Trunk strap hinge control thing-a-mabober - BMW Luxury Touring Community
post #1 of 4 Old Jun 16th, 2006, 3:30 pm Thread Starter
BallsCasten's Avatar
Sorry for the repost.
The strap that keeps the trunk from opening to far has come off the pin. The strap is wound up in the roller. How do I fix?
I had seen the thred for this a while back but cant find it.
Doug
'05 K1200LT,
My dog is very selective where he will pee, yet he will poop anywhere. In that regard; we couldn’t be more different.
BallsCasten is offline
post #2 of 4 Old Jun 16th, 2006, 9:43 pm
kevincook's Avatar
Red face
The same thing happened to me on my first day of ownership. Welcome to the club.
I think you can find the previous post in the Archive section if you do a search in the old forum.
I just grabbed the strap with a pair of needle nose pliers and then riveted the loop back on the loose end. I'm assuming the same thing happened to yours. I didn't think my spring had unwound too far because it worked well for a couple of weeks. Now the spring won't rewind the strap so I'm going to buy a replacement sometime soon. For now the strap holds the top for me and it doesn't get in the way.
If you do replace the whole mechanism I am pretty sure that I read you need to drill out one rivet and pivot the old one out of the way and then rivet the new one into the first whole. Then you can drill out the second rivet and rotate the new piece into place and put the second rivet in. I think there is a backing plate that isn't accessible and if you drill both rivets the backing plate will fall out of position and then you can't get it.
OK everyone, this is my first post that resembles an answer to someone's question. Did I get that correct or is the answer completely wrong.
I went and found this old thread. http://www.bmwlt.net/ubbthreads/show...w=&sb=&o=&vc=1
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #3 of 4 Old Jun 17th, 2006, 8:11 am
Kevin,
You did just fine. Especially the technique for NOT losing the backing plate. Well done. That is the kind of spirit that makes this board great!!!
post #4 of 4 Old Jun 17th, 2006, 9:00 am Thread Starter
Thx Kevin, I was feeling bad I couldnt find the old post, I know I had read it before.
Doug
'05 K1200LT,
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 3:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 9:38 am
