rear abs sensor ring - BMW Luxury Touring Community
post #1 of 3 Old Jun 9th, 2014, 3:57 pm Thread Starter
mstrquad's Avatar
ok it time for a new rear rotor. i went with ebc and now have old rotor off and have to change over the abs sensor ring. it dose not want to come off.could use some help with the way to get it off. thanks
03 k1200 ltc
mstrquad is offline
post #2 of 3 Old Jun 9th, 2014, 4:32 pm
bob1811's Avatar
Re: rear abs sensor ring
I just replaced mine a few months ago...
You will need to heat up the abs ring a good amount, to expand the metal. I used MAP/propane gas for the job. After you heat it up, use a pry bar to get leverage on the ring (like those Wonder bars by Stanley) and pry it up slowly, while working your way around the ring. It will come off, but not without a little work. Do not hammer the ring out of fear of damaging it. If it continues to be stubborn, you could heat it up and hit the inner rotor with some freeze spray and then pry it up.
When you get the old rotor off, give it a quick wipe down and place it on the new rotor while still warm and the metal is still expanded. It should slip right on without any resistance.
Good luck!
2005 Blue K1200LT
2010 R1200GS
BMW/MOA 94539
bob1811 is offline
post #3 of 3 Old Jun 9th, 2014, 11:51 pm Thread Starter
mstrquad's Avatar
thanks that worked put it all in freezer than heated ring and it came right off.
03 k1200 ltc
mstrquad is offline
LT rear ABS ring removal Problem Rigger394 K1200LT 8 Jan 19th, 2012 7:08 am
rear rotor and abs ring play Stoker100 K1200LT 6 Nov 24th, 2011 3:21 pm
Brake Flush '06 ABS II Hilton K1200LT 15 Dec 19th, 2010 1:01 pm
ABS vs. Rear End Failure Tbird Surveys and Polls 11 Jan 22nd, 2007 9:12 pm
