Jacking bike help - BMW Luxury Touring Community
post #1 of 11 Old Dec 4th, 2014, 7:41 pm Thread Starter
Jacking bike help
I just have a regular motorcycle jack. I would like to get the bike off the ground about 2' with it with wheels and center stand off. I have adapters to do this with my other bikes. Can I block up the case and lift it like that and maybe place a winch in the floor joist to take some of the weight off it and keep it balanced. The bike is pretty much stripped and will stay that way for the winter while I work on it. Anybody jack their bikes with wheels and center stand off? Any ideas? Thanks Bob. OH, and what's the holes for that are just above the foot peg brackets?
pdrrock is offline
post #2 of 11 Old Dec 5th, 2014, 1:03 am
Re: Jacking bike help
not exactly what you're asking for, but I was reading this very ingenious thread in i-bmw yesterday about building a platform for a bike to do major work on... with few tools and a little timber. Lots of pictures and it's a little long, but entertaining reading nonetheless.
Maybe it'll give you some ideas.
post #3 of 11 Old Dec 5th, 2014, 5:39 am
Axle's Avatar
Rear engine mount access bolt holes
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #4 of 11 Old Dec 5th, 2014, 5:52 pm Thread Starter
That post was entertaining. What I am looking to do is support the bike with no center stand or wheels.
pdrrock is offline
post #5 of 11 Old Dec 5th, 2014, 7:27 pm
Scouter-50's Avatar
Skyhook?
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #6 of 11 Old Dec 6th, 2014, 5:47 am
pdrock, there's some pics in this thread where we had my bike jacked up at the rear on a couple of car jacks, with the motor held up with another jack so we could drop it slightly.
Can't see why you couldn't do something similar to get both wheels and centrestand off, ideally you'd be in a garage with strong ceiling joists so you could put some safety belts/ropes up to the joists to help hold the weight.
Put bike on centrestand, remove rear wheel. Once the rear wheel is off, jack the back up on to a timber frame (or jacks), then lift the front using a jack and timbers under the engine/transmission, then you can take the front wheel off and centrestand as long as you haven't tangled anything up. If it has the EHCS unit, remove that first before jacking up the engine/front.
?? think it should be OK as long as you have the safety straps.
Bit of work to get it a couple of feet up without a lift though, unless you can run it onto a ramp first that you can work around.
post #7 of 11 Old Dec 6th, 2014, 8:39 am Thread Starter
Thanks, those pictures are helpful. I'm going to see if I can use those engine mounting access holes to see if I can suspend it with a winch. That will carry some of the weight so I can stabilize the front and remove the wheel.
pdrrock is offline
post #8 of 11 Old Dec 6th, 2014, 9:16 am
Don't you have straps for the jack? Here's some pics from a K100RS I stripped, Did the same thing on an R1100RS and also on this R1200RT to get both wheels off for a tyre change. I have blocks of wood between the bike and the jack. Always pull the rear wheel first
07 R1200RTP
RobinW is offline
post #9 of 11 Old Dec 6th, 2014, 11:49 am
Should not be a problem unless you plan to remove the transmission. The engine and transmission have to tilt down to clear the frame. What you see with the RS will not work on the LT if you are pulling the transmission.
ID:	70049   Click image for larger version
post #10 of 11 Old Dec 6th, 2014, 9:34 pm Thread Starter
Are jacking the bike on the case? I was afraid all that weight would crack it. That was one reason to ask about jacking. I got the impression that it was a no no.
pdrrock is offline
post #11 of 11 Old Dec 7th, 2014, 7:29 pm
It just looks like the cases are used. The bearer is on the sub frame behind the cases. It clears the case by 1/2 inch.
K1200LT as a retirement bike... in India? rdwalker K1200LT 12 Nov 7th, 2011 10:14 am
Riding impressions SwedishViking K1600GT/GTL 106 May 23rd, 2011 10:34 am
Need Help! Bike Fell Over EastTexasRider K1200LT 8 May 9th, 2008 2:09 pm
K bike or R bike bvargas163 Bike Talk 4 May 20th, 2007 6:03 pm
The story of buying my LT (Really REALLY long...) bmwjason Ride Tales 0 Jan 7th, 2006 12:09 am
