What is the best brakes for an 05 K1200LT - BMW Luxury Touring Community
 1Likes
  • 1 Post By wrightwaay
post #1 of 6 Old Jun 7th, 2014, 5:44 pm Thread Starter
Hi,
I am thinking that I maybe needing brakes on my 05 K1200LT. I do not know what would be the best pads for this bike. I have put about 6 k on it since I got it. I was not sure if they have been replaced. It has 32k on it right now. Can you give me some advice on this?
05 K1200LT new to me
08 Honda Gl1800 Roadsmith Trike still riding
89 Honda Gl1500 Sold with 205K
dcsorric is offline
post #2 of 6 Old Jun 7th, 2014, 9:17 pm
Re: What is the best brakes for an 05 K1200LT
The stock front are sintered pads and the rears are organic. EBC, Carbon Lorraine make some good pads as well. I still have the original fronts in 05 LT @87 K but I have been through three sets of rears and two rotors.
post #3 of 6 Old Jun 8th, 2014, 1:03 am
I have had the best wear from using BMW pads front and rear.
Clayton
2003 K1200LTE 128k miles and counting
1999 GL1500A
2009 R1200GSA
clayton is offline
post #4 of 6 Old Jun 8th, 2014, 8:53 pm
Beemerboneyard only sells one brand, Carbon Lorraine (sp?) for my 2001. I haven't installed them yet, but I expect them to be close to stock and perfectly fine.
Then again, you probably can't go wrong with OEM.
bgerrity is offline
post #5 of 6 Old Jun 10th, 2017, 11:04 pm
I favor EBC Double HH Sinistered for heavy bikes like the LT and my previous 1600 Vulcan Classic.
silverlt2002 likes this.
wrightwaay is offline
post #6 of 6 Old Jun 11th, 2017, 10:05 am
I would never use sinister brake pads on my LT.
As JZ said, sintered for the front and organic for the rear. My experience is counter to either JZ or Saddleman, but I had bad experience with BBY sourced Carbone Lorraine pads on the rear of my 07. The stock pads are still going strong on the front at 58,000 miles. My OEM rears lasted 27,000. The disk was in great shape. I bought the BBY pads not catching that they were full sintered pads. They also lasted 27,000 miles. The difference is they scored the disk badly and wore it to near the thickness limit. This is the only time BBY has sold me a part that is incorrect for the application.
I replaced the rotor with the EBC unit and used the recommended semi sintered pads they sell. I forgot the designation, but their rotor documentation spells it out clearly. Use of a full sintered pad will void the EBC warranty. Their documentation tells you why. The LT rear disk is thicker than standard due to the weight of the bike. Apparently, this requires using a different material source which isn't available hear treated to the same hardness as the thinner material used on other bikes and the front of the LT. This softer material will not withstand full sintered pads.
So, my opinion is to use whatever sintered pad you want for the front, but use organic for the rear with the stock rotor and organic or EBC's compatible semi sintered for the rear if you use an EBC replacement rear rotor.
looking to buy k1200lt, LA, CA powerman5kw South West 32 May 29th, 2017 11:56 pm
Burping the Brakes, Not Full Bleed - 2005 K1200LT deputy5211 K1200LT 5 Sep 18th, 2012 7:06 pm
Power cycles when brakes applied on a 2007 K1200LT Sprintman K1200LT 6 Jun 26th, 2012 11:17 am
