Light bulb types ???? - BMW Luxury Touring Community
LinkBack Thread Tools
Old Nov 7th, 2014, 12:32 pm Thread Starter
Hello i,m Roland, i live in Europe Holland and got a question.
Is there a list or something like it were i can find al the types of light bulbs in the K1200Lt like H7 or bajonet and so on i,m looking for the types so i can order them but as led lights, thankx, Roland.
Aircooled is offline
Old Nov 7th, 2014, 8:45 pm
Re: Light bulb types ????
The LT 99-2003 use an H7 for low beam and H3 for high beam. On the facelift (2004-2009) the High beam is an H9.
Attached are all the other bulb specs.
Name:	Light Bulbs.PNG
Old Nov 8th, 2014, 8:14 am Thread Starter
ThankX
Old Nov 8th, 2014, 12:51 pm
norton's Avatar
John, you amaze me! every time someone has a question you have the answer including part #s , manuals and pictures to show what they are looking for or at. You must be very organized. I'm nominating you in for MVP of this site......... at least for this year. There are several more who would make the nominations and probably deserve a MVP also.
norton is offline
Old Nov 8th, 2014, 3:14 pm
Thanks, but I have been collecting info on the LT for over 10 years now. Some was garnered first hand and some was absorbed from others that went before me. My BMW folder contains 15.4 GB of data in 2,787 files and 297 subfolders.
Old Nov 8th, 2014, 4:33 pm
When do you plan to restart LT production?
Old Nov 9th, 2014, 7:56 am
norton's Avatar
I can see it now. With a little engine bore, NOS kit, carbon fiber and all the tweaks John has fixed and improved the bikes over the years we are proud to announce the all new for 2015 BMW "JZ Replica" 2000 LTZ.
Specifications:
Displacement: 2000 CC
Horsepower : 195
Torque: 210
Gears: Six forward/ Two in reverse
Suspension Air/ Hyd assist
Weight: 425 lbs.
Tires: Front/Rear Kevlar-ceramic compound
Final drive Electro-magnetic (no bearings,shafts or gears)
Brake assist: Parachute
Seats: Ethan Allen
Wind Protection: 1959 Volkswagen windshield
Mileage: 79 mpg
Colors: Whatever you like
Price: $8,995
Destination charge: $122,000
Warranty: Full labor and parts until your check clears
John where do I send my deposit?
norton is offline
Old Nov 9th, 2014, 8:43 am
Specifications:
Horsepower : 195
Torque: 210
Weight: 425 lbs.
Seats: Ethan Allen
Mileage: 79 mpg
Price: $8,995
I would be happy with the basics fixed (fuel QDs, viton crank o-ring, FD, trunk latch, etc.) and two performance mods:
1. A low compression turbocharged engine. Then I can run the cheap gas in Newfoundland without pinging on every hill (that was a scary tank of gas), yet have performance when needed and when high octane is available.
2. A wider ratio gear box with a lower first and higher 5th. A touring bike with an 8,000 rpm redline, doesn't need a close ratio gear box.
So, John, when will you have the prototype running? Maybe a partnership with Saddleman...
Old Nov 9th, 2014, 9:52 am
The problem with the motor in the LT is that it lacks a knock sensor, the 4 cylinder in my Fusion is high compression, runs extremely lean - 40 mpg on the highway, manual tranny, like all modern motors smooth and quiet. The fuel injection the same design but the software is most likely more advanced
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
Old Nov 9th, 2014, 9:58 am
sailor's Avatar
All the BMW new designed engines (or re-worked engines) that came out after 2004 now have knock sensors so you can run cheap gaz when this is all you have. This includes R1200xx (from 2005) and all "slant-4" and "slant-6" engines (K1200S, K1300S, K1300GT, K1600..)
Given that the K1200LT was at the end of its life, and given certain limitations of Motronic 2.4, I doubt it was worth it when they they did the last major facelift of K1200LT (late 2004).
John (Montreal, CANADA)
sailor is offline
Old Nov 9th, 2014, 12:39 pm
I agree a knock sensor is required as well, but a turbo is still the way to go.
And, unless you have a hybrid Fusion, the compression ratio is quite a bit less than the LT's 10.8:1.
Ford - Cars, SUVs, Trucks & Crossovers | Ford Vehicles | The Official Site of Ford Vehicles | Ford.com
Old Nov 9th, 2014, 12:42 pm
BMW was very late to the game in this regard. Cars have had knock sensors since the 70s.
Old Nov 9th, 2014, 2:25 pm
This post has strayed away from what it started out as. I think it will be Dave (saddleman) that will produce a high performance modified LT. I just want to keep whats there alive.
Old Nov 9th, 2014, 2:54 pm
smahon's Avatar
And a noble goal this is
'15 GTLE
smahon is offline
Old Nov 9th, 2014, 4:22 pm
Enjoy The Ride
saddleman's Avatar
I just read this post & I'm impressed John. I never thought of having a folder on the LT. Everything I know about the LT is in my head & we all know what happens when we get older with that kind of old style memory storage.
