help i can't see - BMW Luxury Touring Community
 3Likes
  • 1 Post By Enduro
  • 1 Post By rhawk
  • 1 Post By james216
post #1 of 24 Old May 17th, 2015, 12:52 pm Thread Starter
ghost rider's Avatar
help i can't see
I have a 2001 Lt with a tall c bailey windshield. Which it great untill it rain then I can't see a thing. I have tried rain x with no effect my only option is standing on the pegs. Which gets very tiring after a few miles. Any thoughts ???
ghost rider is offline
post #2 of 24 Old May 17th, 2015, 3:10 pm
Re: help i can't see
Be careful with the RainX, as I recall it says not to use it on plastic
eelmgren is offline
post #3 of 24 Old May 17th, 2015, 3:32 pm
Scouter-50's Avatar
Not trying to hijack this thread but are you the Erik Elmgren that went to SFA in Nacogdoches?
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #4 of 24 Old May 17th, 2015, 4:33 pm
STEBS's Avatar
Painters tape, a pencil, a saber saw, cut it, if you can live with a shorter screen.
2015 R1200Rt- Ebony
2005 K1200Lt- Dark Graphite
1978 KZ1000 Ltd- Black
St Clair Shores, Mi
BMWMOA # 185482
STEBS is offline
post #5 of 24 Old May 17th, 2015, 6:20 pm
CaliDefector's Avatar
It sounds too high if you have to look through it (though that's just my opinion, you may prefer shield that high.) Be *very* careful if you do choose to cut it though. I used a saber saw with some pretty good teeth. It all went very well until the last moment when I turned it around to finish from the opposite direction then it kinda "jumped" on me and sent a crack through the plastic. I was *so* bummed. Salvaged it with a torch to seal the crack and still use it, but I'd have preferred not to have the crack.
Long story short, I'd use a finer tooth blade next time and possibly a jig saw instead of a saber saw.
But, with the exception of that, cutting it was very easy. Tape the heck out of it as recommended. I used the Euro profile from my short shield and it turned out to be an awesome shape.
2007 R1200GS Adventure
No longer "OrovilleTim" as I defected from California
CaliDefector is offline
post #6 of 24 Old May 17th, 2015, 9:20 pm
Rain-X is bad for some plastics. I lower my windshield in the rain so that I can look over it. And get enough wind blast to keep my helmet shield clear.
post #7 of 24 Old May 17th, 2015, 9:57 pm Thread Starter
Yeah the shield is too tall the po must have been way over 6 foot even at it's lowest it's an inch and a half too tall. I would try to cut it but I'm sure that would be a disaster. Guess I'll have to live with it
post #8 of 24 Old May 17th, 2015, 10:06 pm
Axle's Avatar
tape it up use a felt pen and a steel tape measure to draw the line and use an angle grinder with the fine cutting blade, it will go through like butter.. just take it down in stages until you are happy
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #9 of 24 Old May 18th, 2015, 7:07 am
STEBS's Avatar
It is very easy, I used a fine tooth blade on a jig saw (saber saw?) at high speed, a little edge sanding and a torch (optional) to bring the clear smooth edge back. The angle grinder sounds even easier with no chance of cracking it.
2015 R1200Rt- Ebony
St Clair Shores, Mi
BMWMOA # 185482
STEBS is offline
post #10 of 24 Old May 18th, 2015, 7:19 am
Before selling it, you might be able to just trade it with another forum member. I'd give that a try before making a cut.
As others have said, in the rain, for me, most of the time, I can see a lot better just through the face-plate of the helmet. The rain seems to splatter away, if I'm going fast enough. Too many wet layers really does restrict vision.
post #11 of 24 Old May 18th, 2015, 8:31 am
You really should have the option of looking well over the top if you want and also be able to raise it so you are looking through it. I had a tall and was looking basically just over the edge, the edge would obstruct vision sometimes. When I raised it I was looking way down through it and backdraft would splash water on the inside of it. I cut about 3" off and now I am looking well over the top getting better airflow in all conditions and when I raise it I am looking probably 4+ inches down into it good for cold nights and only a little backdraft.
Cutting it is a nice project but you MUST protect the surface against the bottom of the saw. Also a little acetone on a clothed fingertip puts a super smooth translucent finish on the edge. I cut it mounted on the bike.
johnbaker15 likes this.
