2000 k1200lt abs piston cleaning - BMW Luxury Touring Community
post #1 of 12 Old Dec 27th, 2014, 2:04 pm Thread Starter
Hi Everyone: I have decided to take my abs unit apart and clean the pistons on my 200o k1200lt. My problem is I am trying to take the nuts off that are below the bleeder screws. Can anyone tell me the size of these nuts and the proper way to get them off.
whiteguy is offline
post #2 of 12 Old Dec 27th, 2014, 2:56 pm
Re: 2000 k1200lt abs piston cleaning
Here is a good article on it but no info on the size and I don't have one here to check.
post #3 of 12 Old Dec 27th, 2014, 4:05 pm Thread Starter
Thanks ,for sending me the article. I have the article and it is great but like you said we did not say the size of the nut. I think I need a thin wall socket.
Thanks for the help
whiteguy is offline
post #4 of 12 Old Dec 27th, 2014, 4:22 pm
I would try;
Measure the width of nut so you know what size socket you need, then grind some cheap socket down till it fits, no need to go buy a special thin wall one...
Regards,
Koen
koen850 is offline
post #5 of 12 Old Dec 27th, 2014, 5:02 pm Thread Starter
Thanks Koen I will give it a try
whiteguy is offline
post #6 of 12 Old Dec 28th, 2014, 4:57 am
Thanks for the help
Yes. Definitely thin wall socket is needed. I had to have the socket machined to fit. Sorry but do not remember the size and no possibility now to get to the bike to measure the size of it or the socket.
Born to be wild so why not
C-A-D is offline
post #7 of 12 Old Dec 28th, 2014, 7:08 am
Last month I also had to remove the ABS-pump. The 2 bolts gave me aan head ache.
In the end I used a nippers (is that the right word?). I uses new bolts (M6) when I reinstalled the pump.
tonvanunen is offline
post #8 of 12 Old Dec 29th, 2014, 9:00 am Thread Starter
Exclamation Re: 2000 k1200lt abs piston cleaning
Thanks everyone. When I get this nut off I will let you know the size and how I finally did it.
whiteguy is offline
post #9 of 12 Old Dec 29th, 2014, 1:21 pm Thread Starter
Just to let everyone know the nut is a 22mm. I needed to grind the socket so it was thinner and then it fit. One thing more I had to do was to also grind the end so the socket so it could grip the nut easier. If you look at a socket it has about a 1/4 inch of metal before the socket grasps the nut.
Hope i am making some sense.
whiteguy is offline
post #10 of 12 Old Dec 29th, 2014, 7:12 pm
Scouter-50's Avatar
It is perfectly clear to me, I have had to face off many a socket to get maximum surface area on a nut. If you could give a measurement of the final diameter of the socket it would be helpful. Also did you use a deep socket or a standard? Six point I assume. BTW a lathe makes this operation quite easy.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #11 of 12 Old Dec 29th, 2014, 7:57 pm
oldmopars's Avatar
BTW, if you can not find a 22mm, a 7/8 in socket will be "close enough", 22mm is not real common, but 7/8 in is very easy to find in the US.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
1997 R1100RT
2000 K1200LT Sold
oldmopars is offline
post #12 of 12 Old Dec 29th, 2014, 10:55 pm
22mm is pretty common in the Range Rover world. This was the lug size on my '04.
2000 BMW K1200 LT (Alice)
Gone, but not forgotten:
1983 Venture Royale
1982 Goldwing Aspencade
1982 Yamaha 650 Maxxim
1975 Yamaha 650 Special
Katy, TX
Leboyd is offline
2002 K1200LT Integral ABS Bleeding welivers K1200LT 5 Apr 27th, 2018 4:05 pm
What is the gap for the Rear ABS sensor on a 2000 LTC? wildwestrider K1200LT 5 May 2nd, 2008 10:30 pm
Being more specific: How is the ABS Unit flushed on a 2000 LT? wildwestrider K1200LT 20 Apr 18th, 2008 7:54 pm
