2005 k1200lt abs questions - BMW Luxury Touring Community
 4Likes
  • 1 Post By jzeiler
  • 1 Post By bowdon
  • 1 Post By jzeiler
  • 1 Post By pdrrock
post #1 of 23 Old Dec 26th, 2014, 11:19 am Thread Starter
Hello everyone, I'm new to this forum, new to BMW motorcycles, and new to ABS systems. I enjoy working on my own bikes and right now it's the k1200's turn to have some things done. I couldn't have picked a more challenging motorcycle. I'm changing the rear rotor, rear pads, and the brake lines. I've done brake lines before but not on ABS units. I'm thinking about doing the rotor first, getting it back together and then start on the brake lines. I have read many threads and watched some videos on Youtube. I am looking for a procedure to bleed the ABS unit after I get the lines in. There seems to be six bleed points on the unit, 4 short and 2 long. Or can I get away with changing one line at a time without putting air into the ABS unit, bleeding as I go. Again its the 2005 unit.
pdrrock is offline
post #2 of 23 Old Dec 26th, 2014, 1:18 pm
beech's Avatar
Re: 2005 k1200lt abs questions
There are two circuits for each end of the bike, control (lever to abs unit) and wheel, (abs unit to calipers). The control circuits use fluid from the visible relevant reservoirs, the wheel circuits have their reservoirs in the abs unit. You can not change a line without getting air into one of the systems. The six bleed points on the abs unit are opened and bled in specific orders. There are 3 for the front control circuit and abs chambers and 3 for the rear control circuit and abs chambers. There are several articles on how to do this. Not hard just a procedure. Beemer boneyard has a funnel that will thread into the cap hole in the abs unit for doing the wheel circuits. The control circuits are just replenished via the visible normal reservoirs.
I suggest you look and ask on the K bike forum I-BMW.com and purchase a Clymer manual or the Factory DVD. Either will give you the details. There are two versions of ABS modules with the six point bleed works and I don't remember which bikes have which. I believe you have the earlier one. Does it look like this?
How do I bleed K1200RS ABS III Brakes - I-BMW.com
Beech
beech is online now
post #3 of 23 Old Dec 26th, 2014, 1:52 pm
There are a few steps you can do to minimize the bleed especially on the front control circuit. I should have my write up done this weekend and it is a collection of notes from the last two brake line set changes I have done on the LT. The control circuits take the most work (mostly the rear) but wheel circuits you can use the funnel and the pumps to bleed them out to the calipers.
post #4 of 23 Old Dec 26th, 2014, 2:06 pm Thread Starter
No. I believe the reservoirs are built into the unit. Also the tall points of the bleeds are pointing vertical instead of horizontal. The Clymer manual only suggests the dealer do it if the system is drained. Oh! the funnel is on the way. I will check out the web page you suggested for more info. Thank you
pdrrock is offline
post #5 of 23 Old Dec 26th, 2014, 2:17 pm Thread Starter
Thank you. I look forward to your write up. In the meantime I will do more research. Boy, you guys are quick to respond. I appreciate that.
pdrrock is offline
post #6 of 23 Old Dec 26th, 2014, 2:27 pm
While you are waiting for the funnel get a short length of 3/8 Tygon tubing (lawnmower shops). Cut the funnel 3/4 inch above the screw in part and that will make the funnel fit around the frame in the Front reservoir (tall one).
ID:	71073   Click image for larger version
DanMartin likes this.
post #7 of 23 Old Dec 26th, 2014, 7:46 pm
Review all these resources to become familiar with changing out the brake lines on an LT.
From the i-BMW site Bleed
Kirks Videos from the BMW Motorrad Club of Northern Illinois Brake Line Replacement
And my rendition of how I have done it several times on LTs in a PDF file.
Let me know what you think then I will post it in the Technical Files area.
post #8 of 23 Old Dec 26th, 2014, 9:11 pm Thread Starter
OK John, I'll let you know when I get it done. Thank you!
pdrrock is offline
post #9 of 23 Old Dec 26th, 2014, 11:32 pm
I am usually here if you have a problem, happy to help.
post #10 of 23 Old Dec 27th, 2014, 8:07 pm
bowdon's Avatar
Wink Re: 2005 k1200lt abs questions
Hi guys,
I have the Phonix system, funnel and Speigler lines and plan on doing this in a few weeks since there is ice and snow in Montreal so no more riding till April 2015!!!
I would also be waiting for John's " paper words" so I can get prepared for the work on the lines.
Bowdon
newguy likes this.
bowdon is offline
post #11 of 23 Old Dec 27th, 2014, 9:58 pm
Originally Posted by bowdon View Post
Hi guys,
Bowdon
Look up at my post number 7 (can't use # anymore for number) . The PDF file is "my words".
But one thing I left out is that you can remove the big connector to make getting to the bleed ports easier. Helps if you don't have the "bent" 7 mm wrench.
post #12 of 23 Old Dec 27th, 2014, 11:33 pm
Thanks for the assistance John. Was a little late for me to use the connector removal trick, but I will be doing that for sure if I need to get any more air out of the control side.
