Wiring diagram for rear Saddlebag reflector to LED upgrade - BMW Luxury Touring Community
 1Likes
  • 1 Post By bfree
post #1 of 5 Old May 26th, 2015, 11:52 pm Thread Starter
Hi all,
I previously found a thread which showed how to add LED lights behind the reflector in the rear Saddle Bags. It was wired to be on in general use, but flash alternately with the blinkers. There was a diagram showing the wiring sequence.
I have spent ages and cannot find it. Can someone help?
Brian
bfree is offline
post #2 of 5 Old May 27th, 2015, 2:21 am
Axle's Avatar
Re: Wiring diagram for rear Saddlebag reflector to LED upgrade
is this what you are after ??
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 5 Old May 27th, 2015, 8:40 pm Thread Starter
Linton,
Thanks that is what I was after. There is another post which from memory requires you to join wires under the rear seat to achieve the same affect. The description to remove the reflectors talked about using broken dental tools. IMMSMW.
In any case, this provides me with a method to achieve what I am after. Now all I need is a garage to work in.
thanks Brian
bfree is offline
post #4 of 5 Old Jun 1st, 2015, 2:17 am Thread Starter
Hi,
I found the file i was looking for. Now need to work out which is best or me.
Just Bobs Running Lights
Brian
Axle likes this.
bfree is offline
post #5 of 5 Old Jun 1st, 2015, 8:41 am
Originally Posted by bfree View Post
Hi,
Brian
Wow! That's a lot more work than needs to be done.
Use dental floss to run behind the reflectors to remove them, split the reflector housing, drill hole in one end of back. Get strip LEDs, cut 9 LED lengths. You can either solder wires on to the cut strips or use these. If you use the clip on connectors you may need to carve relief in the reflector back. Glue the refectors back together. Drill matching hole through bumper and saddle bag. Follow Larry's (Rider West) wiring instructions. Clean mounting surfaces well and use a quality double sided tape to remount.
Buff8stuff is offline
Help creating a wiring diagram for CD Radio boblouder K1200LT 1 Sep 30th, 2011 11:37 am
Reverser switch wiring diagram? pozo_izquierdo K1200LT 9 Mar 19th, 2010 5:55 pm
need! electrical guru. wiring diagram JTEC K1200LT 3 Jul 17th, 2008 8:40 am
wiring diagram mlempenau K1200LT 1 Apr 8th, 2008 11:57 am
HID Wiring Diagram check Dezrae Lighting 8 Nov 4th, 2005 10:59 pm
