Tupperware - BMW Luxury Touring Community
post #1 of 2 Old May 30th, 2015, 11:43 pm Thread Starter
wrenchff1098's Avatar
Question Tupperware
Had a great day with the LT today Replaced the Fuel Filter and changed Plug and Wires she runs great with all four cylinders firing again #4 wire had a chunk out of it and the plug was wet and black and nasty not firing,
Anyway my new question is about the screws and clips that hold the tupperware in place a few of mine are no longer working, the rubber parts on a few are missing which allows them spin making it a major pain to get them tight or loose and two on the rear part of the bottom piece are just popped out
So anyway besides going to the dealer and buying them one at a time has anyone figured out a better solution? is this even a semi normal problem? the rattles are annoying
as always thanks for any input or ideas guys
1976 R90/6 (retired)
1993 K1100LT (retired)
1999 K1200LT
wrenchff1098 is offline
post #2 of 2 Old May 31st, 2015, 12:50 am
Re: Tupperware
There are other rubber wellnuts available that are considerably less expensive than the oem. Do a forum search for wellnuts and you should be able to find the source if someone that remembers doesn't post it here.
The metal clip style nuts are different than any others I have seen. I haven't been able to find them just like that anywhere except through BMW.
I have used the less expensive wellnuts, but found them to be of much inferior quality and went back to oem.
I generally order a few of each as well as some extra screws when I run low and have something else to order from Max BMW.
Buff8stuff is offline
Tupperware Trash Captain_Wayne K1200LT 2 Aug 18th, 2013 11:45 pm
Side Tupperware Pointer for First Timers hifiman K1200LT 11 Apr 5th, 2008 9:16 pm
How much tupperware to remove? BCVBeck K1200LT 4 Jan 31st, 2007 12:28 am
GPS Install Tupperware Removal? PhilD K1200LT 11 Aug 30th, 2006 7:28 pm
Dealership did not reinstall tupperware correctly vstromboli K1200LT 39 Feb 1st, 2006 11:52 pm
