my rear rotor is ringing? - BMW Luxury Touring Community
post #1 of 5 Old Jun 21st, 2006, 11:44 am Thread Starter
Question my rear rotor is ringing?
this sounds funny, but my rear brake rotor appears slightly loose. when rolling the bike around tight spots or when rolling to a stop i hear a slight bell ringing sound like the rear rotor is dangling and pinging against the caliper or visa versa.
When I give the rotor a jiggle it seems to have a little play? My gut says the rotor should be imobile. is there an adjustment or other possible thing I am missing?
my 2002 has only 6,500 miles. I just swapped out the pads to kill the squeal. No brake warning lights has me thinking everything is OK, but I have a couple of 3K trips coming up very soon and want to make sure I'm ok?
any thoughts appreciated...
KYchris02 is offline
post #2 of 5 Old Jun 21st, 2006, 12:27 pm
Your gut is wrong. Your rotors should "float".
post #3 of 5 Old Jun 21st, 2006, 1:36 pm
"Float" as in front rotors - ok.
Clang like cow bell - not ok.
Until you hear it, it is hard to believe a $15,000 motorcycle could sound like this. I have one myself, and mine was supposedly replaced once before.
Perhaps someone can get mine modified to fit on a new GT so that the sound can be properly appreciated. No need for horn or loud pipes - just hit a little bump and heads will turn.
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #4 of 5 Old Jun 21st, 2006, 2:48 pm
RR discs on LTs
all LT rear discs(in particular) have some play-some to the point of making clunking noises. I've replaced them when they made too much clunking noise-in response to a customer complaint, but sometimes after a little wear the clunking will return. this is only a problem if the disc/mounts wear to the point that there is a lot of play. at that point replacement is necessary. have a look at a brand new one on a showroom floor-same thing. also use updated rr pads on all LTs to minimize noise-new pads have rubber coated backing plate-old pads no plate.
retiredbmwtech is offline
post #5 of 5 Old Jun 21st, 2006, 5:23 pm
Smile my rear rotor is ringing?
Had the same issue with my 03, thay replaced it at 32K under warranty, rang/rattled like a bell.
Bob R.
brasters is offline
Very specific wiring question - Rear Speakers midwilshire Intercom, CB, & 2-Way Radios 11 Nov 21st, 2011 4:37 pm
rear drive oil leak? louatlvc K1200LT 4 Jun 11th, 2006 7:17 pm
Rear END????? kip K1200LT 13 May 24th, 2006 8:32 am
Replacement of rear shock suspension unit PhillWard Australia, New Zealand, and AsiaPac 3 Jan 17th, 2006 5:01 pm