04 K1200LT, 05 F650GS
Enduro is offline
post #12 of 24 Old May 18th, 2015, 11:13 am
I have an older stock shield that I would trade for the cee bailey. PM me if you are interested. My shield is in pretty good condition but not pristine. But you could lower it with rain conditions.
Notahog is offline
post #13 of 24 Old May 18th, 2015, 11:46 am
I have a pretty short windshield that I took off a 2005 LT. If it will fit your bike send me a message and I will send you the exact height and you can decide if it will work for you. I replaced it with a taller windshield on my bike because I felt it was too short.
kc5ero is offline
post #14 of 24 Old May 18th, 2015, 11:13 pm
I cut 2 inches of my C Bailey windshield with a Dremel and sanded the edge with sand paper. You would never know it was cut.
Alain
Vieux motard que jamais
Alpac is offline
post #15 of 24 Old May 21st, 2015, 4:29 pm
Some guys on my last forum site for Triumphs cut their windshields and then reattched the cutoff portion with small spacers to make a laminal lip to get better wind protection. Just saying
BMWMOA
Never ride faster than your Guardian Angel can fly
2007 K1200LT Storm Grey metallic
Uni Go Trailer
Chayside is offline
post #16 of 24 Old Jun 7th, 2015, 9:25 pm
I shipped Ghost Rider a short windshield and now he is not accepting PM's and has not refunded my shipping costs. Anyone else having problems?
kc5ero is offline
post #17 of 24 Old Jun 14th, 2015, 8:51 pm
wrenchff1098's Avatar
I taped mine off then used a simple compass that I got from CVS drew my line and then with a thin grinding wheel on my dremal tool just kept going over the line until it was cut through and then a sanding pad that I had from home depot and finished it off, its actually pretty easy and made a huge difference in my ability to see over it if I really want to look through it i can always just raise it
SO if I can do it i would think anyone can
1976 R90/6 (retired)
1993 K1100LT (retired)
1999 K1200LT
wrenchff1098 is offline
post #18 of 24 Old Jun 26th, 2015, 11:24 pm
rhawk's Avatar
Reading this thread got Me to thinking...
A couple of years ago, I ordered a Cee Baily's #1 standard windshield for the LT in stock 24" height (thinking that I would like it).
After riding with it for a short while, I realized that it didn't agree with me. The top of the shield was right at eye level, & when it was raised, I felt like I was looking through a fish bowl.
So I'm Thinkin....It's been awhile....the windshield must have depreciated a little.....why not go ahead & make the cut. After all, it's only the first cut that's really difficult.
So I've tried my best to emulate the drawing of 440MM Euro, as seen in the Max BMW fiche.
I think it came out Ok.
Ill attach some photos.
ID:	83346   Click image for larger version
ID:	83354   Click image for larger version
ID:	83362   Click image for larger version
ID:	83370   Click image for larger version
ID:	83386   Click image for larger version
ID:	83394   Click image for larger version
JNW003 likes this.
Rand & Susan Hawksworth
2000 K1200LT
rhawk is offline
post #19 of 24 Old Jun 27th, 2015, 9:55 am
james216's Avatar
No. Don't use rain X. If anything. I'd try a straight carnauba or Brazilian wax on it .Like S100. I have a 20" Cee Bailey shield, that's what I would do. Of course clean and polish it with Novus 1 or the polish Cee Baileys recommends. Or. Cut it down like others have done.
saddleman likes this.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #20 of 24 Old Jun 27th, 2015, 3:15 pm
JNW003's Avatar
I thought Brazilian wax was something else....
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #21 of 24 Old Jun 27th, 2015, 10:05 pm
CR125Honda's Avatar
Hope you got this sorted out..
Sounds like you tried to help out a fellow LT'er and got stiffed.
Doesn't sit well with me.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Couple Mini Trail's QA' & CT's
CR125Honda is offline
post #22 of 24 Old Jun 28th, 2015, 8:10 am
Scouter-50's Avatar
Robert
1981 R80GS
1976 R90S
post #23 of 24 Old Jun 30th, 2015, 5:31 pm
casualemt's Avatar
Gee isn't that the reason BMW put an adjustable wind screen on the LT? Up for protection (I use it to keep bugs out of my coffee cup in the morning) and down for visibility and airflow??? does that c bailey have a flashing red light on top to warn low flying aircraft when you have it all the way up???
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #24 of 24 Old Jun 30th, 2015, 6:17 pm
Did you ever hear from Ghostrider? Any resolution?
Steve
stevekremer is offline