Dave Selvig
2004 Black LT
2000 Canon Red LT
saddleman is offline
Old Nov 9th, 2014, 4:32 pm
smahon's Avatar
My folder is this site, since anything I know came from here anyhow.
smahon is offline
Old Nov 9th, 2014, 5:13 pm
Yes, stray it did. It was a fun excursion though!
Old Nov 10th, 2014, 6:50 am Thread Starter
Started this topic as a light bulb topic but were way off topic now, so got a new question my Klt wont run in reverse, so when i switch it in reverse the orange light goes on and when i presse the start button........nothing
Anybody suggestions ?? would appreciate it, and by the way i,m from Holland so when my english grammar is not 100% yknow why.
regards Roland from Hoensbroek in the Netherlands (if you want to google it in google earth)
Old Nov 10th, 2014, 9:02 am
tombstone's Avatar
Hi Roland,
Probably best to start a new thread but ...
Please give a little more information on the problem. Is this something that has always worked and just stopped ?
If so, what has changed ?
You know the starter motor works and the bike starts.
You know the start button works for the same reason.
You know the reverse selector is working as the reverse light comes on.
I hope this is not a daft question, but the engine is running when you press the start button ?
More information may provide some meaningful responses.
Regards
Tony
2001 K1200LT Bought Nov 2011
1963 Norton Electra 400
1960 Norton Navigator Delux 350
1977 Norton Commando 850 MkIII, owned since new.
tombstone is offline
Old Nov 10th, 2014, 12:59 pm Thread Starter
Okay youre right a bit more info, its a 99 Klt, everything seems to be ok
i own the bike now for 2 months and everything on the bike works, BUT i was under the impression that the motor should not be running because a running motor and pressing the starter button is not always a good idea.
Please explain me what the right procedure is of letting the bike run backwards (reverse), regards from a newb, Roland.
Old Nov 10th, 2014, 1:06 pm
Jim_McG's Avatar
In order for reverse to work, the bike must be running, in neutral, and the knob rotated to reverse. Then pressing the starter button will slowly back you up.
Jim
Jim_McG is offline
Old Nov 10th, 2014, 1:36 pm
smahon's Avatar
Yes, the starter motor is the reverse motor. The engine only provides electricity for this operation.
'15 GTLE
smahon is offline
Old Nov 10th, 2014, 6:45 pm
No worries about damage as the over run clutch for starter to engine prevents any coupling to the engine during the reverse operation.
The engine should be on and there should be an increase in RPM when you push the button to reverse. It should reverse as long as you hold the button down.
If it stops after a few feet then there is speed sensor on the reverse gears that is malfunctioning.
Old Nov 11th, 2014, 4:10 am Thread Starter
Thankx
Old Nov 11th, 2014, 4:46 pm
rowie's Avatar
Has anyone found an LED bulb for the 04-09 that they're happy with? I've always felt the high beam is anemic. I have HID low beam which is awesome but HID in the high beam takes too long to warm up for a "high beam flash". Wondering about LEDs...
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
Old Nov 11th, 2014, 4:59 pm
rowie's Avatar
Has anyone found an LED bulb for the 2005 that they're happy with? I've always felt the halogen high beam is anemic. I have HID low beam which is awesome but HID in the high beam takes too long to warm up for a "high beam flash". Wondering about LED as an improvement...
BMWMOA member
Current rides:
Prior rides:
rowie is offline
Old Nov 11th, 2014, 6:44 pm
I've been doing some research and I don't think LEDs are there yet to replace standard bulbs for headlights. Some new cars are coming out with LED headlamps but those are specifically designed as LED - not a replacement bulb put in.
Like you, I am hoping for an LED replacement but I have a feeling we have a few years to wait. Probably have an easier time if someone came out with a replacement headlamp unit for the LT that was designed with LEDs. Of course I can imagine what that price tag would be!
1973 Yamaha 250 Enduro (crash and burn)
1982 Yamaha Virago 920 (sold)
Honda CB750 Custom (sold...good riddins!)
2003 K1200LT - Black (for sale)
2005 K1200LT - Ocean Blue Metallic
rdepas is offline
I need a tail light replacement bulb number DanDiver K1200LT 18 Apr 30th, 2013 6:05 pm
Why Error Light on BMW Charger Comes On ronk1200lt Batteries, Chargers, & Electrical 4 Oct 6th, 2010 6:15 pm
How to Replace a HID Bulb? hschisler Lighting 34 Jun 25th, 2008 10:29 pm
Forum Humor Sunderland Humor 1 Nov 8th, 2007 8:18 pm
Map and Trunk Light Bulb Question Skozar K1200LT 8 Mar 30th, 2006 7:43 pm
