ATF in final drive??? - BMW Luxury Touring Community
 4Likes
  • 1 Post By CharlieVT
  • 2 Post By r75
  • 1 Post By Voyager
post #1 of 19 Old May 26th, 2015, 5:39 am Thread Starter
That Guy's Avatar
So recently did a fluid flush in my fairly new-to-me 99 LT and discovered that the PO had put, what I think is, ATF in the thing. I replaced with syn hypoid gear oil, then rode a bit, then repeat to fully clear out any ATF.
There appears to be no problems with the rear end. no leaks, no play (that I can detect), no metal on the drain plug. My question is: is there anything I should be concerned about with having had ATF in there for who knows how long?
'Bout to do the trans also. lets see whats in that one.
- Justin
That Guy is offline
post #2 of 19 Old May 26th, 2015, 5:53 am
K100Dennis's Avatar
Re: ATF in final drive???
It's important to use a proper gear oil in the fd due to the sliding action of the spiral bevel drive. The gear oil has special extreme pressure additives (EP) to cope with the pressure on the gear tooth faces. Some residual ATF won't matter, not important to get every drop out.
Dennis
1987 Yamaha TY250R
1991 Aprilia Climber 280
1988 K100RT (the pack horse)
K100Dennis is offline
post #3 of 19 Old May 26th, 2015, 6:24 am Thread Starter
That Guy's Avatar
i know the reasons... I only hope that the ATF in there for however long it was caused no other issues. Again, all seems fine right now.
hopefully the transmission has proper oil in it.
- J
That Guy is offline
post #4 of 19 Old May 26th, 2015, 6:29 am
CharlieVT's Avatar
Some folks have used red colored synthetic gear lube 'cause they thought it was good stuff.
I don't know if the red gear lube is better or not, but you might have confused that stuff with ATF?
I think that even if it was ATF in there, it wouldn't cause problems.
2Wheelroadtrip likes this.
CharlieVT is offline
post #5 of 19 Old May 26th, 2015, 8:06 am
r75
BMW synthetic gear lube that was supplied by Spectro was red in color.
radar41 and bob1811 like this.
Bill
1999 K1200LT
2002 K1200RS
r75 is offline
post #6 of 19 Old May 26th, 2015, 8:45 am
Front wheel drive cars with automatic trans lub the differential with the ATF so should be OK
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #7 of 19 Old May 26th, 2015, 9:02 am Thread Starter
That Guy's Avatar
yeah I thought maybe it was red gear oil, but then the feel and smell of it screams ATF. I work around ATF a lot with old Honda forks so I usually have some on hand and unless it has the same feel and smell, it was definitely ATF.
I also know many of the Honda guys run ATF in the final drives of the older 80's bikes - goldwings, valks, magnas, ect - so that makes this suspect too.
Either way, it sounds like I shouldn't have an issue so that it a bit of a relief. Its fixed now so here's to hoping for no failures. I think I got the answers I was looking for so thanks guys!
- Justin
That Guy is offline
post #8 of 19 Old Jun 3rd, 2015, 10:04 pm
copperstatetour's Avatar
I'll throw my .02 in but I'm gonna say probably fine. I had the same surprise when I got my '00 LT, ATF in transmission and the final drive. I'm not sure how long it had been in there, but it was definitely ATF and not red gear oil, smell, oil weight, and clarity all proved it to be ATF.
Anyway, the skinny is that I have since put well over 20k on the bike and so far no signs of a problem. I'm sure that the lifespan of the transmission and FD have been slightly decreased but on the bright side, with all the detergents in ATF, the insides are probably gunk free and clean!
-Steve
2009 BMW R1200RT
2000 BMW K1200LT (was supposed to be replaced by above, but can't keep above running long enough to replace
2000 BMW R1200C
copperstatetour is offline
post #9 of 19 Old Jun 4th, 2015, 7:57 am
Apples to oranges. Most FWD cars have a transverse mounted engine. This means no change in direction that requires hypoid gears. It isn't the differential that requires the EP lubricant, but the ring and pinion gears that are typically hypoid style or a different, but similar style in the LT with a long name I can't remember.
Also, gears can be made larger with lower contact pressure for use with oils that are lighter in viscosity or which lack EP additives. And auto transmissions have high pressure pumps that can deliver oil much better than the splash systems in manual gearboxes and final drives.
The engineers that designed the gear sets know the contact pressures and type (sliding in the hypoid style) and what is required of the lubricants. Deviating from this is fraught with peril unless you have the skill to evaluate how an alternative oil will work in the gears in question. Putting ATF in a hypoid final drive is a very bad idea.
