with "Weep hole" and "clutch". You will get a lot of info of what might happen.
Recommend immediate looking into the slave cylinder condition. Unfortunately requires dismantling the swing arm.
Born to be wild so why not
C-A-D is offline
post #5 of 5 Old Jun 7th, 2015, 5:59 pm
silverlt2002's Avatar
Very similar to how mine acted before the slave cylinder went. Not at all fun driving it back home without a clutch when it finally failed completely in morning traffic. Definitely good advice to stop riding and check it. First would be to bleed the slave but if that doesn't work (and it probably won't for more than a couple of pulls), you can be pretty sure it is the slave leaking. You want this fixed before it ruins the clutch as stated by an earlier post, and becomes a much more expensive repair. This is a common issue given your year and mileage. Sometimes they last forever on a bike that is used all the time and sometimes they fail on a bike that isn't used much like yours and at the time mine.
Steve Green
US Army (Ret)
2002 KLT
Titan Silver
silverlt2002 is online now
2nd clutch slave cylinder in 4800 miles? Tomk1200lt K1200LT 11 Jan 5th, 2011 6:47 am
RT Clutch Adjustment Nebish RT Series 17 Apr 1st, 2009 10:51 am
4th Clutch in 33K Miles markmoloney K1200LT 28 Aug 16th, 2008 8:42 am
Clutch issue dlbushey K1200LT 21 Aug 31st, 2006 12:46 am
