Won't go into 5th gear. - BMW Luxury Touring Community
post #1 of 17 Old Nov 16th, 2014, 10:56 pm Thread Starter
skagittom's Avatar
Angry Won't go into 5th gear.
OK. I was burned.
I just bought a 1999 K1200LT. 53,000 miles. According to the seller it only needed a rear tire. Before I test drove it I sat on it in his driveway and with the engine running clicked through the gears. The indicator only goes to 4th. I asked if it wasn't a 5 speed and he said "no, it is only a 4 speed". I test drove in in a 50 MPH speed zone and seemed OK. Got home and read the specs and looks like a 1999 should be a 5 speed. Any comments other than "SUCKER"?
skagittom is offline
post #2 of 17 Old Nov 16th, 2014, 11:50 pm
zippy_gg's Avatar
Re: Won't go into 5th gear.
Is your shifter loose or have a lot of play by any chance?
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is online now
post #3 of 17 Old Nov 17th, 2014, 12:32 am
fatbob307's Avatar
If you don't mind my asking, how much did you pay for the bike?
fatbob307 is offline
post #4 of 17 Old Nov 17th, 2014, 8:59 am
HarrisBikeNut1's Avatar
Although the digi display does not indicate 5th, can you select a 5th gear? Loose / broken wire to gear indicator? Maladjusted selector linkage? Something catching somewhere?
HarrisBikeNut1 is offline
post #5 of 17 Old Nov 17th, 2014, 10:08 am
I stand to be corrected but I don't think they made a K1200LT with a 4 speed transmission. Good Luck with your problem hopefully it is only the indicator messing up.
Notahog is offline
post #6 of 17 Old Nov 17th, 2014, 11:24 am Thread Starter
skagittom's Avatar
Doesn't seem to. Feels tight as it should. I dropped the bike off at my local motorcycle repair shop to have a new rear tire installed. After I read the specs saying it should have 5 forward gears, he said he would check it. We'll see. I've been looking on Ebay and transmissions are not expensive if it comes to that.
post #7 of 17 Old Nov 17th, 2014, 11:26 am Thread Starter
skagittom's Avatar
Although I haven't had much time with the bike yet, it seems to shift as normal. Just won't go to 5th. I'll know more tomorrow as my repair shop is closed Sundays and Mondays.
post #8 of 17 Old Nov 17th, 2014, 11:57 am
rhawk's Avatar
I don't think that you got burned.
Ok, the seller deserves it right in the nuts for giving you that line of 4 speed BS.
That said.... I'm going out on a positive limb here.
Historically, I haven't seen many LT Xmsn problems. However, the Shift linkage has a lot of monkey motion, and it gets sloppy with use. If the linkage hasn't been serviced in 50 K miles, it needs to be. ....SO....
Make the shift linkage as "like new" as possible, then change the transmission oil to fully synthetic 75W-90.
Also she upshifts better if you preload the shifter a little before pulling the clutch.
Rand & Susan Hawksworth
2000 K1200LT
rhawk is offline
post #9 of 17 Old Nov 17th, 2014, 12:02 pm
rhawk's Avatar
P.S.
53,000 miles is "just broken in"... So don't let your Shop sell you a transmission job until you try what I suggested.
And Welcome to the LT Community Tom.
2000 K1200LT
rhawk is offline
post #10 of 17 Old Nov 17th, 2014, 2:28 pm
copperstatetour's Avatar
I'm with rhawk, my first thought was shift linkage, I would at least certainly start there. If you look in the Files section accessed via the Technical dropdown at the top of the page there is a document called Shift Linkage Tidbits that goes through cleaning that part up. Here is a link. I perform a clean and lube of my shift linkage roughly every 6k miles and every time I do it I can tell a difference even with that short of an interval.
It also wouldn't hurt to put in new oil as noted above, you may even want to try running some ATF for high mileage cars in there for a few miles of light driving to clean things up - ATF is about 95% detergents and 5% lubrication (and 70% of all statistics are made up) and if there is guk and muk keeping things from working right it might clear it up. I can say with some confidence that the ATF won't hurt your transmission, when I bought my LT the PO had used ATF in the transmission and final drive and it wasn't in very pretty shape either. I have since put on ~30k and no problems.
