Put the big girl back together - BMW Luxury Touring Community
post #1 of 5 Old Jun 13th, 2014, 11:35 pm Thread Starter
TeddyTelco's Avatar
Put the big girl back together and put some gas in the tank and started it briefly. all the lights worked the radio is working seemed to run fine. The low gas light is on. But I noticed the gas gauge and the temp gauge were not showing. Is this normal? I changed the coolant and replaced the outside gas lines and quick connects...
2009 BMW K1200LT "Shelly"
2002 Honda VT1100 Sabre Sold
1979 Harley Davidson FXEF 1340 Sold
1975 Norton 850 Commando Sold
TeddyTelco is offline
post #2 of 5 Old Jun 14th, 2014, 3:52 am
Axle's Avatar
Re: Put the big girl back together
coolant temp takes a while to come up, at least 5 minutes, make sure you have no air locks in the system, If the low gas light is on then the gauge will read pretty low if at all, or you didn't plug the connector on the top of the tank next to the filler hole, under the the stingray
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 5 Old Jun 14th, 2014, 6:27 am Thread Starter
TeddyTelco's Avatar
how do you check for air lock? Wouldn't the low gas light only work if gas sensor is plugged in? I tried John Zs screw driver in the cross hose trick to burp while refilling
post #4 of 5 Old Jun 14th, 2014, 8:19 am
as long as you have coolant in the overflow bottle you should be fine, just use your hand to monitor rad temp at top when she is running, it will start to warm up, hoses will warm pretty quick, not hot warm, I always run the bike with the cap off until I feel the fluid getting warm and it stays at the bottom of the filler, do not rev the engine with cap off or there will be antifreeze everywhere. Coolant gets warm pretty quick on all these newer motors. With the cap on once she gets hot enough to turn the fans on expansion will force some fluid into expansion bottle and any small amount of air will go with it, fluid gets sucked back when she cools
at 32 degrees F my cylinder head, not valve cover, is warm to touch in 90 seconds, she warms up fast not like the K100 and K1100 which take quite awhile.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #5 of 5 Old Jun 15th, 2014, 1:57 pm Thread Starter
TeddyTelco's Avatar
It was 1st tear down Jitters. The bike came thru with flying colors. Just got back from weekends ride. Thanks to all..
Back Protectors meese Rider's Gear & Luggage 21 Oct 10th, 2017 3:48 am
A little girl............ gunny Humor 3 May 19th, 2009 6:32 pm
Back from the "Darkside" SDDinNH RT Series 4 Apr 24th, 2009 11:28 am
Back on a BMW after a major crash on my LT Crestwood330 Bike Talk 17 Nov 9th, 2007 8:19 am
