New and strange noise - BMW Luxury Touring Community
post #1 of 6 Old Jun 22nd, 2006, 11:34 am Thread Starter
ltcommuter's Avatar
Here's one for all you diagnosticians out there...
Occasionally on start up and only when the engine is warm I hear a very rapid knocking sound lasting about 2 seconds. I can consistently replicate that sound if I bring the bike to a quick stop with the clutch engaged until the last second. In this later case the sound persists for 4 to 5 seconds and stops if I goose the throttle.
A friend mentioned it could be the chain tensioner which hasn't EVER been replaced. I now have 170k miles on the bike.
Thoughts?
Cheers!
Bob Bacon
El Cerrito, (Northern) CA
'15 GTL-E in White
'09 LT in Blk "Weave II" 120k miles before it was totaled
'00 LTC+ in CR "Weave" 240k miles before it was totaled
MOA IBA HDDC CRS
Life is not measured by the number of breaths we take but by the moments that take our breath away.
ltcommuter is offline
post #2 of 6 Old Jun 22nd, 2006, 1:52 pm
Thoughts?
Cheers!
I'll go with your friend (if Grif sides with him/her too!!!). 'Sides, you got your monies worth with that tensioner!!! Time to give some of it to your dealer!! Or invite Shealey to drop by and fixit - he's a pushover for fondling an LT!!!
post #3 of 6 Old Jun 22nd, 2006, 1:57 pm
He can 'fondle' my ride any time he wants! I won't tell.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #4 of 6 Old Jun 27th, 2006, 9:14 am Thread Starter
ltcommuter's Avatar
Advice taken
I've set an appointment for this Friday with San Jose BMW to replace my chain tensioner (since Shealey lives too far away ).
While they're in that deep (5 hr job) what else should be replaced after 170k miles?
TIA
Cheers!
Bob Bacon
'15 GTL-E in White
MOA IBA HDDC CRS
post #5 of 6 Old Jun 27th, 2006, 11:32 am
DavidTaylor's Avatar
That's all on the front of the motor, right? If they pull the valve cover might as well have them check the valaves and adjust if needed. How long since you flushed and refilled the radiator? I'm guessing they might have to pull a hose, but if not they'll be right there while they're working on it.
Oh yeah, since they'll have the side covers off why don't you have them bolt on one of these.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #6 of 6 Old Jun 27th, 2006, 2:15 pm
TIA
Cheers!
Make sure they check the tensioner cylinder by blowing air into the oil passage hole and working it back and forth to be sure there is no sticking.
At 170,000 miles I would probably replace the timing chain if already in there. Not likely to be worn that much, but it could be stretched enough to be putting all the load on 1-2 teeth of the sprockets. Replace the front seal in the timing cover also. At 170,000 miles any pre-emptive strikes you can easily make may save you repeat teardowns or worse later.
