2006 K1200LT Gear Shift Sticks! - BMW Luxury Touring Community
post #1 of 13 Old Jul 11th, 2006, 10:23 am Thread Starter
9771's Avatar
Question 2006 K1200LT Gear Shift Sticks!
Hi,
I have a new 2006 LT with about 1600 miles on it. Recently the gear shift sticks, that is it will not rachet the change shaft so I cannot change gears.
It usually does this when I down shift, and won't allow shifting into or out of 2nd gear. I can always shift up. The gear shift lever actually stays down and will not return to the center position.
I can lift it up with my toe and then shift down so I don't think it is a problem in side the transmission.
I have talked to my dealer about it and we have lubed the linkage externally. It will operated just great until the temp gauge is above center. This usually happens in traffic. On a recent trip I had a problem with it in town but once I was out at highway speeds and the engine temps went down it works just fine.
Now for my question--
1. Has anyone else had this problem?
1a. If so what did you do to fix it?
Thanks for any help in advance!
9771 is offline
post #2 of 13 Old Jul 11th, 2006, 10:52 am
Sounds like a lube issue as there is no way to do it "externally". You have to take it apart to lube it.
But the always upshift won't down shift is a concern. That sounds like something else.
post #3 of 13 Old Jul 11th, 2006, 11:29 am
When I installed the upgraded shifter linkage I had a somewhat similar problem. When shifting up or down, the shift linkage would not return to the 'neutral' position. By this, I mean I would have to lift up of the shifter with my toe to completely engage the next gear. After playing with it for a while, I finally lubed all of the ball studs and made sure that the linkage was correctly aligned. It's really not hard to lube the linkage, especially after the first time.
No problems since.
Hope this helps.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #4 of 13 Old Jul 11th, 2006, 12:41 pm Thread Starter
9771's Avatar
Thanks Alan.
That sounds like my problem. I will get my tech to look at it a little harder. I think it is a lube problem or something is too tight.
I'll keep you posted
9771 is offline
post #5 of 13 Old Jul 11th, 2006, 3:58 pm
Texas42's Avatar
I think I would have them check the clutch adjustment, just a suggestion. Upshifting can be done without the clutch being engaged fully but downshifting especially 2nd and 1st is not the case. (IMHO)
--Bo
2013 Magma Red R1200GSA
2012 Candy Apple Red R1200R
2006 Graphite K1200GT (sold)
2002 Titan Silver LT (sold)
Don't Panic!
Achtung! böse Eichhörnchen!
Texas42 is offline
post #6 of 13 Old Jul 12th, 2006, 1:24 pm Thread Starter
9771's Avatar
Update*******
I took the bike to my dealer, my local hang out as well, yesterday and it just so happens that the BMW regional Service Manager was there making the rounds. I told him about the problem and he suggested that since it was so new that there was a part the is internal to the transmission that may have a burr or caught one and that is causing the problem. He told my service tech to change the trans-fluid, then run it for a few miles, then change it again.
He told me that he has seen this problem before and the fixed it.
After the first change it seems to work a lot better! I also switched to synthtic oil.
My tech wants to change it again on Saturday.
I'll let you know how it turns out.
9771 is offline
post #7 of 13 Old Jul 17th, 2006, 1:19 pm Thread Starter
9771's Avatar
Last Saturday my local shop changed the tranny oil again. This has not fixed the problem, in fact it is getting worse. Now it will stick in both directions.
Sunday morning I was greeted to a puddle of tranny oil under the bike. I checked to see where it might be coming from, it was not the drain plug or anywhere near it.
Very heart broken. It has barely 1700 mile on it, now it may need a new tranny. It is under warranty of course, but my dealer is four week out on maintenance appointments. Maybe I should have bought a Honda.
9771 is offline
post #8 of 13 Old Jul 17th, 2006, 1:36 pm
Texas42's Avatar
Maybe it's a "Lemon" and they should give you a new bike. Do you have a "Lemon Law" in Illinois?
