05 & 06 Speedometer - BMW Luxury Touring Community
post #1 of 12 Old Jun 21st, 2006, 12:49 pm Thread Starter
Gold Supporter
Lonewuff's Avatar
05 & 06 Speedometer
I have read the threads to fix for the older LT's speedometer, but am wondering if anyone has tried it on an 05 or 06, or if there is a different fix.
I had a Trooper pace me with radar and found my 06 speedometer was 10% off. I showed the results to the dealer and got the expected response "Oh, they are all that way."
Jerry
2008 FLHTCU White Pearl
Lonewuff is offline
post #2 of 12 Old Jun 21st, 2006, 1:22 pm
The only fix so far is to buy a GPS and use that (at least that is what I did).
One person did disassemble the unit and removed the pointer and placed it back on below the zero line and it actually worked pretty well. I find the 3.33 mile tick marks rather absurd and hard to decipher (where is 55?) so I use the GPS. There is no "jumper" to fix this one.
post #3 of 12 Old Jun 21st, 2006, 1:24 pm
Yes...almost EVERY motorcycle I've ridden has always had an inaccurate speedo. No offense, but this is NOT just a BMW issue. Honda does it. Kawasaki does it. Suzuki does it. All from personal experience.
YES, there is a fix. Take the needle off the spindle and move it over one notch. Mark Neblett posted on this several months ago...maybe longer. Do a search on "Speedometer Correction". You'll be amazed at what you find.
post #4 of 12 Old Jun 21st, 2006, 2:03 pm
Gold Supporter
Smile 05 and 06 Speedo correction
Jerry, along with Mark Neblett, I fixed the error on my 05 LT speedo. You will need to do some "tupperware" removal and eventually remove the instrument panel face (held on by, I believe, nine small Torx screws). DO NOT TOUCH THE UNDERSIDE OF THE INSTRUMENT PANEL IN ANY MANNER SINCE IT HAS A VERY FRAGILE COATING ON IT TO PREVENT FOGGING...IF YOU FOR SOME REASON GET ANY LINT OR OTHER DEBRIS ON THE REAR FACE, OPT FOR USING A BLAST OF CLEAN AIR FROM AN AEROSOL CAN SUCH AS FROM RADIO SHACK TO CLEAN IT.
Once the instrument panel face is removed, use two ninety degree bent tools (positioned 180 degrees from each other) such as picks (available from hardware stores) to pry the speedo pointer up off its fulcrum. DO COVER THE LT AREA AROUND WHERE YOU ARE WORKING WITH A RAG TO PREVENT LOSING THE SPEEDO POINTER WHEN IT POPS OFF!!!!!!!!!!!!!!
Look at the speedo scale at the "zero" region. Reposition the pointer "counterclockwise" below "zero" exactly the distance from "zero" to the first division encountered above "zero". What you have done is effectively slow down the speedo, at least from a visual perspective at its rest position...yes, it will be below "zero" with the bike sitting still. Carefully re-install the instrument face and all the rest of the "stuff".
Checking the speedo on my LT after the fix revealed that it is now within one or two mph of exactly "dead on" with the GPS and that is excellent!
Terry
TSQUARED is offline
post #5 of 12 Old Jun 21st, 2006, 3:01 pm
Just ridin'
Randy's Avatar
I posted a couple of threads in the old forums describing the new instrumet cluster.
Here
And here
This should help you.
Randy Prade
Aurora, CO
Just ride it!
Meet Riley
Randy is offline
post #6 of 12 Old Jun 23rd, 2006, 3:39 pm Thread Starter
Gold Supporter
Lonewuff's Avatar
I read all these and have one question; If my speedometer is off 10% and the speedometer is in 3.3 mph increments and I move the dial counterclockwise one increment, how will that help me at 80mph when my speedometer says I am doing 88mph? At 80 mph with this fix, won't my speedometer just say I am traveling approx 85 mph or am I missing something in how the fix works? Please keep in mind your answers are going to a guy who could F**K up an anvil.
Jerry
Lonewuff is offline
post #7 of 12 Old Jun 24th, 2006, 12:28 am
dmatson's Avatar
On my 05' the speedo is only off 3 to 4 mph when i check it against the GPS (2610) at most speeds. Last week on a trip I took it up to 120 on the speedo and the GPS said 117mph.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #8 of 12 Old Jun 24th, 2006, 9:25 am
Thumbs down Speedo
A lot of troble for an insignificant problem!!
Just use the digital speedo in the computer!!
Cyle thru to the speed, hold down on the BC button for a coupla seconds..
the speed will display. This is digital and dead on with GPS.
Cheers
mkmpflugerville is offline
post #9 of 12 Old Jun 26th, 2006, 12:43 am
HornHonker's Avatar
Cheers
Hmmm, I have not seen a Speed option with the computer (05 LT) ?
2011 BMW 1600GTL
2000 BMW R1100R
2008 Burgman 650EX
HornHonker is offline
post #10 of 12 Old Jun 26th, 2006, 6:58 am
lhendrick's Avatar
Cool
I believe what he means is using the average speed function fors an instantaneous speed reading. Not exactly what you are looking for though.
Laurence Hendrick
2008 K1200GT, Dark Graphite (Oh my, so fast!)
2005 LT Ocean Blue (Sold and comfort will be missed, but not the weight)
lhendrick is offline
post #11 of 12 Old Jun 26th, 2006, 2:26 pm
zimbazi's Avatar
Hey Jerry,
I see you purchased the best looking and fastest LT....
Exactly what I call the " Blue Bullet "
Here are the exact speed from my GPS..
In 5th gear @ 3,000 RMP = 55 mph
@ 3,500 RMP = 65 mph
Jeff Goodwin
Austin, Texas
"Life is a coin.
You can spend it anyway you wish,
but you can only spend it once."
zimbazi is offline
post #12 of 12 Old Jun 26th, 2006, 2:43 pm
zimbazi's Avatar
Hey Jerry,
Here are the exact speeds from my GPS..
@ 4,000 RMP = 75 mph
This should cover everything for those dam Cops !
Also for in town In 4th gear @ 4,000 rpm = 45 mph...
My speedo is five miles in error @ 75 mph the speedo reads 80 mph (error +5).
At 125 mph the speedo is reading 140 mph...that is correct +15 mph in error !
I like the GPS because it is easier to read all the way to Max Warp...
Lt should have come with 160 mph speedo !!
Makes you feel faster !!
Being shot out of a cannon will always be better
than being squeezed out of a tube.
That is why God made fast motorcycles ..."
God must love crazy people....Because he makes so many of US !!
Jeff Goodwin
Austin, Texas
"Life is a coin.
zimbazi is offline
speedometer error BLB K1200LT 17 Apr 14th, 2016 2:22 am
Speedometer Question BUGKILLER K1200LT 15 Jun 22nd, 2007 5:13 pm
Speedometer (and other) issues Brian_H K1200LT 6 Apr 22nd, 2006 12:08 pm
Speedometer Fix - Tomorrow Jimbo3 K1200LT 22 Jan 14th, 2006 11:31 am
'03 LTE Speedometer Modification lovetomotor Lighting 7 Nov 16th, 2005 8:46 pm
