Weep at the reservoir after flushing the brakes - BMW Luxury Touring Community
post #1 of 6 Old Dec 6th, 2014, 12:45 pm Thread Starter
Hello
I have just changed the brake fluid as described in different threads.
Not easy but feasible.
Tried the bike; everything OK.
One little issue.
The fluid weeps (slightly) between the cover and the reservoir of the hand brake.
The level of the fluid is not high; between minimum and middle.
I am considering putting just a little RTV silicone
Any better idea?
By the way I was asking to myself how is this reservoir vented?
Thanks for the help
Bruno
Bruno_C
K1200 LT 2006 85000km
Moto Guzzi Breva 750 2004
Triumph Bonneville 1972
Norton Commando 1976
bruno_c is offline
post #2 of 6 Old Dec 6th, 2014, 1:37 pm
blueknightga6's Avatar
Re: Weep at the reservoir after flushing the brakes
I noticed the same thing on my K1200LT and it occurred each time after I had removed and replaced the cap for what every reason. I would wipe it and it would return. After I picked up the R1200RT I even noticed the same thing but had already figured out what it was from the K1200LT.
I think it is just residual fluid on the reservoir, the cover, the gasket or all three. It would stop and stop even quicker after I washed the motorcycle. Not just cleaned the reservoir but washed motorcycle with soapy water.
Chris Ehlbeck
blueknightga6 is offline
post #3 of 6 Old Dec 6th, 2014, 4:44 pm
There is a rubber diaphragm that seals the reservoir. It often has moisture on the outside and , of course, brake fluid on the inside. I always remove it from the lid and wipe it fully dry before I re-install. If you did not loosen and level the reservoir prior to setting the fill level you will get a small amount of push out when you re-install the lid/diaphragm combo. Just wipe it down and it should not reoccur. The diaphragm seals the unit but allows for fluid movement. The level should never change unless there is a problem since it only goes to the ABS unit and no further (unless you have a 99-2001 with ABS II)
post #4 of 6 Old Dec 6th, 2014, 5:02 pm
Guest
11862's Avatar
DOT 3 & 4 brake fluid is soluble in water so keep wiping the the reservoirs with a wet rag after any service to catch tramp leakage. A general water wash down of the whole bike is good also, to wash away drips etc...........
11862 is offline
post #5 of 6 Old Dec 7th, 2014, 9:11 pm
james216's Avatar
I had that happen when I installed my Ram mount reservoir cover last year. Just keep wiping it with a wet rag. Its just residual fluid from the seal.
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #6 of 6 Old Dec 8th, 2014, 4:54 am Thread Starter
Thank you all
I will wash it with soapy water and keep cleaning.
The gasket is in good condition so there is no reason it leaks.
Thanks again
Bruno
Bruno_C
bruno_c is offline
Weep Hole Drilling Video jzeiler K1200LT 81 Nov 25th, 2015 8:32 am
No rear brakes. timprice K1200LT 23 Jun 24th, 2014 6:36 pm
Flushing Integral ABS Brakes Jim_McG K1200LT 25 Mar 19th, 2014 3:49 pm
Tech Session in Easton, Pa. on March 21 firstbeemer North East 61 Mar 11th, 2011 2:55 pm
No front brakes - weird... ClaytonB K1200LT 18 Jun 2nd, 2010 6:17 pm
