Help with integrating stereo to intercom system? - BMW Luxury Touring Community
post #1 of 3 Old Jul 5th, 2006, 7:40 pm Thread Starter
surfran's Avatar
I have tried to integrate my stereo into my new IMC MIT-100 intercom system by tapping into the rear speaker wires with capacitors, isolation transformers and 3.5mm plug as shown in the diagram from Bob Weir.
I am having trouble in that the sound is crackling and fading in and out. I am not sure if I was supposed to remove the rear speakers from the equation or if I installed the Caps backwards, but would like some feedback so hopefully I can remedy this and enjoy music in the headsets rather than always blasting it from the front speakers.
Here is the schematic that Bob has posted in another thread to help someone. I assumed the capacitors would go with the positive (long lead) toward the transformer and the negative (short lead) toward the speakers. Assuming that is correct I don't think I did anything wrong unless the speakears should be taken out of the equation when using the headset?
Any help would be appreciated.
2000 Canyon Red "Crimson Cruiser"
40,000 miles grinning, and counting....
BMWMOA # 131660
surfran is offline
post #2 of 3 Old Jul 5th, 2006, 9:30 pm
JPSpen's Avatar
Wow
Didn't look at it too close buy why would you want to build something when you can just pick up one of these.. Looks like you might need non-polarized capacitors or something like that.. Here's what I found....
www.davidnavone.com I used his NE-7 adaptor. and connected it to the speaker wires at the stingray. Then went to an adapter cable from the RCA to the intercom...I adjusted the trim pots so that the volume was similar on the speakers and the headset in the garage. So going down the highway you won't blow your speakers and the headset will be plenty loud. Still works fine if you are not on the headset.
It was 19.95 and I didn't have to build anything.
Good luck
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #3 of 3 Old Jul 6th, 2006, 6:45 am Thread Starter
surfran's Avatar
Sure now you come in with an easy plug and play.......but I'm invested now so I will try and make this work for a short time.
BMWMOA # 131660
surfran is offline
Intercom Issue DougLaird Intercom, CB, & 2-Way Radios 3 Jan 14th, 2007 10:50 am
Backchat Vixen Intercom System - Simple/Low-Tech Solution eljeffe Intercom, CB, & 2-Way Radios 0 Apr 24th, 2006 7:27 am
Trying to make sense of all the Intercom Choices Toolman Intercom, CB, & 2-Way Radios 9 Apr 20th, 2006 6:46 am
k1200lt stereo system jgrenga K1200LT 1 Mar 14th, 2006 9:19 pm
J&M Intercom System rodgtc Intercom, CB, & 2-Way Radios 18 Mar 2nd, 2006 9:49 pm
