Starting problem - BMW Luxury Touring Community
 1Likes
  • 1 Post By mtrevelino
post #1 of 8 Old May 17th, 2015, 11:13 am Thread Starter
Unhappy Starting problem
Hi everyone,
I am new on this site, I bought a 2003 k1200LT 3weeks ago and ride the bike for a week. While riding the gauges started jumping up and down. The bike shut down and refuse to crank. it started after jump but shut down. I replace the battery but will only click, no crank or start. I bye pass the alarm system, still click only. I did push start and bike started, put volt meter on the battery, the meter is reading 12.55v only while accelerating. Can someone please help me, this is my first BMW.
kalilu is offline
post #2 of 8 Old May 17th, 2015, 12:14 pm
mtrevelino's Avatar
Re: Starting problem
It sounds like the ground cable came loose. It is tough to get to and is located on the starter(?). There are some posts on this happening. Perhaps someone else can chime in and tell you how to "reach" the loose cable.
As for voltage, the 12.55 reading should be with the engine off, if you are accelerating, or with the engine running, the voltage should be 14.1 volts.
Here is one link to tell you where to look for that loose ground cable:
http://www.bmwlt.com/forums/k1200lt/...k-starter.html
rhawk likes this.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 8 Old May 19th, 2015, 8:13 am Thread Starter
sorry for the delay, Thanks a lot for the help. the starter ground was the problem. Can you tell me the procedure to replace your K1200LT alternator? My alternator only putting out 12.80v at full throttle.
kalilu is offline
post #4 of 8 Old May 19th, 2015, 8:57 am
mtrevelino's Avatar
You really do not want to know this procedure. Just do an advanced search for clutch replacement and add a hour. Your best bet is to purchase a Clymers repair manual. Here is a link for the clutch replacement:
http://www.bmwlt.com/forums/k1200lt/...placement.html
Mike Trevelino
Williamsburg, VA
2008 RT
post #5 of 8 Old May 19th, 2015, 9:33 am
before you start tearing it apart, the voltage through the alternator indicator light tickles the alternator to put out voltage, make sure the connection - blue wire - back of alternator is a good connection on the alternator.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #6 of 8 Old May 19th, 2015, 10:29 am
You really want to be sure the problem is in the alternator before starting to replace it. MAJOR repair due to the needed dismantling...
Born to be wild so why not
C-A-D is offline
post #7 of 8 Old May 19th, 2015, 1:27 pm Thread Starter
thanks everyone, I check the blue wire when get home later.
kalilu is offline
post #8 of 8 Old May 19th, 2015, 7:46 pm
If the blue wire is solid then turn on the key and make sure you have a "battery" light with the engine off. If you don't the bulb is burned out and it is the source to excite the field in the alternator. Second one from the left on the bottom row.
Mystery Starting Problem Agent86 K1200LT 31 Oct 14th, 2013 2:47 pm
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 12:17 pm
Rain induced problem on '04 LT? bwdjr K1200LT 3 Nov 19th, 2009 12:01 pm
Starting problem taizadog RT Series 0 Jul 14th, 2009 8:34 am
1985 R80 Starting problem mpillis Other R-Bike Discussion 1 Jan 5th, 2006 7:49 am
