Rear wheel balancing - BMW Luxury Touring Community
 1Likes
  • 1 Post By jzeiler
post #1 of 14 Old May 26th, 2015, 7:14 am Thread Starter
cbxer's Avatar
I have a 5000 mile lt and am replacing tires. I noticed the factory didn't balance the rear tire. Is it recommended to balance the rear tire on these bikes? I know that was the original tire on the bike. Thanks in advance....
Terry
2005 k1200lt
2004 rune
3 1979 CBX
1980 CBX
cbxer is offline
post #2 of 14 Old May 26th, 2015, 7:34 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Rear wheel balancing
When I had my 2000 K1200LT the rear tire would sometimes be perfect & not need any weights, other times it would only take 1 or 2 weights to balance it. It will depend on how will the rim is balanced and how will the tire is balanced from the factory.
Stevie Shreeve
katnapinn is offline
post #3 of 14 Old May 26th, 2015, 7:54 am Thread Starter
cbxer's Avatar
I have a standard balancer. Do I need any extra adapters to balance the lt wheels?
Terry
2005 k1200lt
2004 rune
3 1979 CBX
1980 CBX
cbxer is offline
post #4 of 14 Old May 26th, 2015, 9:14 am
That Guy's Avatar
I used the cheap harbor freight balancer (with a new, straight rod) with nothing special. worked a peach.
- Justin
That Guy is offline
post #5 of 14 Old May 27th, 2015, 7:52 pm
Just a data point my 05 came from the factory with no wheel weights and it was butter smooth. Over the last 90 K + I have gone through quite a few tires and some required as little as a 1/8 oz and some required 3 oz.
Patric likes this.
post #6 of 14 Old Jun 5th, 2015, 10:03 pm
flyerp52's Avatar
you might think about dyna beads been using them on the front and back .I really like them would recommend them.
flyerp52 is offline
post #7 of 14 Old Jun 5th, 2015, 11:50 pm
james216's Avatar
I used dynabeads in my rear tire last time. I like it so far.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #8 of 14 Old Jun 6th, 2015, 10:52 am
bob1811's Avatar
+1 on the dyna beads. Used in the last 4 tire changes....
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #9 of 14 Old Jun 7th, 2015, 9:05 pm
rowie's Avatar
I've used Dynabeads and liked them, trying RideOn Sealant to see if that's any good. Liking it so far, but I start with a balanced wheel hoping that the auto balancing will lengthen the life of the tire (one can dream...!!).
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #10 of 14 Old Jun 9th, 2015, 7:26 pm
westvandude's Avatar
If you use a car type balancer you'll need to pull the large threaded spindle off put the motorcycle one on.
This is my balancer:
https://www.youtube.com/watch?v=fj8o2xTJoBI
don't show the motorcycle adapter there tho.
The motorcycle attachment looks weird like this:
http://thumbs1.ebaystatic.com/d/l225...eWAkaMhC9g.jpg
Not sure how static balancer would work because most motorcycle wheels have two bearing spots. This doesn't just 5th bolt hole.
Anything over 70mph and it self balances anyway. Just like the european washing machines. Thing bounces all over, but when it hits 1400rpm smooth.
Never tried the beads inside the tire... sounds like bs to me, just balance the damn thing properly.
However, yes, most motorcycle tires are much thinner than auto/truck tires and weight considerably less so will not require nearly as much balance weights.
westvandude is offline
post #11 of 14 Old Jun 10th, 2015, 8:30 am
Trust me on this one: use Ride-on and forget balancing!
budzee is offline
post #12 of 14 Old Jun 10th, 2015, 9:28 am
OldRider2's Avatar
I've used the beads for the last few years and they work great on Gold Wings. My LT seems to have a slight wobble/balance issue at very low speeds. I'm assuming that may be because of the slightly cupped tires from the PO that didn't ride much and didn't keep the air pressure up.
Budzee: I'm curious about the Ride-on product. How long have you used it and have you replaced any tires since using it? Does is leave a lot of residue or buildup of the sealant on the rim? Curious.
OldRider2 is offline
post #13 of 14 Old Jun 10th, 2015, 6:14 pm
JNW003's Avatar
Not to get very far off topic, but does anyone know if something like Slime or Ride-on would negatively affect valve stem-mounted tire pressure monitors?
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #14 of 14 Old Jun 11th, 2015, 8:29 am
I have used Ride-on on several bikes for 4-5 years now. I get my tires changed at a local Honda/Suzuki/HD dealer and they just wipe it off the rim with a rag, never heard any complaints. The guys at the dealer are real distance riders riding thousands of miles a year. They all use ride-on.
budzee is offline
Rear wheel spacer? superstan26 K1200LT 33 Nov 27th, 2017 5:54 pm
Spare Rear Wheel piper1612000 K1200LT 3 Aug 17th, 2014 5:20 pm
What Size of Torx Bit for Rear Wheel Bolts? BCVBeck RT Series 23 Sep 21st, 2013 2:06 pm
K1200LT auto rear wheel conversion Tourdog Trailers, Sidecars, & Trikes 10 Feb 26th, 2010 11:37 pm
Front wheel dirt vs rear wheel dirt gpolakow K1200LT 3 Sep 8th, 2007 9:04 pm
