sucking gas cap - BMW Luxury Touring Community
 1Likes
  • 1 Post By ChiefMn
post #1 of 4 Old Jun 5th, 2015, 7:25 pm Thread Starter
ChiefMn's Avatar
sucking gas cap
I'm on a road trip with a new to me 2004 k1200lt.When I stopped for gas it made a sucking noise when I losened the gas cap.Found a a cut line under the seat and think someone botched a canisterectomy.Anyone know how the gas tank vents and if I have to pull all the tupperware to get to it?
Jeff Bokusky
Shoreview ,Mn.
2001 K1200LT ---
1973 Harley FLH 96 c.i.
1948 Harley EL 88 c.i.
1985 kawasaki KX250
1993 honda XR 200--
1978 Triumph Bonneville
ChiefMn is offline
post #2 of 4 Old Jun 5th, 2015, 8:01 pm
JNW003's Avatar
Re: sucking gas cap
There are two lines you need be concerned with and they both run under the seat with easy access. The one on the right side is the gas tank vent that just needs to be rerouted down to the ground, while the one on the left is the return line that needs to be plugged leading back to the engine. I did both while on a long distance trip last year and left the canister underneath the topcase for removal at a later point that I haven't gotten to yet. Be sure that the tank doesn't continue to suck after you have done this, as the problem could be a pinched vent line (between the incorrectly reinstalled right upper tupperware and the tank - don't ask me how I know, but it collapsed my tank, ending up with a dent in the fuel level float tube and erroneous fuel level readings...). Good luck, it's an easy fix on the road!
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #3 of 4 Old Jun 5th, 2015, 8:05 pm
Re: sucking gas cap
Reach up under the nose above the fender on the right side. Find the nose frame tubing. There will be a junction for two hoses. One is the spill hose from the filler bib, the other is the tank vent. Just pop them both apart and continue your trip. Or just leave your cap slightly loose.
Arrows point to the two hoses and the circle is where the junction is.
post #4 of 4 Old Jun 5th, 2015, 8:53 pm Thread Starter
ChiefMn's Avatar
Re: sucking gas cap
Thanks guys. Found the vent lines under the seat.uplugged the right one with the quick connect under the rear seat and plugged the left one with the screwdriver in the tool kit.Blew in the right one and heard air through the gas cap.
Thanks for the Alices Restruant diagram with the squggley lines and arrows showing what every thang was
lowlid40 likes this.
Jeff Bokusky
Shoreview ,Mn.
2001 K1200LT ---
1985 kawasaki KX250
1993 honda XR 200--
ChiefMn is offline
Windshield a giant, sucking vortex LT_Timmer K1200LT 23 Nov 3rd, 2009 9:41 pm
Face flattening, brain sucking fun davemoore Chit Chat 0 Jul 29th, 2008 9:17 am
DTE Gone Haywire ronk1200lt K1200LT 13 Dec 6th, 2005 5:54 pm
