2005 brake fluid reservoir location - BMW Luxury Touring Community
post #1 of 6 Old May 20th, 2015, 7:54 pm Thread Starter
I need to change rear pads. I wanted to check rear brake fluid level before I compress the caliper pistons. Where is the rear caliper reservoir? Is it ok to just compress and go?
stevekremer is offline
post #2 of 6 Old May 20th, 2015, 8:17 pm
johnbaker15's Avatar
Re: 2005 brake fluid reservoir location
It's part of the ABS unit, under the seat on the left. There are actually four places for brake fluid, two for control circuits and two for brakes.
Looking for the photo that shows the location on top of the ABS unit.
Take a look at this file for location.
File Type: doc Addendum for flushing 05 brake system.doc (820.5 KB, 226 views)
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #3 of 6 Old May 20th, 2015, 8:23 pm
If the level was set properly at the last brake flush you will not overflow the reservoir. Having said that here is the location of the rear reservoir (it is the shorter of the two with the funnel in it). The proper procedure when flushing is to have the caliper pistons fully pushed in for the flush. Then top off the reservoir and re install the pads and seat then against the rotor. That way you have no spillage when replacing the pads.
ID:	80761   Click image for larger version
post #4 of 6 Old May 20th, 2015, 8:24 pm
cbxer's Avatar
I just flushed mine. The rear resevoir is on the bikes right side under the seat. Towards the back.
Terry
2005 k1200lt
2004 rune
3 1979 CBX
1980 CBX
cbxer is offline
post #5 of 6 Old May 20th, 2015, 8:29 pm
That is the rear control circuit reservoir, the braking reservoir is on top of the ABS unit.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
post #6 of 6 Old May 20th, 2015, 8:31 pm
cbxer's Avatar
You are correct.
Terry
2005 k1200lt
2004 rune
3 1979 CBX
1980 CBX
cbxer is offline
Brake flush intervals Voyager K1200LT 8 May 25th, 2014 9:45 pm
Loss of Brake fluid beemer100 K1200LT 3 Aug 29th, 2010 1:49 pm
Pulled the plug-- MN.GT K1200/1300GT (The Next Generation) 37 Mar 4th, 2009 7:49 pm
Rear brake fluid reservoir Colin1952 K1200LT 7 Nov 21st, 2005 6:40 pm
Help! 04 Rear Brake Fluid Reservoir mikec826 K1200LT 2 Nov 4th, 2005 10:15 am