1973 Yamaha 250 Enduro (crash and burn)
1982 Yamaha Virago 920 (sold)
Honda CB750 Custom (sold...good riddins!)
2003 K1200LT - Black (for sale)
2005 K1200LT - Ocean Blue Metallic
rdepas is offline
post #13 of 23 Old Dec 28th, 2014, 12:01 pm Thread Starter
Could someone tell me what the big deal would be if you had to start from the beginning when filling and bleeding the system. Is it just the time it would take or would you risk damaging the ABS unit. Again, I have no experience with ABS. Just curious and want to learn.
pdrrock is offline
post #14 of 23 Old Dec 28th, 2014, 4:05 pm
bikesnumbnuts's Avatar
Buy the Maintainance CD rom from Bmw , Its all there on it and after you have done a bleed change , You will understand it aint rocket science . I have changed the fluid out on 2 bikes using a Syringe .
bikesnumbnuts is offline
post #15 of 23 Old Dec 28th, 2014, 8:27 pm Thread Starter
I looked on ebay and motobins but I could not find the cd for a 2005. Just contact a dealer or is there another place you could suggest.
pdrrock is offline
post #16 of 23 Old Dec 29th, 2014, 1:13 pm
Try your local dealer and see if its available . 2004 upwards .
post #17 of 23 Old Dec 29th, 2014, 8:30 pm
Filling and bleeding the control circuits is done "key off". It doesnot matter which end you start with. Best to do the control first then use it to bleed the wheel circuits under power.
beech likes this.
post #18 of 23 Old Dec 30th, 2014, 10:14 am Thread Starter
That's a roger John. Thanks for the extra info. Will probably do this next weekend when all my ducks are in a row. Once I start I want to be able to finish it in one day. That's tough during football season. "Go Pac Go"
pdrrock is offline
post #19 of 23 Old Dec 30th, 2014, 12:08 pm
I feel your pain. Replaced my lines with Spieglers and John has been giving me pointers. It isn't a huge process but a little intimidating the first time (at least it was for me...) Will be testing mine with a GS-911 tonight.
My pointers are to take your time and get a Speedbleeder bag. Get plenty of brake fluid. It is cheap and caused me an extra day of work because I ran out on a Sunday after the auto parts stores were closed (had to watch the Pack do their thing! ) Bye week this weekend so you have two full days to work on the brakes.
rdepas is offline
post #20 of 23 Old Dec 30th, 2014, 1:40 pm Thread Starter
I assume a speedbleeder bag is a set of 4 or 5, probably available at beemer boneyard or maybe your local auto store. Next year I plan to go to Lambeau, Yours truely, Cheesehead, Rhode Island Chapter.
pdrrock is offline
post #21 of 23 Old Dec 30th, 2014, 1:51 pm
The Speedbleeder bag is like an IV bag (some guys use IV bags but I couldn't get my hands on one.) You can get them from multiple placed and they are about $10.
Lambeau is a great field. You'll love it!
rdepas is offline
post #22 of 23 Old Jan 3rd, 2015, 5:20 pm Thread Starter
I finished up today John. I ended up doing the full flush on both the front and back. Thank you for all your help as it proved to be invaluable. It took me about 3 to 4 hours as I took my time and everything seems to be operating fine. I won't know for sure until I can actually ride it, but it will be on the lift for most of the winter with plenty more to do. No error codes when the bike is turned on and the lever and pedal feel just about like my other bikes feel. I just have one question about filling the 2 reservoirs in the unit. Mine being the 2005. I used a syringe and filled it up to those white washer looking things. Again thanks so much. I appreciate your presence on this site and the fact that most of the threads I have read, your there answering a question.
cws likes this.
pdrrock is offline
post #23 of 23 Old Jan 4th, 2015, 10:21 pm
Yes to the top of the "white ring". That is actually a filter screen. I remove it and pull off old fluid before a flush, then replace it for the fill. To do the fill correctly on the 05 and up you need to have the caliper pistons fully retracted when you set the level in the reservoir. That way when you do get the wig-wag warning light it means your pads are about worn out. These reservoirs are not as sensitive to low level as the early bikes are.
But don't worry if you did not have the pistons back when you set the level. Just be sure and pull some off before you push them back for a flush or pad change or you will overflow fluid out the vent.
2002 K1200LT Integral ABS Bleeding welivers K1200LT 5 Apr 27th, 2018 4:05 pm
Should I sell my 2003 K1200LT before troubles come? And 12 other questions... joseph_p K1200LT 9 Sep 20th, 2012 1:32 pm
Swap 2005 engine to 2002 K1200LT? john_loucks K1200LT 8 May 4th, 2012 4:14 pm
2000 K1200LT ABS unit disassembly CharlieVT K1200LT 13 Sep 11th, 2011 3:40 pm
Which one to buy ? pre 2005 vs. post 2005 k1200lt? beemermike K1200LT 25 Oct 13th, 2010 11:06 am
