Where do I get the front "junction block" for a Speigler brake line install? - BMW Luxury Touring Community
post #1 of 14 Old Jul 12th, 2014, 1:43 pm Thread Starter
txvoyager's Avatar
My lines arrived this week and ineagerlymdove eagerly dove in this morning...
The banjo bolts, etc. Take a bit of effort to get moving, but my real hang-up is that I don't have a way to join the front lines. The original ones are joined by a permanently-connected aluminum block. How do I get my lines to connect like the ones in this pic (from this forum)?
Kevin Sawatsky, Kingston, TX
IBA #487 (IBR 2013, 48 Plus!, B2B Insanity, 10 Tenths, SS5000, 50CC, BBG, SS1000...)
'12 Yamaha Super Tenere
'05 BMW K1200LT
'03 Yamaha FJR
'01 BMW K1200LT (early version) - Sold
'99 BMW K1200LT - Sold
txvoyager is offline
post #2 of 14 Old Jul 12th, 2014, 2:28 pm
oldmopars's Avatar
Re: Where do I get the front "junction block" for a Speigler brake line install?
While this is still on my "to-do" list I see 3 lines in the picture of your lines that look like they will thread into the junction block T" like the ones in the picture. Starting from the top of your picture it looks like lines #2, #3 and #4 are what you are wanting.
However, it does appear that you are missing the "T". I would think that this should have come in the "Kit". Call Speigler and see what they say.
oldmopars is offline
post #3 of 14 Old Jul 12th, 2014, 3:46 pm
Old Slow Guy in A Fast Car
katnapinn's Avatar
You use the one already on the bike. Just remove the 3 old hoses from it & install the 3 new ones.
Stevie Shreeve
katnapinn is offline
post #4 of 14 Old Jul 12th, 2014, 4:13 pm Thread Starter
txvoyager's Avatar
Originally Posted by katnapinn View Post
Just remove the 3 old hoses from it...
Any tips on how Id do that? I have the "crossover" removed -- it has a nut to turn -- but I sure don't seen any hope of removing the other two... and neither do my vice grips!
'05 BMW K1200LT
'03 Yamaha FJR
post #5 of 14 Old Jul 12th, 2014, 4:20 pm
No you will not. They left out the aluminum block from your set. That crossover tube will go into it. You cannot re-use the stock one. I just got mine this week and it had a block, not the bolts like your set has, just the block and washers. Looks like they threw the wrong "bag of goodies" into your kit. Give them a call and they will fix it.
post #6 of 14 Old Jul 12th, 2014, 4:45 pm
Unhappy Re: Where do I get the front "junction block" for a Speigler brake line install?
Yep! Like JZ says, they left out the block. Put my set on last week and it came with a new block for the three lines to attach to just like the original. Bummer. Give them call on Monday--I'm sure they will get one out to you.
msas89 is offline
post #7 of 14 Old Jul 12th, 2014, 4:57 pm
copperstatetour's Avatar
Just confirming that my set came with the block (for both my LT and my C) so they just forgot to include it with your set. Call them up and let them know, I am sure they will get you a new one.
-Steve
2009 BMW R1200RT
2000 BMW K1200LT (was supposed to be replaced by above, but can't keep above running long enough to replace
2000 BMW R1200C
copperstatetour is offline
post #8 of 14 Old Jul 12th, 2014, 6:56 pm
r75
I would not recommend using the factory (BMW) T block due to risk of galvanic corrosion.
Bill
1999 K1200LT
2002 K1200RS
r75 is offline
post #9 of 14 Old Jul 14th, 2014, 2:18 pm Thread Starter
txvoyager's Avatar
Originally Posted by jzeiler View Post
They left out the aluminum block from your set... Give them a call and they will fix it.
Yep... Speigler is shipping one out.
Another related question... Any tips on removing the banjo bolt just under the top of the rear shock? FYI, I have an Ohlins in there and really don't want to remove it if there's another way...
'05 BMW K1200LT
'03 Yamaha FJR
post #10 of 14 Old Jul 14th, 2014, 4:03 pm
katnapinn's Avatar
When I did mine I remember removing the top bolt on the shock. Letting the final drive drop down & moving the top of the shock back out of the way.
BTW sorry for the miss information on the "T" block. I did the lines on my old LT 6 or 7 years ago & thought I had reused the "T" block.
Stevie Shreeve
post #11 of 14 Old Jul 15th, 2014, 12:23 pm
Any suggestions for getting the banjo out that is under the steering head? I can get a long and a short hex on it several ways but it is so tight and there is so little room that the tool flexes what little room there is w/o breaking it loose. Saw on a write up of the earlier models that you could reach it from above but didn't know if that was the case on the 05 and up. Would taking the nose off give me better access?
_____________
Kim Thomson
Motorcycle Cigar Smoker
85 K100 Standard - Big Red
Gone, but not forgotten...
85 K100RT - (wore out)
alabrew is offline
post #12 of 14 Old Jul 16th, 2014, 11:32 am Thread Starter
txvoyager's Avatar
[QUOTE=alabrew;1022881]Any suggestions for getting the banjo out that is under the steering head?QUOTE]
I removed the nose to get better access. That was not an easy bolt to break loose, but leverage is your friend. I couldn't get enough without removing that part of the tupperware. Since that is where my leak occurred, I also wanted to inspect for and clean any remaining brake fluid.
'05 BMW K1200LT
'03 Yamaha FJR
post #13 of 14 Old Jul 18th, 2014, 12:28 am Thread Starter
txvoyager's Avatar
Yep... definitely need this part in the Speigler kit. Now to fill and bleed the lines and sew everything back up...
'05 BMW K1200LT
'03 Yamaha FJR
post #14 of 14 Old Jul 18th, 2014, 12:34 am
...and just a little late for you, Kirk's just posted a video on changing old lines to Spieglers. Well done again Kirk!
The Front Brake FrankNitti K1200LT 23 Oct 19th, 2012 12:38 am
front brake line ...grrrrrr ! wolfflow K1200LT 0 Aug 12th, 2011 4:46 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
Is it OK just to use front brake only? JoyfulSoul K1200LT 62 Mar 5th, 2006 9:03 pm
