Screw Garu's. Where does this one fit ? - BMW Luxury Touring Community
post #1 of 11 Old Jun 26th, 2006, 4:33 am Thread Starter
Miles of Smiles
Hilton's Avatar
Question Screw Garu's. Where does this one fit ?
Removed the plastic ( sides; top & bottom, and lower front ) to clean Jenna properly the other day and the 10mm screw shown in photo #1 fell out. Doesn't seem to be a panel screw (12mm #2 photo) as it has a different length and no point/cone start to the thread. Fell out from towards the front on the left hand side. Know it's not from the plastic as they are all in place.
TIA
ID:	4661   Click image for larger version
Name:	T-25 12mm panel screw.jpg
Hilton is offline
post #2 of 11 Old Jun 26th, 2006, 9:27 am
Senior Member (ret.)
RaffyK's Avatar
That one looks like the center screw where the mirrors attach. The 3 mirror studs and a center screw attached to the sub-bracketry.
Raffy
RaffyK is offline
post #3 of 11 Old Jun 26th, 2006, 9:40 am
RaffyK's Avatar
I might be wrong. I believe the one I mentioned has a pointed end. But check anyway. If not that, I am wondering where as well.
Raffy
RaffyK is offline
post #4 of 11 Old Jun 26th, 2006, 11:31 am
Another guess: Could be one of the screws that retain the fan shrouds. I don't remember if those were Torx or Hex screws on my bike from the factory, I had replaced them with Torx if they were not already.
post #5 of 11 Old Jun 26th, 2006, 4:26 pm Thread Starter
Miles of Smiles
Hilton's Avatar
Smile Screw Loose
Thanks for the clues. I guess I can remove the plastic again and explore. I was just hoping it was not from under the nose cone. That comes off after returning from the CCR. Cheers
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #6 of 11 Old Jun 26th, 2006, 5:36 pm
JPSpen's Avatar
Service drop?
Something else to think about. If it's been service by anyone but you ........
Sometimes a tech will drop a screw... It's easier to just grab a new one than to go after the one that was dropped. Especially if it fell into the "hell" zone. You may have an extra screw now...
Murphy's law of reproduction. You know when you take something apart and then put it back together, you sometimes have a piece left over.. Murphy says if you do that enough times you'll have two of them....
Don't fry your brain worrying about it....
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #7 of 11 Old Jun 26th, 2006, 11:37 pm
I would also say the fan shrouds but on my 02 there is also a washer on it and it is a hex head.
ltride is offline
post #8 of 11 Old Jun 27th, 2006, 1:48 am Thread Starter
Miles of Smiles
Hilton's Avatar
Smile Screws, Washers, and now Plugs
Had a good look around today under the plastic. Not the fan shroud screws as they are in place (easy to see from the exhaust end, and just to note, they have pointy ends) Looked long and hard under the nose cone area with a small mirror, but nothing obvious. Might just be that one fell down during assembly as per previous post. Time will tell. Whilst taking off the rear tail light assembly a double washer (joined together when electroplated) fell out and I'm quite sure it doesn't belong in there! We are talking about a brand new bike here, and so it should be as good as it gets. Per factory QC.
I did notice that I have an extra electrical conector adjacent to the #2 injector. Cable length would only allow to reach to #2. Same as the ones on the injectors. Any ideas anyone? (I thought may be due to differences in country specifications)
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #9 of 11 Old Jun 27th, 2006, 5:01 am
US specification LTs with the Charcoal Cannister under the trunk use that connector for the solenoid valve to the vacuum lines to the throttle bodies for cannister purging.
post #10 of 11 Old Jun 27th, 2006, 5:48 am Thread Starter
Miles of Smiles
Hilton's Avatar
Smile
Many thanks David. Cheers
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #11 of 11 Old Jun 27th, 2006, 1:06 pm
GBarnes's Avatar
And if you hook that connector to an injector, the bike will run like crap (DAMHIK)
GB
GBarnes is offline
BMW Navigator - security screw ytk GPS 9 Jan 8th, 2009 5:39 pm
Oil Filter Cover screw shipment delayed dshealey K1200LT 6 Jun 10th, 2006 4:57 pm
battle hymn of the republicans KBandit Humor 29 May 4th, 2006 8:23 am
Windscreen Screw Size TandemCyclist K1200LT 7 Feb 1st, 2006 10:48 am
Factory Top Trunk Luggage Rack Install Crestwood330 K1200LT 7 Jan 2nd, 2006 8:57 am
