2005 front turn signal running lights not working - BMW Luxury Touring Community
 1Likes
  • 1 Post By rdepas
post #1 of 3 Old Dec 16th, 2014, 6:31 pm Thread Starter
Unlike my 2003, the 2005 uses a dual filament bulb. I am assuming this is to act as a running light...except I don't see mine cone on when I switch the ignition on or start the motorcycle. Is there some trick to get them to activate?
1973 Yamaha 250 Enduro (crash and burn)
1982 Yamaha Virago 920 (sold)
Honda CB750 Custom (sold...good riddins!)
2003 K1200LT - Black (for sale)
2005 K1200LT - Ocean Blue Metallic
rdepas is offline
post #2 of 3 Old Dec 16th, 2014, 6:58 pm
Munmi's Avatar
Re: 2005 front turn signal running lights not working
Could it be that someone has incorrectly put dual filament bulbs in the sockets?
I believe that not all years had running lights standard, therefore using single element bulbs. This is the case with my former '02 and current '04.
There was a ghetto mod here updating the standard turn signal to also have running lights.
Scott and Theresa
Munising, MI
2004 K1200LT Black
2014 Kawasaki KLR650
Munmi is offline
post #3 of 3 Old Dec 16th, 2014, 7:46 pm Thread Starter
Checked out the wiring diagram in Clymers. The wire going for the turn signal running filament is also tied in with the low beam. I just turned the key on and noticed my low beam isn't coming on either. Traced it back to a blown fuse. I did an HID upgrade and had read that the 7.5A fuse is on the low end for that and will blow if the battery is low. Was having a bit of an issue with the battery lately but should. be corrected now. Just put a 10A fuse in. Will see how that does. Side lights worked like a charm.
Munmi likes this.
rdepas is offline
Bright lights not working jsharp25 K1200LT 1 Jan 17th, 2014 8:20 am
Additional turn signal indication lights RonHolly K1200LT 32 Nov 1st, 2013 5:44 am
Lost running lights, brake lights, blinkers and horn...HELP! passteve Lighting 3 Sep 21st, 2011 12:50 pm
PIAA 1100X mod - Daytime Running Lights Daza Lighting 7 Jul 10th, 2009 1:11 pm
Turn Signal Bulb hschisler K1200LT 16 Aug 17th, 2008 3:32 pm