-Steve
2000 BMW K1200LT
2000 BMW R1200C
copperstatetour is offline
post #11 of 17 Old Nov 17th, 2014, 2:47 pm
I have no idea if it's the linkage (because I haven't even purchased an LT - yet!). However, there's a great video on youtube that shows how to do it.
https://www.youtube.com/watch?v=4o-ysRHinLU
Lot's of good videos on youtube.
Leboyd is offline
post #12 of 17 Old Nov 17th, 2014, 7:29 pm
Shift linkage is my first response. A caveat though as the fifth gear has its own shift fork and if the the little pin on it is broken (goes into the shift drum, but I have never seen that before) then you will never get to 5 th. Item #4 in the picture. #2 is 1 st & 2 nd, #3 is 3 rd and 4 th.
Note to self do not use # to represent a Number any more as the web site interprets it as a hash tag. Damn social media!
But seriously when you have the bike back put it on the center stand and rock the rear wheel. Push down shift lever to confirm first, then continue rocking the wheel as you lift up an hear a gear change, there should be four in the up direction (you started in first).
post #13 of 17 Old Nov 18th, 2014, 11:33 pm Thread Starter
skagittom's Avatar
Thank you all for the great input. As I said, I left the bike with my Polaris-Kawasaki-Victory Dealer to put on a new rear tire and service/check everything. I got a call from them today that the bike was ready and it shifted fine. I tried to find out from my owner friend by text but I got no comment. Just that it was OK. I will pick it up tomorrow. Maybe changing all the fluids fixed the problem. I will post more later. Thank you for the welcome.
Tom
post #14 of 17 Old Nov 19th, 2014, 12:02 am Thread Starter
skagittom's Avatar
My mechanic said it is showing as going into 5th now. I saw the You Tube video of the transmission removal. Didn't look too bad. At least not compared to my 1969 Honda 750 Four that broke a chain, broke through the cases and bent all the transmission shafts. I had to pull the engine to get the bottom half of the case off then replace all the shafts (100.00 for all back in 1969)
I will post after I ride it after picking it up tomorrow. Hopefully it's not raining.
post #15 of 17 Old Nov 19th, 2014, 4:25 am
rhawk's Avatar
You should still service your shift linkage.
It's good preventive Maint.
By the sound of it, you're a you're not afraid to wrench, so it shouldn't be a big deal.
(good luck with the rain thing)
2000 K1200LT
rhawk is offline
post #16 of 17 Old Nov 23rd, 2014, 2:03 pm Thread Starter
skagittom's Avatar
Everything OK now, it seems.
Got the bike back from the shop and had to wait 'till yesterday afternoon to ride because of bad weather.
The bike shifts great, and has some features that I like much more than what my 2005 Goldwing 1800 had. The electric windshield is the best feature because I can adjust it to stop the wind noise from my helmet, or drop it down for best fuel economy. I love the heated seat and grips. I didn't have those on my Goldwing (or the power windshield). It has a very comfortable riding position for my 6'4" 210lb frame. Even though is more top heavy, it seems very easy to maneuver at speed. The battery is easier to get at also.
I will service the shift linkage soon. It doesn't always like to go into 1st gear without some extra effort.
post #17 of 17 Old Nov 23rd, 2014, 2:17 pm
johnbaker15's Avatar
Re: Everything OK now, it seems.
That isn't unusual, try preloading the shifter and letting the clutch out a little. It should drop right in gear, I do it frequently.
It is a "feature" not a problem.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
My Rear Drive Rebuild ErnieA North West 15 Jan 3rd, 2015 11:14 pm
A tale of of two gear box's Patric K1200LT 12 Jul 19th, 2010 11:46 am
Anyone use REV'It gear? Casey Rider's Gear & Luggage 8 Jul 5th, 2010 10:31 pm
Trouble getting into 1st gear durq K1200LT 27 May 11th, 2010 9:25 am
"Wife Beater" motorcycle safety gear Dean_BMW Bike Talk 48 Jun 15th, 2007 11:15 am
