Has anyone experienced slow speed - BMW Luxury Touring Community
 1Likes
  • 1 Post By want2tour
post #1 of 9 Old Jun 3rd, 2015, 2:08 pm Thread Starter
ltlfeat's Avatar
Has anyone experienced a front wheel wobble at slow speed , less then 5 mph, it happens when stopping or making a slow speed turn.
ltlfeat is offline
post #2 of 9 Old Jun 3rd, 2015, 2:16 pm
want2tour's Avatar
Re: Has anyone experienced slow speed
A few questions come to mind. For starters:
How severe is the wobble?
Tire press?
Make/model of tire?
How new is the tire?
Does it happen on all types of tarmac?
And does it only happen after leaving the pub?
CaliDefector likes this.
2005 KLT Graphite Gray
2003 F650GS Black
*Too slow for fast women
want2tour is offline
post #3 of 9 Old Jun 3rd, 2015, 8:40 pm
Axle's Avatar
at that speed something is loose, the tyre is out of round, but most likely bad cupping. To be safe 1st make sure the wheel is not loose.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #4 of 9 Old Jun 4th, 2015, 9:22 am
Yes, the front tire was worn and cupped, put new tires on the bike and it went away
martin18152 is offline
post #5 of 9 Old Jun 4th, 2015, 9:30 am
Jim_McG's Avatar
That gave me a chuckle.
Jim
Jim_McG is offline
post #6 of 9 Old Jun 5th, 2015, 12:26 am
oldmopars's Avatar
AIR PRESSURE. Check it first. The Metz 880 will do that if the tire pressure is low. Freaked me out when mine did it, new tires and the thing wobbled, found out the guy that installed the tires had a faulty pressure gauge and he under inflated the tires. I added air and the wobble went away.
Also, it is free to check and should be part of your normal bike checks anyway.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
1997 R1100RT
2000 K1200LT Sold
oldmopars is offline
post #7 of 9 Old Jun 5th, 2015, 7:07 pm Thread Starter
ltlfeat's Avatar
2000 miles ago New 880 on the front and Bridgestone battle ax on the rear'
The first, time I have a mixed tires I didn’t didn't notice any problems, put LT away for the winter Spring time took her out for a ride wobble very prominent Turns out tire pressure was real low filled it up 42 pounds it was definitely better but it didn't go away,will check if anything is loose asap kinda doubt it she rides and handle graet otherwise
ltlfeat is offline
post #8 of 9 Old Jun 5th, 2015, 8:35 pm
oldmopars's Avatar
It may be after sitting for a while you need to get out an run it. Tires don't like to sit with all the weight in one spot for long periods, try taking a long ride, heat the tires up real good and see if it is still there, be sure to recheck tire pressure before the ride.
It is a good reason to ride if nothing else
1997 R1100RT
2000 K1200LT Sold
post #9 of 9 Old Jun 6th, 2015, 6:18 pm Thread Starter
ltlfeat's Avatar
Thanks all for the help had tire balanced all is good.
ltlfeat is offline
Speed and auto radio volume with Autocom Waz K1200LT 13 Nov 13th, 2008 2:55 pm
Front Fender Flew Off Going Through Speed Strips awscoach K1200LT 9 Oct 27th, 2008 11:19 pm
Speed Bleeder for clutch line SteveHill K1200LT 2 Jun 4th, 2008 1:22 am
low speed handling gpolakow K1200LT 25 Jun 20th, 2007 8:37 pm
Rear Brake and Slow Speed Handling Billy K1200LT 16 Jun 16th, 2007 11:04 am