--Bo
Don't Panic!
Texas42 is offline
post #9 of 13 Old Jul 18th, 2006, 9:43 am Thread Starter
9771's Avatar
Not sure about lemon law. It may be premature for that, after all they have told me that they will replace the transmission under warrenty. I just hope that is where it ends!
I love this bike and I'm not ready to give up on it yet.
The dealer here, Twin City BMW Motorcycles has been very very helpful. I would recommend them to everyone for service!
Too bad they don't have enough techs to cover their business. Twin City is a car dealer that decided to get into motorcycles. The owner is pretty clueless about motorcycles and their owners. The manager of the cycle shop is doing his very best as well as the rest of the staff. I appreciate their efforts on my behalf even though the owner may not.
9771 is offline
post #10 of 13 Old Jul 18th, 2006, 11:14 pm
BecketMa's Avatar
You been able to find where it is leaking from?
BecketMa is offline
post #11 of 13 Old Jul 19th, 2006, 8:19 am Thread Starter
9771's Avatar
**********Final Post on this subject***********
Yesterday I spent the better part of the day at the BMW shop trying to resolve my problem.
There are no transmissions in the US. My dealer was not sure if or when they would be able to obtain one. This left me less than satisfied. To make things worst there was no one present who deserved my rath.
I was planning to ride about 700 miles on a short trip to southern Illinois the second week in August.
Disgruntled and disillusioned I returned home. I decided to check the transmission fluid level to make sure I had enough. After removing the left rider peg bracket, I found the source of the leak. There was a stream of fluid coming from the transmission fluid fill hole. The cap was not even finger tight! I tightened the cap which stopped the leak.
Next I decided to take a look at the gear selector. My contention has always been that there was some binding in the change linkage. My focus was the pivot that is attached to the transmission case. I turned the bolt which caused it to loosen. There is a locking nut on the bolt so there is little chance that the nut will come off. This relived the binding on the change linkage. I rode the bike to get it good and hot to see if the gear shift would stick, it did not!
To sum up. I was correct in my assessment of the binding problem in the change linkage. We could have avoided all of this "drama" by some simple troubleshooting and not jumping to conclusions which lead to "over working " the problem.
Later today I will call the dealership and let them know I don't need a new transmission, or maybe I'll just pencil them in for the 1st of the month.
9771 is offline
post #12 of 13 Old Jul 19th, 2006, 8:44 am
Shawn,
Good find. Same "problem" started creeping up on my 2005 when it neared the 12k PM(preventative maintenance).
Being the "banished" HD rider I am, I figured I'd take the shift assembly apart, clean, lube and reassemble... so I did that... man, what a difference! I found several potential "binding" points and resolved them.
Result: slick shifting.. good smooth, "feel" to the shift mechanism after remounting left peg mount plate to bike.. it's amazing to see how it "feels" by hand, toggling up and down on the shift lever "before-n-after"..
I think the BMW rep was trying to head off a big warranty charge-back. The "good news" is you now have a well "flushed" tranny!
As a "technician", once the guys above my "pay grade" took ownership of a problem, it was theirs. If the BMW "Rep" told me to wash the bike to fix the tranny, I'd privately express my thoughts on the topic, then wash the bike because at that point the BMW Rep "owned" the problem... especially if it was not a "safety" issue. That's a whole different situation.
In your case, it was clearly a potential "safety" issue. If you can't shift to merge with traffic that could be a problem... especially if you run out of throttle =)
J.M.J...
Dcn Channing
post #13 of 13 Old Jul 19th, 2006, 2:33 pm
Texas42's Avatar
Does that mean that they filled the transmission on the side stand and it leaked when you had it on the center stand? How could they get too much in there?
--Bo
Don't Panic!
Texas42 is offline
2006 K1200lt Gps Tomakazie GPS 10 Jul 31st, 2006 4:34 pm
2006 K1200LT Problems! Need Advice!! Cchild6898 K1200LT 41 Jul 11th, 2006 12:47 pm
