Finally went south....crown bearing - BMW Luxury Touring Community
post #1 of 3 Old Jun 24th, 2006, 9:04 pm Thread Starter
OKUIII's Avatar
Smile Finally went south....crown bearing
Well it finally happened......the imfamous crown braring went south. I first noticed the bike was really shaking on the center stand and that when I checked the air in the rear tire, it was getting hard to turn it. I mean that turning it was not smooth. It would go around maybe 1 time and stop. But it sounded like the rear rotor and the dragging disk pad (EBC). Well, I am up in San Jose now and was in a quandry as to go back to Irvine or not. I had noticed also on the wat to San Jose, the gas mileage was dropping from ~47-50 down to ~40-42. Again I thought it was the rotor drag.
I had called Pete at San Jose BMW for the 48k modified service, valve check, radiator flush, clutch flush, and brake flush. I have done all the other fluids and filters before I left. I asked Willie, the tech, to check the rotor and he showed me after removing the tire, the rotor was fine and there was rubber on top of the drive shaft and weeping all over the rear drive. The tire had been rubbing against the shatf housing for some time which could be part of the reason the fuel mileage is going down. We looked at the gear oil and no significant amounts of metal shavings. He cleaned out the rear drive and put in regular BMW gear oil.....I asked if he put in synthetic and he said no. He said it made no difference and that after 600 miles I could go back to synthetic. Is this correct? Why can't we put synthetic from the start?
Since I was far away from home, I decided to change the crown bearing for preventive measures along with putting on new rear brake pads. He checked the valves and all were within spec. I asked if they were on the tight side or the loose side......he said the were within spec! Did not take more than 15 minutes...which I thought a little unusual. How long does it take to check the valves anyway?
I guess the best thing out of this is that I did not have a catastraphic failure which would have really been expensive. I asked about warranty, goodwill....out of luck...over 3 years...and have 54,876 miles...But they did say I was covered for two years on parts and labor. Maybe I can get home without a new failure.
Botton line for me was I have kept with this board and have kept a keen watch...just waiting....and it finally happened...but you guys gave me the knowledge as to what to look for and the sympyoms.
Thansk to everyone who has posted on rear failures.
OKU
O. K. Upchurch III
Irvine, California
2016 R1200gs
2000 K1200LT (Best Bike #1)
1997 R1100RT (Best Bike #2)
1995 K1100LT
1990 K75RT
OKUIII is offline
post #2 of 3 Old Jun 24th, 2006, 11:18 pm
If all the Tupperware was already off I suppose a good tech good check the valves in 15 or so minutes. There isn't much to it
mjordans2000 is offline
post #3 of 3 Old Jun 26th, 2006, 9:09 am
Steve_R's Avatar
Only takes me about 15 minutes when I've got all the tupperware off and that includes filling out the valve spec sheet to keep with my other paperwork. YMMV
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
Final Drive murray K1200LT 22 Sep 28th, 2008 9:02 am
Just got a "New" 19-ball Crown Bearing from Chicago BMW this week? Holy Cow K1200LT 29 Oct 19th, 2007 11:58 pm
Crown Bearing Replacement Complete scott122262 K1200LT 2 Mar 1st, 2006 6:54 pm
Crown bearing question scott122262 K1200LT 4 Feb 28th, 2006 8:31 am
Crown Wheel Bearing Photos rjking K1200LT 6 Feb 19th, 2006 2:00 pm
