'99 1200LT Running Hot - BMW Luxury Touring Community
post #1 of 7 Old Jun 8th, 2014, 4:36 pm Thread Starter
I've had my LT for 6 months. As the temperature around Dallas has gotten warmer, the bike temperature rises when I'm stuck in traffic or otherwise around town waiting at lights. I haven't redlined yet but I've come rather close.
When I'm cruising highway speeds the needle stays right where it should, at or just below the midway line.
I went ahead and replaced the coolant (yes a 50/50 mix) and changed the oil/filter but it is still behaving this way.
In order what would you guys check as being the most common problems?
'99 Old Gray Mare
bdavis1 is offline
post #2 of 7 Old Jun 8th, 2014, 4:49 pm
Re: '99 1200LT Running Hot
Read the post at the page bottom here. Mine does the same, and has for 14 years. HTH.
post #3 of 7 Old Jun 8th, 2014, 4:50 pm
'99 Old Gray Mare
It' s normal, as long as the fans come on before red line. The gauge has a greater amount of movement than ones in cars but any vehicle with electric fans does the same thing as long as air conditioning does not have the fans on. The temp sender is not on the motor, it is on the water pump where the temp of the coolant varies more.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is online now
post #4 of 7 Old Jun 8th, 2014, 6:53 pm
STEBS's Avatar
hahahahaha It's normal, I think most of us have heard those words at the dealer on several occasions,
But in this case it is normal just as Gary45 says, my 02 did this, concerned me also at first but if the fans start at or near the red temp line your good to go with no worries. The temp climbs fast just sitting and the temp gauge is pretty sensitive, it almost makes you want to shut it off before over heating. You don't need to do that though.
2015 R1200Rt- Ebony
2005 K1200Lt- Dark Graphite
1978 KZ1000 Ltd- Black
St Clair Shores, Mi
BMWMOA # 185482
STEBS is offline
post #5 of 7 Old Jun 8th, 2014, 8:02 pm
One thing you might check before you settle in with the quick rise of the temp as "normal" is when the fans start make sure that BOTH fans run at same time. One is usually enough but if one stops you will definitely overheat if the second one stops for some reason.
Jack
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #6 of 7 Old Jun 8th, 2014, 9:39 pm
The real danger is the "HOT" light. Here are the spec temps.
post #7 of 7 Old Jun 9th, 2014, 12:54 am Thread Starter
Thanks guys,
I hadn't seen a needle do this on any water-cooled biked. I'll just ride until the engine melts. hahahaha.
bdavis1 is offline
1200LT pulling my hair out!! wkane4 K1200LT 31 Nov 27th, 2011 6:03 pm
center stand motor continues running theoldone K1200LT 2 Jun 17th, 2010 2:19 pm
hot running, summertime running rpeve K1200LT 17 Jul 12th, 2009 1:22 am
Hot wire when motor is running? alstrickland55 K1200LT 8 Jun 8th, 2009 9:08 pm
1200LT vs Harley Street Glide reschwert K1200LT 69 Feb 19th, 2007 2:37 pm
