2006 Xenon headlight replacement - BMW Luxury Touring Community
post #1 of 9 Old Dec 8th, 2014, 3:52 pm Thread Starter
Is changing the D2R bulb in the low beam the same as changing a H7 bulb?
The service manual left out the Xenon bulb R/R information, same as chilton's repair book.
thanks...Randy
2006 LT
Magnesium Shwarz Metalic
Bountiful, Utah
2006lt is offline
post #2 of 9 Old Dec 8th, 2014, 7:14 pm
Re: 2006 Xenon headlight replacement
Not entirely. The ballast is fastened to the assembly and if you have big hands....or are clumsy like myself, it might be easier to remove the nose cone to get at things.
Hoodcounty is offline
post #3 of 9 Old Dec 9th, 2014, 10:43 am
bblalock's Avatar
I am assuming your low beam isn't burning. Have you checked the fuse? I remember someone saying the Xenon bulbs do not burn out.
Benton Blalock
"I ride.....the bike doesn't"
'18 Honda Africa Twin Adventure SportDCT
'12 Kawi KLR 650 "Dirty" - traded in
'08 LT Black "Fireball" 113,000+ miles(RIP- transmission - may be seen on the road again)
'05 LT Yeller er Gold? "Ophelia"(RIP- fire) 80,000 miles
'04 R12CLC (RIP- hurricane) 36,000 miles
230,000+ BMW miles
'Rounder'
bblalock is offline
post #4 of 9 Old Dec 9th, 2014, 11:12 am Thread Starter
No, it's working, I read that bulbs lose their brightness over the years.
I would like to switch to a 55w 5000 bulb.
later..Randy
2006 LT
Bountiful, Utah
2006lt is offline
post #5 of 9 Old Dec 9th, 2014, 12:46 pm
GaryEm's Avatar
Its like changing the H-7 with the spring clip you push in and flip back and you can do this with out taking plastic off by laying on your back on some platform thats about 14 to 16 in. off the ground and work with both hands up there
Gary
2003 K1200LT
GaryEm is offline
post #6 of 9 Old Dec 9th, 2014, 3:18 pm Thread Starter
Thanks Gary.....
2006 LT
Bountiful, Utah
2006lt is offline
post #7 of 9 Old Dec 9th, 2014, 8:08 pm
later..Randy
In the HID world the bulbs are all DS2 units in different color temps and with different mounting bases. The power is determined by the ballast. In this case BMW only offers one ballast unit. And it is usually the ballast that goes out. The bulbs have an arc chamber and unless it is broken they will light.
post #8 of 9 Old Dec 10th, 2014, 9:01 am Thread Starter
Is this the right bulb? 85126, 35watt, phillips, made in Germany.
2006 LT
Bountiful, Utah
2006lt is offline
post #9 of 9 Old Dec 10th, 2014, 7:30 pm
Don't know if that fits - looks to be right. BMW lists it as:
07 11 9 905 567 BULB XENON LIGHT - D2R 0.04 1 $241.
Personally I have not seen one of the stock BMW bulbs but also I have never seen a HID bulb go bad that was not physically broken. I have replaced several ballasts though. I have the same bulb in my 05 LT for the last 10 years and have been through 2 ballasts and the bulb is just as bright as it was new.
One more data point D2S are for projector lights and D2R are for reflector lights (like the LT) but the bulb construction is the same internally.
Replacement radio for 2006 K1200LT RedDog K1200LT 0 Jun 14th, 2012 2:46 pm
2006 RT ESA shock replacement 1Tojo1 RT Series 1 May 5th, 2012 1:00 am
2006 320 Xenon light retrofit? Travis Lighting 6 Oct 15th, 2006 11:42 am
Replacement Hand Grips for a 2006 Lt Tarkusny Bike Talk 6 Jun 21st, 2006 7:54 am
Need replacement Xenon bulb for 2006 LT Scotter Lighting 23 Jan 31st, 2006 1:16 pm
