Brake Caliper Bleed Screws won't stop leaking - BMW Luxury Touring Community
 1Likes
  • 1 Post By bob1811
post #1 of 9 Old Jun 4th, 2015, 11:09 am Thread Starter
bob1811's Avatar
I just completed the annual service on my 2005 LT. This included the installation of new brake pads and the annual brake flush.
Back story… Several years ago, after reading threads on this forum about speed bleeders, I purchased a complete set of the screws for my bike. I later determined that they aren't really needed to perform the flush, so I never installed them.
So fast forward to last week, I find the unopened bleed screws in the original packaging and in a moment of brilliance, I decide that it would be a good idea to install them on the bike. I completed the install and system flush with no problems, at least I thought. I went out for a ride and noticed leakage from the bleed hole (not threads) on both rear caliper bleed screws. I tightened them down more, still they leaked. So I decided to place the original screws back in the caliper… now they are leaking as well (from the bleed hole, not the threads). I can’t torque them down any further. Prior to this situation, I’ve never had leak issues with the bleed screws.
My concern is, Why is it leaking from the bleed hole, but not the threads, and how do I make it stop?
Options I’m thinking about:
1) Putting thread sealant on the original screws and reinstalling.
2) I have another set of unopened speed bleeders, SB1010, not the SB1010S that I could try. The SB1010 is a longer screw.
3) Ordering replacement OEM screws.
Thoughts?????
Thanks in advance.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #2 of 9 Old Jun 4th, 2015, 11:29 am
Re: Brake Caliper Bleed Screws won't stop leaking
Thoughts?????
Thanks in advance.
I never bought speed bleeders as they are entirely unnecessary. I also read somewhere that some of them didn't fit right and needed to have the point filed off of the tip or something goofy like that. I wonder if you damaged the sealing surface in the calipers by installing the ill fitting speed breeders? Hopefully, someone here who has installed them successfully can give you some ideas.
For me, the cheap bleeder bag was a far better deal and just as effective as the speed bleeders and I got to keep the original bleed valves that work and seal just fine. I always prefer to apply Occam's razor and go for the simplest solution possible.
post #3 of 9 Old Jun 4th, 2015, 11:47 am
Moogie's Avatar
Lots of info on the net on this. Just google it. Most likely report was dirt on the caliper surface were the bleeder meets it, that's what makes the seal. You need to check each surface of the screw and caliper to make sure they are intact. I bought BMW bleeder screws after removing the factory fillers and they sealed good. May have to take the caliper off to inspect the mating surface. Hope this helps. A more knowledgeable mechanic with first hand experience will help.
2000 Lt
800 Kawasaki
25 yrs. without
750 Suzuki
550 Suzuki
160 Honda
Moogie is offline
post #4 of 9 Old Jun 4th, 2015, 12:29 pm Thread Starter
bob1811's Avatar
My apologies if I was not clear on the issue at play here. The leak is not from the threads of the screw (in either the speed bleeders or OEM screws), but from the bleed opening hole at the top of the screw (where the fluid comes out). I determined this when after install, I removed the rubber dust cap and fluid came out of the top of the cap. it's a small amount, but it's leaking and I'm trying to get it to stop.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #5 of 9 Old Jun 4th, 2015, 2:58 pm
I believe that's what Moogie was addressing. If the bleeders don't make a good seal when turned in they will leak out the hole.
Speed bleeders have been known to have an issue with sealing. If you over torqued the speed bleeders you may have damaged the sealing surface in the caliper's holes. A really good machinist may be able to clean them up.
Buff8stuff is offline
post #6 of 9 Old Jun 4th, 2015, 7:57 pm
Completely remove the bleed screw and make sure there is no leftover thread sealer down in the hole (clean it with a Q-tip) from the Speed Bleeders. Then make sure the tip of the bleed screw is clean and smooth and re-install. Also look at the threads to make sure they are clean as well.
post #7 of 9 Old Jun 4th, 2015, 8:23 pm Thread Starter
bob1811's Avatar
Thanks to everyone for the responses. I'll pull the screws and clean them up and reinstall as suggested. I'll let you know how it works out.
Thanks!
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #8 of 9 Old Jun 6th, 2015, 7:17 am
beemer2's Avatar
I had a bleeder screw on the rear caliper leak after doing the Speigler line change when filling the system. I ended up running a tap thru and replacing with a new bleeder. Leak fixed.
Marvin
2003 K1200 LTC
1967 Honda SS125
1964 Honda 90
2008 R1200RT.. Sold
beemer2 is offline
post #9 of 9 Old Jun 6th, 2015, 10:35 am Thread Starter
bob1811's Avatar
I took John's advice and cleaned up the thread lock residue from the speed bleeders. It seems to have worked...
Patric likes this.
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
Leaking front brake hose PaulStaske K1200LT 9 Oct 14th, 2013 12:15 am
front flexible brake line leaking Axle Australia, New Zealand, and AsiaPac 7 Sep 14th, 2013 8:57 pm
Not a Leaking Brake Caliper sully2028 K1200LT 5 Dec 29th, 2010 10:20 pm
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