CharlieVT likes this.
post #10 of 19 Old Jun 4th, 2015, 8:22 am
Other than the spider gears and being larger, the hypoid gear "final drive" in my Taurus transmission was identical and I was extremely surprised to see it was not in a separate compartment with normal gear oil. It was transverse mounted, I believe a lot of front wheel drive cars are as you describe but there are front wheel drives that use hypoid gear sets running in ATF
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #11 of 19 Old Jun 4th, 2015, 9:17 am
Was it AWD?
post #12 of 19 Old Jun 4th, 2015, 9:22 am
Was it AWD?
No - 2 wheel
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #13 of 19 Old Jun 4th, 2015, 9:24 am
jkriner's Avatar
I used Redline Shockproof Heavy in my transmission and final drive. It has a reddish color to it. Almost like a strawberry milkshake. I didn't notice a difference in the final drive, but the transmission definitely shifted smoother.
Jesse Kriner
Hope Mills, NC
2014 K1600 GTL Damask Red
2005 K1200 LT "Gray Ghost" 148,000+ miles
2014 Honda CTX700 DCT ABS (wife's)
2012 Honda NC700X DCT ABS
2002 Shadow Sabre
1985 K100 RS
jkriner is offline
post #14 of 19 Old Jun 4th, 2015, 9:39 am
No - 2 wheel
What year and model and trim? I have found a few Taurus diagrams, but can't find a FWD one with hypoid ring and pinion.
post #15 of 19 Old Jun 4th, 2015, 12:10 pm
It was a 91 v6 also we had a tempo, only 2 automatics I ever changed tranny oil on and it was 15 years ago so my memory is probably wrong
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #16 of 19 Old Jun 4th, 2015, 5:14 pm
I'd be very curious to see why a car maker would use a hypoid ring and pinion in an application that requires no change in axis of rotation. That would be bizarre. One of the reasons for using transverse engines in FWD cars was to avoid the need to make a 90 change in direction of power transmission. Same reason that RWD cars have longitudinal engines. Direction changes are costly. Most transaxles use a simple set of helically cut gears to transfer power from crank to input of transmission. And these will live a long time in ATF as they don't have the sliding friction (shear) that hypoids have to handle and which requires the EP lubricants.
post #17 of 19 Old Jun 5th, 2015, 7:46 am
Jim_McG's Avatar
Generally true but I had a 1980 Audi 5000S FWD with longitudinal 5-cyl engine. Audi was an early FWD manufacturer & am pretty sure they now use a transverse mount. - more efficient & also much more compact.
I also currently own a 3000GT VR4 AWD with transverse engine. Power transmission to the rear has to change direction twice with considerable losses. The answer there - more power! But that's for a different forum.
But bringing this hijacked thread back to bikes, what's up with the K1600 - slant 6 transverse engine with rear drive - does that make any sense? No wonder it needs 160 HP. I still would take it though.
Jim
Jim_McG is offline
post #18 of 19 Old Jun 5th, 2015, 8:57 am
I suspect it has to do with two things:
1. Packaging - much as with transverse engine cars
2. Being more like the UJMs that for years outsold BMW
The two changes in direction of power flow for shaft drive bikes is a pain with this configuration. I think Honda got it right for a shaft drive configuration with the GW. Too bad they have fallen so far behind BMW on the technology curve everywhere else.
The thread wasn't hijacked. The discussion was very relevant to explain why you don't use ATF in an LT final drive even if some cars use it in their transaxles.
Now talking about the K1600 drivetrain configuration in a thread about ATF in an LT final drive is a real hijack.
post #19 of 19 Old Jun 5th, 2015, 2:55 pm
dougholck's Avatar
+1 for Redline Shockproof in Transmission to improve shifting.
Liqui-moly products in engine and final drive from Beemerboneyard.
107K and original final drive, 2002 LTe
Doug Holck
Lodi, Ca
I don't always ride motorcycles,
but when I do I prefer BMW's.
Ride safely my friends
3 Continents -10 Countries - 50 States
02 K1200LTe
04 1150GS Adventure
08 Suzuki DR650
CCR 05, 06, 07, 08, 09, 10, 11, 12, 13, 14
See you 2015 in Coeur d' Alene, Idaho
BMW MOA 109760
AMA Charter Life Member 518333
International Fellowship of Motorcycling Rotarians
HDDC POSSE
dougholck is offline
K1200LT Drive Shaft / Final Drive Leak fredtman K1200LT 14 Aug 17th, 2015 2:20 pm
What to do with a "used" FD jers99lt K1200LT 23 Dec 9th, 2011 11:31 am
HELP NEEDED - Final Drive cccpastorjack K1200LT 20 Aug 2nd, 2009 8:57 am
Final Drive murray K1200LT 22 Sep 28th, 2008 10:02 am
