I think I messed up - BMW Luxury Touring Community
post #1 of 4 Old Jun 3rd, 2015, 12:52 am Thread Starter
I think I messed up
After my rear brake line on my 99 K1200 ruptured, I bought the Speigler kit to replace all of my lines. I watched the 54 minute YouTube video, and watched it again while I was doing the work. Everything was going great, I made everything fit, got it torqued down, went to bleed the system, and after getting new fluid in, it's all just shooting out of the bottom of the caliper and onto my garage floor. I've determined so far that this isn't right, but don't know what to do from here.
dmoore2793 is offline
post #2 of 4 Old Jun 3rd, 2015, 2:03 am
JNW003's Avatar
Re: I think I messed up
Sounds to me like you may have not used the spacers to replace the brake pads when you went to bleed the system. Other more expert wrenchers may chime in with other thoughts. Good luck on the fix!
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #3 of 4 Old Jun 3rd, 2015, 4:48 am
Axle's Avatar
more information is needed the the crystal ball went flat, where exactly is the leak? can you take a photo, did you have the pads out and pop a piston, if all you have done is changed the lines it should not have any impact on the caliper, so what have you done..? you did fit the new washers each side of the banjo,
If you undo the bleeder to much the fluid will bypass the bleed nipple and come out, they only need to be cracked far enough to allow the fluid to run, its much easier to have a second person squeezing the brake and then the other opens and closes the bleeder after each pump.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #4 of 4 Old Jun 3rd, 2015, 7:30 am
OldRider2's Avatar
Axle has explained it pretty good for you. I haven't replaced my brake lines but about every brake line has copper or some other washer that has to be fitted to either side or one side of the bolt on most lines. You'll figure it out!
OldRider2 is offline
45th Woman not to be messed with WildBil Chit Chat 11 Nov 11th, 2009 6:20 pm
Messed up ABS flush mpillis K1200LT 3 Nov 9th, 2008 9:52 am
HID Install Article Messed Up RVB1019 BMWLT Site Support Forum 6 Nov 8th, 2008 7:33 pm
How messed up is this? eljeffe Chit Chat 6 Jun 21st, 2008 1:16 am
Messed up fuel tank cover. Offwego K1200LT 6 Jun 25th, 2007 4:49 pm
