May have stripped bolt attaching gearshift lever to footrest - BMW Luxury Touring Community
post #1 of 8 Old May 29th, 2015, 10:26 pm Thread Starter
Hi- have watched the video on gear shift maintenance and read tutorials - but I think I stripped the bolt attaching the gear shift lever to the footrest... Some talk about using heat first... Which I didn't do... Should I even be using the 6mm Allen wrench in the K1200 tool kit? It fits ... Maybe that was my first mistake. I started this job because I sheared off the bolt/ball joint attached to the shifter. I ordered a replacement gearshift lever after a friend could not tap into the socket and get it out... Now this...suggestions?
2015 Vulcan Classic 900 - newest bike in garage
2001 BMW K1200 LTC - current
2007 Suzuki VStrom 1000 (sold)
1985 Kawasaki KZ440 (R.I.P.)
01K12LTC is offline
post #2 of 8 Old May 30th, 2015, 12:09 am
Axle's Avatar
Re: May have stripped bolt attaching gearshift lever to footrest
mmmn no good maybe go this way ebay
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 8 Old May 31st, 2015, 10:52 am
If you just stripped the bolt head on the gear lever , leave it alone. There is no need to remove it. If you really want to get it out cut a slot in the head and then apply HEAT as there is blue loctite on the threads.
post #4 of 8 Old May 31st, 2015, 11:40 am Thread Starter
I was trying to replace the gear lever - as the bolt/ball cap sheared off and I ordered a replacement gear lever to attach to the footrest.
01K12LTC is offline
post #5 of 8 Old May 31st, 2015, 11:40 am Thread Starter
What do you mean - cut a slot in the head?
01K12LTC is offline
post #6 of 8 Old May 31st, 2015, 11:52 am Thread Starter
Axle... I bid on that!!
01K12LTC is offline
post #7 of 8 Old May 31st, 2015, 7:11 pm
Axle's Avatar
use a hacksaw or thin grinding disk slice the bolt head and use a straight screw driver
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #8 of 8 Old May 31st, 2015, 9:11 pm
And heat!
Stripped head bolt holes PaulStaske RT Series 25 Apr 24th, 2015 10:16 am
R1200RT Clutch Hand Lever Adjustment Modifications/Options Dimond RT Series 7 Aug 8th, 2014 7:07 pm
Stripped Rotor Bolt mactuba K1200LT 1 Mar 19th, 2014 7:57 pm
stripped bolt repair fpmlt K1200LT 8 Oct 16th, 2009 11:55 pm
