Any way to calibrate the speedo of '05 - BMW Luxury Touring Community
post #1 of 20 Old Nov 17th, 2014, 2:27 pm Thread Starter
I did the jumper mod on my '03 and it worked great. Wondering if there is a way to calibrate the speedo on an '05
1973 Yamaha 250 Enduro (crash and burn)
1982 Yamaha Virago 920 (sold)
Honda CB750 Custom (sold...good riddins!)
2003 K1200LT - Black (for sale)
2005 K1200LT - Ocean Blue Metallic
rdepas is offline
post #2 of 20 Old Nov 17th, 2014, 5:31 pm
deanwoolsey's Avatar
Re: Any way to calibrate the speedo of '05
Nope.
deanwoolsey is offline
post #3 of 20 Old Nov 17th, 2014, 5:41 pm Thread Starter
Back to calculating my 10% over all the time...
rdepas is offline
post #4 of 20 Old Nov 17th, 2014, 6:07 pm
mwnahas's Avatar
The 03 is 10% off. The 05 should be a constant amount of few mph over. The 03 can be jumpered, and the 05 some have moved the needle on the post one notch. The easy way use a GPS.
Just Go
Cleveland Ohio
2014 K1600 GTL Grey Wolf.
mwnahas is offline
post #5 of 20 Old Nov 17th, 2014, 6:10 pm Thread Starter
Good to know. I will need to check it against my GPS. Pick the bike up this coming weekend.
rdepas is offline
post #6 of 20 Old Nov 17th, 2014, 7:20 pm
The only way to fix it involves removing the unit, taking off the cover and plucking the speedo needle off the ervo. then re-install it to correct the error. Too much work as the tick marks are 3.333 mph. Why they didn't make them 2.5 I'll never know.
post #7 of 20 Old Nov 17th, 2014, 7:35 pm Thread Starter
Originally Posted by jzeiler View Post
...tick marks are 3.333 mph. Why they didn't make them 2.5 I'll never know.
5 kph = 3.1 mph so that would be my guess.
rdepas is offline
post #8 of 20 Old Nov 17th, 2014, 7:46 pm
True but the KPH scale has its own tick marks and they are 10 KPH each.
post #9 of 20 Old Nov 17th, 2014, 8:21 pm Thread Starter
I was just wondering if the MPH and KPH scales are swapped for other countries and that is why the tick marks would be that way. Honestly I don't have a clue...just spit-balling.
rdepas is offline
post #10 of 20 Old Nov 18th, 2014, 9:27 pm
rattler50's Avatar
My 05 is 5mph fast. When I show 80 I know I'm running 75...........
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #11 of 20 Old Nov 18th, 2014, 9:32 pm Thread Starter
Wife found out cops are serious about speed limits around the Olympic Peninsula but I have also found they don't sit in curvy areas of the mountains so that means some fun to be had!
I pick the bike up Friday. If it is 5 MPH off - that is easy enough to compensate for. It was different looking at the speedo on the 2005. So much different than the 2003 cluster.
rdepas is offline
post #12 of 20 Old Nov 18th, 2014, 11:37 pm
My '05 LT has always been about 5kph or so off on the high side, and I've always used a GPS for accuracy... so when I got the '05 GT I expected the same thing and ran at least 5kph over the posted limit... until I got a GPS installed after a couple of months of daily running and discovered the GT's speedo is very accurate
Got lucky and now stick much closer to the correct speed...
post #13 of 20 Old Nov 18th, 2014, 11:40 pm Thread Starter
What the heck! If they can make the speedo accurate on one bike, why not make them accurate on all of them??? Rhetorical question but it would have been nice of BMW to make the speedometers accurate on all bikes.
rdepas is offline
post #14 of 20 Old Nov 22nd, 2014, 12:56 am
casualemt's Avatar
What I find is odd is that the trip computer will give you an accurate speed, but not the speedometer...I wonder what feeds the trip computer?
RICH CANNON
2000 K1200LT "a great ride"
1979 XS1100 (gone)
1986 VT500 Ascot (gone)
1972 Honda 500-4 (gone)
1961 Lambretta (way gone)
casualemt is offline
post #15 of 20 Old Nov 22nd, 2014, 11:46 am
Same signal, just a different algorithm to process it. The BC provides a rolling average but will indicate current speed upon reset that is usually spot on. The speedo processes that signal to provide a steady rate signal for the indicator. Even my 330Ci is off by 3-5 mph. Must be by design to slow us down.
post #16 of 20 Old Nov 22nd, 2014, 11:48 am Thread Starter
Slow us down.... Good one! LOL
rdepas is offline
post #17 of 20 Old Nov 22nd, 2014, 3:23 pm
casualemt's Avatar
Actually I think it does help me with my speed, I am always looking at my speedometer and quick calculating my actual speed, which in effect causes me to be concious of my speed. This is a good thing, as my LT feels just as wonderful at 80 as it does at 60, but the state patrol doesn't see it that way....
post #18 of 20 Old Nov 23rd, 2014, 12:34 am Thread Starter
I found the opposite. Was so used to running 10% over that it was automatic and then I would find myself doing the same in my truck...which the speedo was right on! OK - I'll fess up, I would run a few over 10% over so it was even worse in the truck.
rdepas is offline
post #19 of 20 Old Nov 23rd, 2014, 6:29 pm
rattler50's Avatar
Set your cruise at 60 or 70mph and then zero out your average speed on the computer. It will tell you how fast you are going..............
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #20 of 20 Old Nov 24th, 2014, 12:18 am Thread Starter
That's a great idea!
rdepas is offline
Speedo trouble... rugguy K1200LT 5 Sep 5th, 2014 6:03 pm
Speedo correction - information please K100Dennis K1200LT 6 Sep 11th, 2011 8:02 pm
My speedo is fixed !!! STARFIGHTER RT Series 6 Dec 26th, 2008 5:06 pm
Speedo failure 1st bustedknuckles K1200LT 6 Feb 15th, 2007 9:17 pm
speedo correction for older RT retiredjj RT Series 0 Sep 13th, 2006 10:18 pm
