How to park LT in a wind open range? - BMW Luxury Touring Community
post #1 of 12 Old Jun 14th, 2006, 4:56 pm Thread Starter
strsout's Avatar
If you are in the middle of no-were, with no wind protection. them a strong 30mph, maybe 50mph wind start blowing from SouthWest, what would be the best way to park the bike?
The front nose facing what direction?
Center stant or Side stand?
Drop it down?
Loma Linda - CA
IBA#14,458 - AMA
strsout is offline
post #2 of 12 Old Jun 14th, 2006, 5:00 pm
JPSpen's Avatar
Hmmm
I'm thinking side stand. Wind blowing against the right side of the bike..
But if the wind does a 180 you're screwed.
J
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #3 of 12 Old Jun 14th, 2006, 5:30 pm
Drop it down?
That is a pretty good question Elton! Had not thought about it before.
My first thought would be centerstand facing into the wind. I would not trust side stand in gusty wind.
Laying it down, although a pretty good way to avoid blow over damage, will have one worried about fluid leaks/overflows. Laying it on the left side could pool oil in the combustion chambers, right side would be better for engine oil, but then final drive may overflow the vent plug.
The biggest problem would be brakes/clutch. Some of us have had no front brakes after a tip over because of air bubbles in the line from the master cylinder. This can work itself out after some time, but bleeding is the best way to repair this.
post #4 of 12 Old Jun 14th, 2006, 9:57 pm
After pulling into a Harley shop in Wyoming with every bike on the lot blown over by the wind, we parked our bikes (We were on Harley's) facing into the wind and on the side stand as Harley's don't have centerstands. That worked for us.
After getting caught in some unbelievable wind on my LT, with no place to go, not even a shoulder to pull off on, I had no other choice than to just hang on *tight* and keep on driving. Once the road took a turn between mountains it blocked the wind for me.
black1200lt is offline
post #5 of 12 Old Jun 15th, 2006, 2:08 am
BecketMa's Avatar
Just a guess, nose into the wind, on the side stand, 'course in first. Tail into the wind, like parking the nose going down hill.
Bob, 00LT
BecketMa is offline
post #6 of 12 Old Jun 15th, 2006, 6:02 am
Park it facing into the the wind and hope for the best
rixchard is offline
post #7 of 12 Old Jun 15th, 2006, 10:33 am
Zotter's Avatar
Coni's on the right track - wind is the norm out here (Something about Nebraska I hear). Parking in the open with 30mph is pretty common.
Wind shifting is rare here - fairly consistant when it's blowing. Takes a pressure front or other drastic change to get things 180.
Point the nose into the wind. If you need to expose a side at all or even quartering due to other limtis - go for the right side to take the brunt, side stand it. Avoid 90 degree broadside - keep it as close to nose on as you can.
No way I'd expose it to a tail wind while parked.
Can't say side or center is better than the other - I've only ever used the side stand in the wind - ain't had a prob, yet (::knock on wood:
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #8 of 12 Old Jun 15th, 2006, 8:13 pm
mwnahas's Avatar
On the side stand because, the three suppot points are farther apart then the centerstand, therefore a wider support base. Bike in gear as posted earlier.
Wind comming from the right front quarter. Least effect from the wind would be from the front, but you want some force from the right side to plant the kickstand.
oh ya windshield all the way down.
Just Go
Cleveland Ohio
mwnahas is offline
post #9 of 12 Old Jun 15th, 2006, 10:19 pm
Would putting it in reverse be better than in 1st gear? It has less slack in reverse.
Big_E is offline
post #10 of 12 Old Jun 16th, 2006, 9:15 am
Just a guess here, but no. The reverse is run off the starter motor, and the starter motor has no compression like the pistons to hold it in place.
So having reverse engaged would not necessarily keep the bike from moving.
Did that make sense?
Mopos is offline
post #11 of 12 Old Jun 16th, 2006, 10:42 am
Reverse has much less holding power than first gear. Try it sometime. Get the bike on a bit of an incline (while sitting on the bike!), put it in reverse, and see how much resistance to movement there is. Then put it in first and compare.
Takes quite a bit to move the engine in first gear, not so much to turn the starter motor in reverse.
post #12 of 12 Old Jun 16th, 2006, 5:59 pm
c00k1e's Avatar
Its not nearly as bad as some people imagine so long as you follow the basics;
1 - side stand
2. in gear
3 most importantly, push the bike up to the engine resistance point before finalising the side stand position
4 - a chock behind the rear wheel
I have had mine on a ferry to the Isle of Wight with NO tie down 4 times - the above has held despite my constant worrying!
c00k1e is offline
Lean into the wind? Smith K1200LT 29 Jun 3rd, 2006 6:49 pm
H... of a wind robasay K1200LT 16 Apr 18th, 2006 7:43 am
Replacing the smaller wind deflectors bmwbob1 K1200LT 3 Mar 18th, 2006 10:18 pm
The story of buying my LT (Really REALLY long...) bmwjason Ride Tales 0 Jan 6th, 2006 11:09 pm
