Shift Linkage Lube - BMW Luxury Touring Community
 1Likes
  • 1 Post By saddleman
post #1 of 8 Old Nov 23rd, 2014, 5:38 pm Thread Starter
Enjoy The Ride
saddleman's Avatar
Shift Linkage Lube
After almost 200,000 miles on LT's I have a lube that I like on the shifter linkage balls. I have my 2004 on the lift because the brake servos failed & I haven't done any work on it in almost one year. when I remove the shifter linkage the Honda Moly lube that I used a year ago still looked liked the day I put it on. All of the other lubes I have tried left the balls dry after 6 months.
Razmataz likes this.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
post #2 of 8 Old Nov 23rd, 2014, 5:41 pm
murray's Avatar
Re: Shift Linkage Lube
+1
I use the same stuff there and try it on the centerstand.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #3 of 8 Old Nov 23rd, 2014, 5:45 pm
I make a blend of Honda Moly and VersaChem synthetic caliper grease. The latter is a very sticky transparent lube and adds to the "stickability" of the Moly. I use this on splines as well
post #4 of 8 Old Nov 23rd, 2014, 10:30 pm
Same here. I bought mine at the recommendation of Tom Cutter for use on my driveshaft splines and pivot pin bushings that I had him install when he rebuilt my FD last year. Works great on a variety of things.
post #5 of 8 Old Nov 24th, 2014, 5:58 am
james216's Avatar
How did your servos fail? Did they quit completely. Are you going to replace them. Or rebuild
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is online now
post #6 of 8 Old Nov 24th, 2014, 8:41 am Thread Starter
Enjoy The Ride
saddleman's Avatar
The servo's failed and I had minimal braking. I'm just going to bypass the ABS unit & have manual brakes.
Dave Selvig
2004 Black LT
2000 Canon Red LT
post #7 of 8 Old Nov 24th, 2014, 8:59 am
james216's Avatar
Let me know how it goes. If mine fails. That's what I would do
I'm a 4 percenter.
post #8 of 8 Old Dec 17th, 2014, 7:37 pm
drmajor's Avatar
I have been using Bel Ray blue jell....comes in a tub. Used it in our racing dirt bikes. After two years of racing in mud and sand, it was still good. Never seen it fail and we tried hard!
David Major
Charleston, SC
-2003 LT
-2007 GS Adventure. White
drmajor is offline
Shift Linkage Bushings gone at 17k miles cwarren K1200LT 27 Dec 21st, 2013 9:15 pm
Shift Linkage Install av8trto K1200LT 6 Oct 5th, 2011 11:42 pm
Shift Linkage Adjustment--shorten or lengthen? petevandyke K1200LT 6 Jun 30th, 2011 7:54 pm
Shift Linkage Lube beartooth K1200LT 5 Jun 10th, 2011 9:14 pm
Shift linkage lube - it's a sinch! Zotter K1200LT 14 Jun 20th, 2008 2:26 pm
