Should I add coolant? - BMW Luxury Touring Community
post #1 of 6 Old Jun 18th, 2006, 7:38 pm Thread Starter
My '05 LT seems to run at normal temp, even on hot days. But when I check the coolant level in the left case, I don't see anything. Bike is cool and on the centerstand.
1. Should I be adding coolant, even the though running temp is normal?
2. What type of coolant does it use? I couldn't find this info in the owner or maintenance manual.
flyby is offline
post #2 of 6 Old Jun 18th, 2006, 8:02 pm
Smile
Don't become overly concerned with a low 'overflow' resevoir. Its been my experience that any additional coolant added to this tank will only evaporate due to its close proximity to the exhaust pipe. So long as your two radiator tanks are full with a 50/50 mixture of distilled water and 'long life' no silicant coolant you should be okay for at least 24,000 miles and realistically 100,000 miles. Hope this helps...
Bruce Harris, Jr.
Burlington, NC USA
1995 Harley-Davidson FLHTCUI Anniversary Edition
2005 Bushtec Turbo +2
BruceHarrisJr is offline
post #3 of 6 Old Jun 18th, 2006, 9:57 pm
I thought mine was empty also until I removed the cap & stuck my finger in it. The level was all the way to the cap & the coolant is clear.
Big_E is offline
post #4 of 6 Old Jun 18th, 2006, 10:19 pm
Originally Posted by BruceHarrisJr
-------------------So long as your two radiator tanks are full with a 50/50 mixture of distilled water and 'long life' no silicant coolant you should be okay for at least 24,000 miles and realistically 100,000 miles. Hope this helps...
Bruce, this was discussed in detail about a year ago, and I also had stated "no silicates", but when I looked at the BMW coolant I got from the dealer, it has silicates.
Picture of the lable attached.
post #5 of 6 Old Jun 19th, 2006, 4:24 am
Miles of Smiles
Hilton's Avatar
Smile Nitrite or Silicates ?
Hi David, just a question about additives. Had a look at the 99 - 01 manual and it says "Nitrite Free" My BMW concentrate also says "Free From Nitrite"
No mention of silicates, but no further info on lable. I gather the nitrites are due to corrosion issues with the alloy, but what do siicates do? Sorry if I missed it during last year. Cheers
ps. Short trip (400 kms) today, Jenna purrs. Rena loves it.
Hilton is offline
post #6 of 6 Old Jun 19th, 2006, 8:25 am
The peep hole in the side case is worthless - I can't see a thing. Pop the seat up and open the cap to the overflow tank and shine a flashlight in there - if you see fluid (mine is light blue) you are good to go.
Equivalent Coolant Tbird K1200LT 21 Sep 2nd, 2012 8:34 pm
Changing K1200LT Coolant? dasBike K1200LT 9 May 6th, 2008 6:42 am
Coolant philjohn K1200LT 10 Mar 2nd, 2006 7:14 am
Coolant overfilling the reservoir tank TimVipond K1200LT 12 Jan 9th, 2006 8:07 pm
Coolant loss Q Rondeau K1200LT 1 Oct 24th, 2005 11:17 am
