'05 LT Oil Burning Problem? - BMW Luxury Touring Community
post #1 of 12 Old Oct 17th, 2005, 12:59 pm Thread Starter
yeoman_kp's Avatar
Question '05 LT Oil Burning Problem?
My K1200LT has just 2200 miles on it. Fellow riders report that I smoke when accellerating. My first service was at 1,000 miles (as recommended by my salesman). After 1,200 miles since my oil change the site glass (on center stand) shows oil at the half way mark. I normally leave my bike on the center stand unless on a ride. Should I be concerned about the "black puffs" riders report and the amount of oil consumption at this point?
yeoman_kp is offline
post #2 of 12 Old Oct 17th, 2005, 1:24 pm
Senior Member (ret.)
RaffyK's Avatar
nope. You do not have oil consumption issues. The bike runs rich to cool the heads when you go full open on the throttle.
Raffy
RaffyK is offline
post #3 of 12 Old Oct 17th, 2005, 2:12 pm
k1200ltrider's Avatar
Talking
What Raffy said! Leaving the bike on the side stand for prolonged times will result in some tiny tiny bit of oil seeping by the valve stem seals but that is very normal. At startup this results in some smoke coming from the exhaust.The bike is therefore best parked on the center stand for long periods. If you want to use the side stand just switch of the engine wait 10 seconds to let the oil drain away (you can tilt the bike SLIGHTLY to the right) from the head and then park it as usual.YMMV
k1200ltrider is offline
post #4 of 12 Old Oct 17th, 2005, 3:13 pm Thread Starter
yeoman_kp's Avatar
How is the rich mixture on acceleration related to my oil consumption/burning?
post #5 of 12 Old Oct 17th, 2005, 3:22 pm
What you are saying is that in 1,200mi. you have burned about 1/2 sight glass of oil or less than 1 pint, right?
Since you only have 2,200mi. total on the bike, I would call this normal. Keep an eye on it and give the bike another 12,000 to break in. Oil consumption should be near zero then.
Bruce C
brucecha is offline
post #6 of 12 Old Oct 17th, 2005, 3:27 pm
Daman858's Avatar
When the mixture is rich, there is more fuel in the fuel to air ratio thereby making a bit of smoke. Mine does it and I have used a teaspoon of oil in 11,000 miles.
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #7 of 12 Old Oct 17th, 2005, 4:27 pm
RaffyK's Avatar
Was your oil level in the sight glass all the way to the top when parked on the center stand? If so, it was overfilled. It should be in the center of the sight glass. If it was overfilled, then parking on the side stand when on a ride would allow for seepage of oil and would cause the excess oil to burn.
The black smoke is rich fuel burning. If it was oil, you would have a blueish smoke. Follow another LT and watch when they go wide open on the throttle to pass a car or just do a speed run, you will see puffs of black smoke.
Raffy
RaffyK is offline
post #8 of 12 Old Oct 18th, 2005, 11:45 am Thread Starter
yeoman_kp's Avatar
Fill Level
Thanks to all for your input. My manual says with the bike on the center stand oil level at the top of the site glass is MAX and at the bottom is MIN. Raf's oil level recommendation of no more than half a site glass (where mine is now) seems in conflict with the manual.
post #9 of 12 Old Oct 18th, 2005, 12:10 pm
Dochatley's Avatar
My man yull says the same. On sidestand should be middle of glass, Top of glass when on center stand. Some guys run it at mid glass as full when on center stand. Either will be safe.
If you want to make God laugh, tell him your plans
Jerry P. Hatley
2007 R1200RT (Betty Lou)
2009 Harley Roadglide (sold)
2007 Goldwing (sold)
1999 BMW K1200LT (sold)
2004 Harley Ultra Classic (sold)
2002 Harley Ultra Classic (sold)
1998 Harley Roadking Classic (sold)
Dochatley is offline
post #10 of 12 Old Oct 18th, 2005, 3:41 pm
In general, as long as there's oil showing in the sight glass, you should be OK. Also note, the manual recommends checking your oil levels when the engine is at normal operating temps. Wait for about 5 minutes after shutting down for all the oil to return to the sump, then check it.
Here's the full scoop straight from the manual...
Name:	Checking oil levels.jpg
JetDoc is offline
post #11 of 12 Old Oct 18th, 2005, 4:08 pm
ZB50's Avatar
Hey Yeoman,
If anyone laughs at you when you bike smokes at startup,,,, Tell them it was engineered that way to prevent the damage that occurs during a dry/cold start. (Forward thinking in the BMW RD dept).
Jimmy
ZB50 is offline
post #12 of 12 Old Oct 19th, 2005, 8:26 am
Originally Posted by ZB50
Hey Yeoman,
Jimmy
The oil smoke helps lube the muffler bearings!
JetDoc is offline
Faceshield fogging, no problem. Faceshield freezing, problem. edonthenet Rider's Gear & Luggage 10 Mar 6th, 2018 7:43 pm
Newbie with a 2000 LT and a problem surfran K1200LT 21 Nov 8th, 2005 12:41 pm
Burning oil? RaffyK K1200LT 14 Oct 17th, 2005 1:23 pm
J-Peg Install Problem TomMoss Ergonomics & Rider Comfort 4 Oct 12th, 2005 9:36 pm
