oil qty front forks - BMW Luxury Touring Community
 2Likes
  • 1 Post By oldmopars
  • 1 Post By Voyager
post #1 of 10 Old Jun 4th, 2015, 7:57 pm Thread Starter
bobst2's Avatar
Question oil qty front forks
looking for ounces or millileter per fork. my manual says .47 us gallon and i know
that is incorrect.
i got around 14 ounces out
and was thinking of useing 15 weight fork oil becauser i have a new bottle
any reason not to they say atf
bobst2 is offline
post #2 of 10 Old Jun 4th, 2015, 8:31 pm
bob1811's Avatar
Re: oil qty front forks
I just replaced a fork seal. Each fork takes 0.142 gallons or 0.47 liters. I used ATF.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #3 of 10 Old Jun 4th, 2015, 8:54 pm
The LT forks do not function as a shock absorber so it really does not matter what oil you put in them
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 10 Old Jun 4th, 2015, 11:46 pm
Axle's Avatar
don't like to disagree with your statement but they do, if you put too heavy oil in them the spring and shock won't work very well. too light and the opposite occurs. to say "it doesnt matter what oil you put in the forks" is a fairly broad statement.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 10 Old Jun 5th, 2015, 12:20 am
oldmopars's Avatar
I believe he said that because the forks are just empty tubes that keep the front wheels going straight. There is no springs, check valves, orifices, etc. in there, just empty tubes. All the spring support, dampening and basic "suspension" action is handled by the shock/spring that sits back a little bit.
So, all you really need in there is a good oil to keep them moving freely. ATF or other shock oil should be fine, the WT will not change the way the bike handles unless you put something really thick and sticky in there.
Patric likes this.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
1997 R1100RT
2000 K1200LT Sold
oldmopars is offline
post #6 of 10 Old Jun 5th, 2015, 6:58 am
I agree. I understand his point that this oil is not the primary determinant of damping force as in conventional forks, but different oils will affect both static and dynamic friction of the sliders. A light fork oil will allow much easier fork movement as compared to say heavy motor oil or gear oil. I would stay close to whatever BMW recommends. This is almost always a good idea with any manufactured equipment. It is rare that the maker of the product gets it completely wrong. It happens, but not often and generally gets corrected via a TSB, etc.
Patric likes this.
post #7 of 10 Old Jun 5th, 2015, 8:52 am
MountianMama's Avatar
The 471ML just happens to be 16 FLOZ
Eric von Laue
3Cyl Kawa ( a long time ago)
450 Yamaha Seca ( maybe it was a Maxim )
1100 Honda Magna
650 Honda XR ( to Guatemala and back)
1990 Honda PC800 ( Mountain Mama )
2000 BMW 1200LT ( Maxamillion )
Keep the rubber side down
MountianMama is offline
post #8 of 10 Old Jun 5th, 2015, 9:22 am
The stanchions physically touch 2 small bushings that is the bearing surface for movement up and down, as mentioned no springs or damper inside the forks. I am assuming you will not be putting in some type of extremely heavy oil that could affect the small bearing surface and cause increased stiction.
The V Star 650 comes with a very short spring, long 8 inch spacer and they put in quit heavy fork oil, in mine I put in K100 springs, short 1 inch spacer and number 5 fork oil, the ride was much better. The forks worked more fluidly, smoother, they do make an after market spring long spring for the Star, I had the springs from parting out my K100, the stock setup is cheaper.
If you are interested chart on fork oil
Fork Oil Viscosity Chart, ignore the weight on the label.- Mtbr.com
Another tech article on fork oil
http://www.peterverdone.com/wiki/?ti...spension_Fluid
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #9 of 10 Old Jun 6th, 2015, 9:06 am
GaryEm's Avatar
Bob where did you get your fork seals and what kind and order# are they thats the next thing I have to do
Gary
2003 K1200LT
GaryEm is offline
post #10 of 10 Old Jun 6th, 2015, 10:50 am
bob1811's Avatar
Gary,
Two sources the BMW Dealer at $13.00 for each seal plus shipping, or Amazon, "All Balls" fork seal kit #55-108 at $10.88 w/free shipping for two seals. As you might guess, I went with the All Balls deal. They work fine.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
Dont ever search the word OIL... Carsucharda K1200LT 18 Mar 23rd, 2012 9:08 pm
2012 RT Front Forks?? Eureka RT Series 2 Dec 9th, 2011 9:14 pm
Eye opening service visit pozo_izquierdo K1200LT 50 May 22nd, 2011 1:14 pm
An Oil Man's View robasay Chit Chat 38 Jun 25th, 2009 8:28 am
2006 R1200RT Front Oil Leak CPAJJS RT Series 5 Jan 21st, 2009 9:01 pm
